Question about Refrigerators
Water build up in the bottom of the refridgerator under the fruit and vegtable cripser draws. maytag model #MTB1954ARW
  • 1 more comment
  • Anonymous May 25, 2008
    Water accumulating under the vegetable drawers on the bottom of my GE refrigerator
  • capt42 May 26, 2008
    Same problem - have checked the seals, no apparent damage.
  • Anonymous Mar 18, 2009
    Hoover HE430TF water in bottom , have replaced seal and recommended to unblock the drain under the plastic light assembly . I NEED A DIAGRAM OF THE EXACT LOCATION OF THE DRAIN LOCATION
  • 525 Answers
Water build up under the fresh food drawers is usually associated with an air intrusion from the exterior. Warm air intruding into the fresh food compartment creates excess condensation, which eventually accumulates on the bottom.
Some causes are:
1. Internal obstruction, not allowing door(s) to close tightly enough.
2. Deteriorated door seal, (torn, pinched, deformed, misaligned,).
3. Light not turning off when door closed,(faulty door switch, misaligned door, loose hinges allowing door to drop).
Make sure all drawer have nothing obstructing their closure, and door shelves have nothing extending beyond the support bars.
Other less obvious causes may be creating this issue also and are not normally addressable by the novice servicer.
Hope this helps find the cause.
Posted on May 25, 2008
What is setting for fruit and vegetable draws
Lower humidity is more cold air going in. Higher humidity is les air. Veggies in higher humidity and fruits in lower. Meat can also be be stores in lower humidity.
Sep 07, 2012 | Maytag MFD2560HES Bottom Freezer French...
Fridge looses temperature
Make sure the two vents from the top of the fridge that run into the freezer are not blocked or obstructed in anyway, that's what the problem was in ours. Also do not allow ice to build up on the vents in the freezer.
Jan 03, 2012 | GE Profile 26.6 cu. ft. Side-by-Side...
Model 363.9668513 water collects under the fruit
this is because the plastic is shiny and attracts condensation,only "cure "is a piece of kitchen towel under drawer to mop up as/when.(when you open door all the cold air drops to the floor and is replaced with warm moist air from the kitchen.hence condensation.
Apr 13, 2010 | Refrigerators
Model PTB1953GRO Maytag Refrigerator-Water drips into
you might need to open the freezer wall and clean the drain hole.. it might be cluge... very EZ :)
take all out even the ice maker unit
take back wall out and see if the drain is cluge with ice or something...clean it and out it all back
Dec 31, 2009 | Refrigerators
Water accumulating in the bottm of refridgerator
HI, Now that you have the ice out of the drain, There is an after market drain transfer heat strip kit you need to buy and add.
Please let me know if I can help you. I have the kit on my web site www.whirlpoolpartssurplus.com
Let me know if I can assist you
Thanks
Vic
May 17, 2009 | Refrigerators
Drain hole in top fridge section flooding and icing up under vegtable storage draws.
maybe you fridge is tilting to far forward some times a fridge needs to lean back slightly only by 5 degs so adjust the foot t the front. this will mke the water flow towards the back and also help keep the doors sealed better
Dec 10, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
308 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
