Question about Maytag 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White
Maytag Model MZD2768GE, Volume 26.9 Climate
Maytag Model MZD2768GE, Volume 26.9 Climate control technology - top drawer won't hold (preset temperature) It has Citrus, Produce and Meats - no matter which one I push, the temperature keeps dropping (as low as 25 when I shut it off and moved the meat from there to the next drawer) , waited 5 hrs, turned it back on the Temp read 40, waited 1/2 hour and the temp had dropped to 31, so I shut it off again. Is there a way to set the temperature and make it "hold" like a reset button or something like that?
catriver
  • 878 Answers
SOURCE: Refrigerator won't cool. Freezer works fine!
Pierce, there was a service bullitin put out on this model. TDR-0010A-B. Had to do with normal freezer, warm fresh food compartment. Maytag issued a kit that included a new thermostat and damper assy. to solve this problem. Bullitin came out in 2002. If you are not having a defrost issue and all fans are running normal, I would call Maytag and inquire about the above posted bullitin, It may be covered. Catriver...post back.
Posted on Sep 04, 2006
HVACRH20
  • 237 Answers
SOURCE: Maytag fridge s-by-s freezes alot of the stuff at the back and lower vege drawer
Actually this seems about right. The air flow in the fridge is usually from the back top of the fridge. That will be the cold spot then the air sinks down to the bottom and then recycles back into the freezer comp. to get cold again. Door shelf is usually warmer than the rest. As with most units, it takes some understanding of the air circulation pattern in order to find the sweet spots for dairy products and meat, veggies, etc. Check to see if there are slider adjustments on the drawers for temp or humidity, etc. Also make sure there are not parts missing from the inside of the fridge. Sometime a part that appears to only be a small plastic item gets broken over time and never replaced when it could actually be very important to air circulation. I recommend getting a small floating aquarium thermometer and setting it in a glass of water in order to get the "true" temp. of the products not just the air temp of the fridge. Put the glass in different locations over a weeks period to record what the temps are like in different areas of the fridge so you can make a "map" of the cold spots, etc. Leave the thermometer in for about 12 hours before you record the temps for that location. I think you will find the answers you need in order to place your food more effieciently in the fridge. As for summer days, the unit will have to work harder in warm weather to cool than it does in the winter months of course but there is always a concern that you are not cooling 100%. The way to check that is to let the unit run for several hours (turn the temps down so it runs for at least an hour solid) then you would have to pull the whole interior rear freezer panel off the back to view the cooling coils and make sure they are fully frosted across the whole coil surface. If they are iced up only in a few inches of coils then you likely have leaked out the liquid refrigerant over the years and there's not enough to cool a full 100% of its capacity. And your complaints are the same with even brand new models... it's about 60% of our service calls (not cooling properly or freezing food).
Posted on Jan 28, 2007
SolutionGuy
  • 331 Answers
SOURCE: 'ice dam' on bottom of freezer, now problems with fluctuating temps
Kat, you only have 1 problem happening.And no this is not due to the original repair. (though I have to admit... replacing the filter/drier, starter and compressor is NOT part of routine maintenance and has me a little befuddled.) Your evaporator drain is plugged. Most likely with what we in the biz call "bio-gookus". This is normal, but must be cleared to keep the water from puddling and coming out your freezer door. With the evap panel removed and the drain hole exposed, pour 1/4 cup of HOT water into the drain hole. Use a small screwdriver or other small instrument to pick out the ice buildup. Once this is clear, use something like this http://www.azpartsmaster.com/shopazp/Gallo+Condensate+Blowout+Guns+(A66800).html to blow out the rest of the lines. After doing this, pour more hot water into the drain to verify free flow. This will take care of your leak problem. Now... the frost buildup. NEVER RUN YOUR FRIDGE WITH THE PANELS OFF! They are there for a reason, believe it or not. They direct air flow across the coils (both evaporative and condensing). Frost buildup is normal, though you may be experiencing higher levels of frost because of the panel missing...Your fridge utilizes an automatic defrost system. It'll initiate every 8 hours. This is controlled by a timer located in your fresh food section. The defrost heater RARELY fails on these. Fix the evaporator drain and replace all panels. This will solve your dilemma.
Posted on Aug 09, 2007
  • 3 Answers
SOURCE: Temp control moves on it's own
Mine was doing the same thing and it was really frustrating! I would come home and it would be 88* inside. I found out that this model air conditoner has had problems with moisture getting in the control panel and shorting it out when it's humid outside. I have the part number if anyone wants it. It cost me about $45 from Sears Parts.
Posted on Jul 08, 2008
docjohn174
  • 943 Answers
SOURCE: Maytag Gas Dryer - Flame starts and then turns off 5 seconds into cycle
HI thanks for your question. the coils on the gas valve are faulty . common problem with gas dryers , replace the coils thanks the appliance doc. please rate my answer. thanks
Posted on Oct 11, 2008
Monogram DISP480DXASS jack hammer noise behind the Climate Control Drawer.
By the way you discribe it, it sounds like it's going into defrost mode check and make sure freezer side isn't iced over or that the drain isn't iced over if it's a side by side drain should be at the very bottom of freezer side usually hidden behind a piece of plastic if it's a top and bottom the drain will in the freezer very back bottom also hidden hope this helps
Mar 04, 2016 | Refrigerators
Maytag climate control drawer fan is not running.
Refer your inquiry directly to Maytag or an appliance parts supplier.
Jun 28, 2014 | Maytag MZD2766GES Side by Side...
Refridge is warm, freezer is working fine. There is a damper controlled by a small motor behind the meat drawer or top drawer. Pulled out drawer, and hole that gets air from freezer was blocked with a...
This is known as the CZT or Climate Zone Technology fan and if you direct wire it and it does not run, replace.
This is the cold zone fan which supplies cold air to the meat and crisper drawers.
Feb 07, 2011 | Maytag MSD2758GEW
I've got the same problem with my 2nd drawer. Did you figure out the problem with your top drawer?
Oct 06, 2009 | Refrigerators
Volume
Set the volume to the desired start up volume then hold the knob in for about thirty seconds. It should beep. The radio will then start at that volume everytime you start your car.
Sep 01, 2009 | Jensen's VM9312 Car DVD Player
MSD2758GEW Climate Zone Drawers
This fridge is garbage. Fixed ours 14 times in 6 years. WILL NEVER BUY ANOTHER MAYTAG ANYTHING AGAIN!!!! CLIMATE ZONE TECHNOLOGY DRAWERS NEVER DID WORK CORRECTLY....EVER.
Jan 31, 2009 | Maytag MSD2758GEW
MY Maytag Wide by Side freezes in the produce drawers.
When a unit freezes in the lower drawers this is usually due to a thermistor which is not functioning properly. If you can provide your model number I can try to locate your schematic to your unit showing the thermistor that you would replace to alleviate this issue. I will await your reply as to the complete model number of your unit.
p.s if you had ice up the top of the unit as well then you would look at the damper door otherwise known as the diffuser door in some units or the control for the door as the problem area in your unit.
Thank you,
Rick
Jan 21, 2009 | Maytag 26 cu. ft. Wide-By-Side...
Remote Control Control Codes
has anyone solved this problem???
Jan 13, 2008 | Audio Players & Recorders
Maytag 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White Logo
105 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
