Question about Amana ABB1927DE Bottom Freezer Refrigerator
Refrigerator and freezer are not cold. This is the second time this has happened. We purchased the appliance about 6 years ago. I have unplugged it and let it set for an hour. Plugged it back in. . . . nothing. Is there a re-set button? What should I do?
  • Amana Master
  • 3,740 Answers
I am sure by now that things are already pretty warm. There are a few possibilities here that can cause your symptom
1. The defrost cycle never terminated. This is controlled by the 60 deg F thermostat in the evaporator area. If the thermostat has failed it will not allow the defrot cycle to terminate when 60 deg F has been reaches. I.e the unit will sit there dead but the interior lights will work.
It is item 31 of this link but not shown on the diagram:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174373&diagram_id=1358641#d1358641
Here is the thermostat: http://www.appliancepartspros.com/part_details.aspx?part_id=4078076&image=5
2. Also there is a Thermistor (Item 29 of the below link) than can cause the unit not to start:
3. The unit control board has failed
Unit control: (Item 5)
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174373&diagram_id=1363241#d1363241
There are other things that can cause this such as the Compressor PTC Relay / Thermal Overload or the run capacitor. But the items listed above are the most common.
PTC / Thermal overload Items 10 and 11 of this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174373&diagram_id=1341069#d1341069
If there are no internal lights then there can be a problem with power after the power cord.
I am sorry but there really is not a fast fix for this. What you can do is place a fan blowing into the freezer compartment for 2 hours. (Makes a water mess) If the defrost cycle terminates when you plug it in after the manual defrost then the defrost heater can be defective. The heater is Item 15 of this link:
With out troubleshooing with a meter using the wiring diagram here
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=1358643&pkw_=basket&model_id=5174373&NewWindow=1
It would be difficult to say exactly what is causing your current failure. All I can say is what will cause it. I can not say change part "____" because I have not proved with out a doubt what part has failed.
Thanks for choosing FixYa.
Kelly
Posted on Sep 30, 2010
    Sergeant:
    Champion:
  • 351 Answers
No reset maybe a bad thermostat or defrost timer there a lot of thing that could make not cool
How to replace defrost timer
a bad defrost timer can be checked with a multi meter
Sep 08, 2014 | Whirlpool Refrigerators
STANDING WATER UNDER DELI TRAY
Try going further than defrost and draining the hose. There is gunk that builds up and you need to clean that out. Use a pipe cleaner(the fuzzy wires used mostly for art projects. They actually can clean pipes and water lines!!) Also, you can pick up a pack of pellets used for breaking down the "gunk" build up.
Mar 06, 2014 | GE Profile : PFSF6PKXWW 25.5 cu.ft. Bottom...
We have a GE side-by-side refrigerator (GSS23QGTA); it's about 6 or 7 years old and has been working just fine until about a month ago when we noticed that the freezer was not freezing food. The temp had...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 16, 2011 | Refrigerators
Freezer frosting over vents, refrigerator not cold enough
Greetings,
i work on this for a living 33 years..sight unseen, I'd say the evaporator is froze over. Its missed its defrost..I suggest leave freezer door open and unplug for 24 hours to melt ice..There still will be a problem and this will continue, but this gives you temporary service. You;ll need a repair-person to fix it. The evaporator frrezes over blocking airflow to fresh -food section. This in turn can cause a fresh food and freezer failure..
Bruce Denton appliance tech 33 years...
Jun 30, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
Kenmore Elite bottom freezer making a clickbuzzzzzzclick sound
you need to check to see if you have a control board by compressor.if not change relay and overload to compressor if you have a grey box with a board in it then you need to most likely change it
Mar 14, 2009 | Refrigerators
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
Amana ABB1927DE Bottom Freezer Refrigerator Logo
144 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
