Question about Delfield Freezer ColdPro Solid Door Reach-in Freezer - 3 Section
I have a delfied freezer and i cant find the defrost clock or the temperture control.its a two door with a refrigerator on one side and a freezer on the other it has defost heaters on the freezer.the reason i ask is the freezer part wnt shut off when it reaches temperture and it freezes up because it never shuts off and the temperture readout starts blinking and beeping.the model # is6051-sdt is it on the board or is it the temp readout messed up
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 141 Answers
Look in the refrigerator section by the light you may need to take off the light cover ... or it may be down on the bottom behind the air grille
Posted on Oct 01, 2010
  • jason zeringue Oct 01, 2010
    im sorry i answered you with the wrong answer send me your e mail add and i will recerch in the morn but i think if it has an red led temp reading i think that is also your defrost timer jason e mail model and serial too airforceac@live.com
Why mu refrigerator rrtg21pabb ia working but not freeze
If the refrigerator is not defrosting, the defrost control board might be defective. The defrost control board monitors several conditions and determines how often to run the defrost cycle. If the board fails, the refrigerator will not go into the defrost cycle. Eventually, ice will build up on the evaporator coil and then the refrigerator and or freezer will not stay cold enough. This will depend on where the evaporator is located. It's prudent to check the defrost heater and defrost thermostat for continuity before replacing the defrost control board.
Aug 27, 2014 | Haier RRTG21PABB 20.7 cu ft Two Door...
Samsung RS261MDPN not cooling properly
sounds like a defrost issue defrost clock heater or limit could be bad
Jan 18, 2013 | Samsung RS261MDPN - 26 cu. ft. Side by...
Ice keeps forming on the bottom of the freezer - like a leak on the back side flows into the bottom toward the door.
When a refrigerator leaks water like yours, it is common for the problem to be nothing more than a clogged defrost drain. When the unit defrosts itself, the frost melt water drips into a pan underneath the evaporator in the freezer, and goes through a tube from there to the bottom outside of the unit. Since the water cant go down this drain, it backs up on the freezer floor, then eventually the kitchen floor.
Oct 06, 2010 | Amana 15.0 cu. ft. / 425 liter Upright...
CAN'T GET EVAPORATOR FAN TO COME ON & TEMPERTURE TO DROP.
Several possibilities. The fan won't come on until the coil inside the box on top of the freezer gets down to about 0 degrees. It also will not come on if the door is open. It sometimes takes 10 to 15 minutes to come on. If you are low on refrigerant (freon) the coil will not get cold enough to come on at all. Feel the coil on the outside of the freezer on top and see if it is very warm to the touch. If not you are probably low on refrigerant. If you have the electronic control system, it may not be sending the signal to the fans after a defrost cycle. If possible, put gauges on the valves to check your freon charge. If this unit has not been operational in a while, you might try flipping the top cover off the coils and turn the fans by hand a couple of revolutions. I have had them to seize up from not being used. The fans should turn freely.
Aug 31, 2010 | Delfield Freezer 6125XL-S
Woods upright freezer
I would look at the defrost control [sometimes they are defrost clocks]Maybe that the freezer is not defrosting.
Jun 26, 2009 | Freezers
Side by side refrigerator is not cold. Bottom freezer is.
if the freezer is cold and the fridge is not then it can be several things. The freezer could have a bunrt out defrost heater, defrost timer faulty, fan not working in the freezer??. all of these things will stop your fridge getting cold, but your freezer will still be around minus 9 deg c. you wont get any air into the fridge as the coil in the freezer is prob all iced over. Dont worry about the heat on the door frame as it is only the anti sweat heater
May 01, 2009 | Maytag Freezers
Delfied Freezer6000XL freezing temps are not hold
Sounds like a refrigerant restriction in the system. Recover the refrigerant, replace the filter drier and pull a deep vacuum on the system before recgarging.
Mar 21, 2009 | Delfield Freezer 6151XLSR Stainless steel
Freezer/refrigerator
Refrigerators with an evaporator (called a humid plate on this type of refrigerator) in the refrigerator section are called a semi-automatic defrost. This means that the freezer section occasionally needs defrosting but the refrigerator section defrosts by a means called "heat leakage defrost". How it should work....
the cold control, (the electrical device under the dial), leaves the compressor off for long enough for the plate to melt off each cycle.
If yours is not melting off perhaps you have a faulty control or you have it set too high. hope this help
Oct 07, 2008 | Frigidaire Freezer Refrigeration White...
Fridge freezer
  • Check the temperature setting
  • Assure that there is enough room for air flow in the refrigerator or freezer
  • Check for air flow restrictions in vents
  • Test the temperature control
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • Test defrost heater
  • Test defrost timer
  • Test evaporator fan
  • Check for a clogged drain tube
  • Check for refrigerant leak
Sep 23, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Sides of freezer extremely hot
if there is air getting into the freezer because the door is not sealing properly the unit will run because it is sensing it is not cold enough inside. your unit releses the heat from the refrigerant through copper tubing that runs through the cabinet, and thats why it is hot. you need to level the unit make sure the door is sealing on the top bottom and both sides ansd then the freezer will work properly and be able to shut off after it has come down to the proper temp.
Aug 05, 2007 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezers Logo
106 people viewed this question
Top Delfield Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
Tom Donaldson
Level 1 Expert
Are you a Delfield Freezer Expert? Answer questions, earn points and help others
