Question about Polaroid A515 Digital Camera
What does SD protected on my polaroid a515 mean? How do I get it out of that mode?
    Brigadier General:
  • 3,006 Answers
Your camera uses SD memory cards. On one edge is a slider switch: towards the electrical contacts is the unlocked position and away from them is locked.
Unfortunately, the switch is easy to move accidentally and it's also easy for it to appear to be unlocked when it isn't. Like any mechanical component it's also possible for the switch to fail.
If the switch is in the locked position then slide it fully to the unlocked position; if it's already in the unlocked position, slide it fully to the locked position and then fully back again. There should be a soft click at each end of the switch travel, if not then the switch is definitely faulty or obstructed.
If that fails, then try looking closely at the switch in both positions to ensure that there is no debris obstructing its movement, if not then check the electrical contacts to ensure that they're completely clean and grease-free. Don't touch the contacts with your bare skin, but if the contacts need cleaning then a cotton bud (Q-tip) moistened with a little alcohol or methylated spirits can be used to clean them.
If you still have no fix, then try a different SD card as yours may have an irreparable faulty switch. If the card does prove to be faulty then on most major brands you may be able to return them to the manufacturer for exchange: I've found that they will often do this on a goodwill basis even if the card is out of warranty.
If all options regarding the memory card are unsuccessful, then you have a faulty camera and further remedies require either a professional repair or replacement of the camera.
I hope that my answer has been of use and has given you additional options to fix your problem. Please take a moment to rate my reply.
Posted on Sep 30, 2010
Where to insert sd card polaroid a515 digitgal camera
Open the battery door, located on the underside of the camera (use your thumb to slide the door outwards). Install the SD card into the slot located next to the battery bay. Close the battery door.
Apr 04, 2011 | Polaroid i830 Digital Camera
Need to know how and where to insert sd card
There are usually 2 places that an sd-card can be inserted in a digital camera - Inside near the battery under the door, or a separate flap on the bottom of the camera labeled SD.
  • If there isn't a slot specifically for an SD-card on the bottom of your camera, open the battery door.
Try and locate a very thin rectangular ****. Once you have found the slot, take your sd card and push it inside the slot until you hear a click, that means it's securely in place.
Apr 04, 2011 | Polaroid A515 Digital Camera
How do i format a larger sandisk card and what are the stepts?
Hi
The Polaroid A515 digital camera can only use SD cards upto 1Gb. if you are trying to use a SanDisk 2Gb SD or a higher capacity SDHC card you will be disappointed.
Regards
David
Dec 29, 2010 | Polaroid A515 Digital Camera
Our Polaroid a515 camera is not being recognized by our Mac when we connect it by the USB cord.
If you use a memory card in the camera. just get a card reader and use it to download to a folder you create on your desktop.
Oct 11, 2010 | Polaroid A515 Digital Camera
What kind of memory card do I need for Polaroid a515 model digital camera?
you need a SD card...they go for cheap i believe. make sure its not the mini or micro....it should be the plain sd card..
heres a picture:
http://blog.frankvh.com/wp-content/uploads/2009/07/sd-card.jpeg
sanddisk i always a good company but they are all the same for me.
post for more help :)
-mike
Sep 24, 2010 | Polaroid A515 Digital Camera
Trying to find out how much cam is worth
you can get whole detail at.... http://www.retrevo.com/s/Polaroid-A515-Digital-Cameras-review-manual/id/1235bh241/t/1-2/
Feb 22, 2010 | Polaroid A515 Digital Camera
Where can I get an instruction manual for a515 polaroid camera. the instructions were lost.
http://www.polaroid.com/service/userguides/digital/cameras/a515_a520_ug_en.pdf
Jun 05, 2009 | Polaroid A515 Digital Camera
Cant take picture. polaroid a500 camera reads sd protected.
It means the sd card cant be accessed unless you remove the protection . Connect sd to laptop and use software to remove the protection .
Mar 13, 2009 | Polaroid A500 Digital Camera
My camera wont put the pictures on my computer
If you have a SD card in the camera i suggest just pulling that out and plugging it into an SD card reader and pulling up the pictures that way
thats the easiest way of getting the pictures out
Aug 01, 2008 | Polaroid A515 Digital Camera
Hi
The polariod a515 has a microphone built in
but it does not have a full speaker, just a little one thats only good for blips and boops.
so unless you have sound disabled it will not play back the sound for you
Aug 14, 2007 | Polaroid A515 Digital Camera
Polaroid A515 Digital Camera Logo
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
