Question about Kenmore Elite 45986 Front Load Washer
How do i remove front console of he4t washer?
  • 3 Answers
SOURCE: Kenmore Sedona Elite 3.8 Cubic Foot HE4t Washer (Front-Loading) 45089
open lower front with a starshaped bit(screwdriver) three small screws, to get to white plastic cleanout (easy to turn by hand)may have someting stuck in it. about a gallon of water is there so have two big towels ready to soak it up.
Posted on Dec 29, 2007
jsrock516
  • 5911 Answers
SOURCE: kenmore elite HE4T front load washing machine standing water
This problem can be caused by either a leaking water inlet valve, or a condition known as "siphoning". Since you just recently moved, I would make sure you don't have a siphoning problem, first. The following link explains how:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Although siphoning normally refers to a constant drain problem where a washer has problems maintaining the proper water level, it can also lead to problems where the drain line will back up into the washer.
Now, if you follow the advice in the link and determine this is NOT caused by siphoning, I would suspect that you have a water inlet valve that is leaking. A tell-tale sign will be water trickling down the fill tube in the rubber door bellow. The water inlet valves have a diaphragm that is controlled by an electric solenoid. Sometimes the valve becomes clogged with sediment or deposits, causing the diaphragm not to close properly. If you live in an area that has hard water, or use well water, you may have hard water deposits or rust build up in the valve. You may be able to correct the problem by removing the valve and cleaning it with some distilled vinegar. You can remove the valve by following these steps:
1. Unplug the washer and turn off water supply at the taps.
2. Disconnect the water inlet hoses.
3. Remove washer top panel by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel slides back, then off.
4. The inlet valve (this is what your water inlet hoses connect to) will be located in the left rear of the washer (facing from the front). Remove the dispenser hose(s) from the valve and the electric connections. Remember how the electrical connections are removed. They should be color coded. One is for HOT, one is for COLD.
5. Remove the mounting screws that hold the assembly in place.
Once you have the inlet valve removed, you can place it in some distilled vinegar and let it soak. Just don't submerge the electrical connections. If this does not correct your problem, replace the valve. Searspartsdirect.com and repairclinic.com are two notable web sites that I have frequently used. Just type in your complete model number to begin the parts search.
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Sep 02, 2008
SOURCE: HE4T How to remove the front panel
if you want to take the top panel off,there are 3 screws at the back of the machine,remove then lift
Posted on Feb 25, 2009
rickead1
  • 1998 Answers
SOURCE: I have a kenmore he4t washer and the front door
First thing to check is if your door hinge has a sag to it. The next step if there is a sag is try adusting the screws that hold the hinge on the frame of the door sometimes these do come loose. and do require tightening. Folowing confirmation that there is no sag in the hinge your next step would to order a new door latch. If you are not mechanically capable of removing the front section of the machine you should call a technician
Posted on Apr 28, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elit HE4t Front Load Washer leaking from rt side of tub
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question##$$
Posted on Oct 01, 2010
How to repair HE4t with HF code?
HE4T had problem on control board when early time version. Later they modified control board and find new version should fix your problem.
Apr 24, 2014 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
I want a manual for My Kenmore HE4T Front Load Washer
This site has lots of manuals. http://www.manualslib.com/products/Kenmore-He4t-110-4508-3024385.html#.VPmnI5cyiQE.mailto
Feb 14, 2014 | Kenmore HE4t 3.8 Cu. Ft. King Size...
How do you reverse the front door on a Kenmore HE4t washer?
The Kenmore HE4T washer does not have a reversible door. The matching dryer would have a reversible door.
Some newer washers do have a reversible door but it is still a very small number of washer that allow you to reverse the door.
You can not reverse the door on an HE4T washer.
Aug 21, 2011 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Apr 28, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t Washer Control lock lit, door locked
121 MINUTES USUALLY DRAIN CYCLE PLZ REMOVE 3 BOTTOM PANEL SCREWS 7 MM SCREWS, TO OPEN DOOR SLIDE RIGHT HAND TOWARDS DOOR LOCK ,THERE WILL BE A SMALL LEVER TOO PULL DOWN ,NOW ITS OPEN,,, SINCE U HAVE BOTTOM PANEL OFF PUMP IS RIGHT IN FRONT REMOVE PLASTIC HOUSING CLOCKWISE ,,,REMEMEBER HOLD 3 GALLONS OF WATER STILL ,HAVE BUCKET READY ,NOW CLEAN OUT PUMP AND DEBRIS ,, CLOSE IT UP SHOULD BE FINE NO MORE PROBLEMS ,,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
THE WASHING MACHINE TUB ON MY KENMORE HE4T SLAMS AGAINST THE SIDES OF THE MACHINE AND EVEN CAUSES IT TO JUMP ACROSS THE FLOOR
remove the front access paenl 3 screws across the bottom fornt panel. under there you will see the 4 suspension(shock absorbers), look to see if they have broken or perhapsa just dislodged form hte unit ,
Dec 02, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore Elite HE 4T
HE 4 front load remove bottom panel 3 screws once remove now you have access to pump get towels and bucket oper lint filter and remove debris from inside ,,,,, and that its F2 long drain,,,,,,
Oct 13, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
HE4t King Size Washer Balance Problem
remove the lower acess panel ( 3 screws across bottom) check for broen suspension/shock absorbers
Mar 02, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore 3.8 cu. ft. HE4t King Size Capacity
remove feet set on stand and put the 4 screws in 2 in the front 2 in the back the remove the drawer and level the 4 legs on the stand then lock the lock nut if you git a little vibration raise the front washer up 1/8 in usely will take care of it
May 03, 2007 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
49 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
