Question about Huffy Sport & Outdoor - Others
Need replacement part for Huffy Sports Main Court Jr. Portable basketball goal. The replacement part is the bottom pole of the goal. Would like price quote and avaiability of this replacement part. Thank you in advance for your assstance on this matter.
5 Suggested Answers
SOURCE: do not have the instructions for assembling a
http://www.lifetime.com/customer-care/instructions.aspx
Posted on May 11, 2009
walesarumi
  • 6993 Answers
SOURCE: I have an old huffy
Follow the below assemble instruction as requested for your huffy sports basketball hoop;
Insert the mounting screws through the mounting holes of the backboard, then lay the backboard face down. Lay the mounting brackets on top of the backboard so the mounting screws of the backboard go through the mounting holes of the brackets. Tighten the screws with a wrench.
Insert the adjustment hardware between the brackets and insert the screws connecting to the brackets to the adjustment hardware, then add a nut to the screw and tighten with a wrench. These screws will be inserted horizontally through the brackets into the adjustment hardware. The adjustment hardware allows you to adjust the height of your basketball hoop.
Line up the holes of the rim to the holes of the backboard and install the rim screws through the rim into the backboard and secure them with a nut. Tighten the nut with a wrench. Thread the nut through the wire holes of the rim.
Assemble the pole. Dig a hole with a shovel where you want to install the basketball hoop. For the exact size of the hole, you will need to consult the directions on your Huffy basketball hoop. To achieve the regulation height of 10 feet, this step strongly depends on the size of the particular basketball pole and a specific measuring depth. Measure the hole with a tape measure for accuracy. Mix a bag of cement in a wheelbarrow with water. Consult the directions on the cement bag for exact mixing instructions.
Place the pole in the hole and shovel in the cement. Allow the cement to dry.
Use a ladder to reach up and connect the mounting arms to the mounting brackets and then to the top piece of the basketball pole. Each of mounting arms has a hole at the end that you need to line up to the mounting bracket and secure with a screw, add a nut and tighten with a wrench.
Line up the holes at the end of the two top arms to the top holes of the top of the basketball pole. Insert the long screw through the holes of the arms and pole, secure it with a nut and tighten it with a wrench. Install the bottom arms to the lower holes of the basketball pole.
I hope the above helps.....
Good luck.
Posted on Apr 03, 2011
Ironfist109
  • 3018 Answers
SOURCE: I want to pull apart
  • I know exactly what your talking about. When you disassemble the hoop assembly down to just the poles get yourself a friend and a couple long screwdrivers and run them through the holes at the top and bottom of the pole. One side for you and the other side your helper. You may want to spray some WD-40 or any kind of bolt buster lubricant in where the poles are connected first. Give a gentle twist back and forth as needed too. You will want to do this on a lawn so that when they come loose they don't get all scratched up. This is how one is suppose to separate these poles.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Posted on Jul 03, 2011
SOURCE: Lifetime Portable Basketball System- The pole are stuck.
Deddy456 was spot-on with dropping the poles from waist level. Worked for our Spalding that looked hopeless. Thanks!
Posted on Nov 20, 2011
How do I get a Spaulding portable basketball goal pole a part
Dear Shane,
I would try contacting the Spaulding company, by phone, and I am hoping you can find their factory & number on your computer.
God bless your efforts.
(P..S. It may not come apart)
May 11, 2018 | Sport & Outdoor - Others
How to install back board to the pole on a huffy sports center court
There should be a pole bracket with 4 to 6 bolt holes that attaches to the back board plate.
Jul 12, 2014 | Sport & Outdoor - Others
Huffy center court replacement backboard
you can go online like to ebay or some other dearler ship and search huffy center couter or (backboard) and there you go. Also its cheap
Mar 16, 2013 | Basketball
Need replacement balls for a Huffy electronic
I have found the number for Huffy. You should be able to see if they have replacement balls for your electronic basketball game.
U.S. Customer Service
Email: service@huffysports.com
Phone: 1-262-820-3440
Phone: 1-800-558-5234
Fax: 1-262-820-6757
Thank you, hope this helps. Please let me know.
Apr 30, 2010 | Huffy Dual Electronic Basketball Game
Assembly instructions for portable basketball hoop
we put all three poles into one by mistake on our new portable hoop we managed to get the screw out but cannot get the poles apart help!
Sep 10, 2009 | Huffy Sport & Outdoor - Others
Sport & Outdoor - Others Logo
183 people viewed this question
Top Huffy Sport & Outdoor - Others Experts
Bill Eager
Are you a Huffy Sport and Outdoor - Other Expert? Answer questions, earn points and help others
