Question about Kenmore 64802 Top Freezer Refrigerator
Air vents are freezing up - Kenmore 64802 Top Freezer Refrigerator
    Sergeant:
    Champion:
  • 351 Answers
Getting air from somewhere check door seals make sure they are good and doors are closing tight
Posted on Sep 30, 2010
My refrigerator keeps freezing things...,.changed the gaskets around door and still have the freezing probkem
Most fridges have a cooling vent above or on the side of the top shelf. This is where most of the cold air comes from, so keeping food away from here may preventfreezing. ... Some side-by-side refrigerators (particularly older models) feature a vent that funnels cold air from the freezer into the fridge.4 Aug 2015
How to Prevent Your Refrigerator From Accidentally Freezing Food ...
refrigerators.reviewed.com/features/how-to-prevent-accidental-food-freezing-in-fridge...or try this link... refrigerator keeps freezing things Google Search
Oct 23, 2017 | Refrigerators
Model no. Fghs2655pf5a refrigerator side freezing food. I have set it to factory default and still freezing.
check ur thermistors in fridge and freezer, check ur defrost terminator and defrost timer. However is the freezer freezing too? if so I would suspect the terminator. if not check ur air flow vent and knob assembly as the vent may be closed to far or opened to far? the settings on the air flow and cold control thermostat should never both be set on high the middle is a good setting
Mar 13, 2015 | Refrigerators
Vent freezing up in fridge side
Isn't it fanned? The fan should blow cold air into the fridge. May be seized or iced up. Defrost, check and clean condenser, run to check.
May 03, 2012 | Refrigerators
Code p0410 on pontiac, aztek 2001
A code P0410 may mean that one or more of the following has happened:
  • Water may have collected in the AIR pump or the vent solenoid and frozen or corroded the pump
  • Blown AIR pump fuse due to freezing up
    • Blown AIR pump fuse due to freezing up good-day !
Nov 15, 2011 | 2001 Oldsmobile Intrigue
The produe in the veg./fruit bins are freezing
Hello. On some refrigerators there are vent holes that allow colder air from the freezer compartment to be vented to certain areas in the fridge. Look and see if there are any vents like this on your fridge, If so you can control the amount of cold air entering by sliding the door open or closed on the vent. If there is a vent but the cover is broken or missing you can cover the hole to reduce the freezing air entering the fridge.
Jun 12, 2011 | Refrigerators
I see a misty smell like anti freeze coming through the vents in the car
Holy cow you can see smells?????
haha just messing. If you have the smell of anti freeze coming through the vents it means that the heater core needs to be replaced. The heater core cycles the hot engine coolant and uses that to warm the air to give you hot air. If you can smell it it is leaking into the vent system and needs to be replaced.
Apr 22, 2011 | Buick LeSabre Cars & Trucks
The freezer side does not freeze on the top shelf. The refrigerator freezes everything in the bottom but reads 47 degrees and doesn't cool the top shelves. The fan under the fridge runs fine.
Behind the back wall of the freezer about halfway down, probably behind the light bulb (if there is one there) there is a fan. My guess is that the fan isn't working, or is slow. To test, open the freezer door, then hold the door switch closed and listen for the fan.
This fan should be blowing air up the back of the freezer, and send some of the cold air through a vent at the top of the freezer into the fridge. The air then descends through the fridge and reenters the freezer through a vent at the bottom. If the fan is broken, or if the upper vent is somehow blocked or broken, the cold air will enter (rather than exit) the fridge side at the bottom vent. Because cold air tends to descend and warm air rises, the cold air will freeze the stuff at the bottom of the fridge, and the thermostat (at the top of the fridge) will say it is warm.
Dec 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My A/C evaporator is freezing up, and wont cool the house below 85 degree
Check your filter and make sure you have one in place and it is clean. This is either a low inside airflow problem or system is low on freon. If you have strong air flow from vents and filter is been kept clean then low freon is most likely. Run system in on position with cooling off to make sure ice is melted. When water stops draining. then restart system . If it starts frosting up at outside unit shortly after start up it most likely is air flow. If you don't have at least 15 degree drop from registers in a few minutes and indoor humidity is not too high inside and airflow decreases and air gets colder just before it freezes up then it is low freon.
Jun 29, 2009 | Heating & Cooling
Air conditioner line freezing up
Check to make sure the filter inside the air handler is clean and that no vents are closed or blocked by furnature or rugs. Check the air handler to see if the blower is operating. You could have a belt off, the door switch could be in the open position or something simple like that. If this checks out OK., you will need to have a technician check the charge
Oct 07, 2007 | Goodman CLQ36AR49 Air Conditioner
Kenmore 64802 Top Freezer Refrigerator Logo
37 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
