If your Whirlpool LTE6234DQ3 dryer is not drying clothes properly on the automatic/permanent press cycle, there are a few parts that may be causing the issue:
Moisture Sensor: The dryer's moisture sensor detects the level of moisture in the clothes and adjusts the drying time accordingly. If the sensor is dirty or faulty, it may not be able to accurately detect the moisture level, resulting in clothes not drying properly. Try cleaning the sensor with a soft cloth and see if that resolves the issue.
Thermostat: The dryer's thermostat regulates the temperature inside the drum. If the thermostat is faulty, it may not be able to regulate the temperature properly, leading to clothes not drying properly. A multimeter can be used to test the thermostat for continuity.
Heating Element: The heating element is responsible for generating heat in the dryer. If the element is faulty, the dryer may not be able to generate enough heat to properly dry clothes. A multimeter can be used to test the heating element for continuity.
Ventilation: Poor ventilation can also lead to clothes not drying properly. Make sure the dryer's venting system is clean and free of blockages.
It is recommended to have a professional technician inspect and diagnose the issue if you are not comfortable with checking and replacing these parts yourself.
clean out lint filter check the vent hose make sure you are getting a air flow out your vent hose if not its blocked inside no air no dry it need air to dry cloths heat only will not dry plenty of air heat quicker drying
I have a Kenmore dryer and it runs but won't heat up and dry the clothes. I don't hear the ignition even turn over. Please help. I can't afford to buy a new dryer at this time.
I am having the same problem on a WD9900A. The wash cycle works great. Spins fast and clothes are completely rung out. Dryer cycle heats up well. Fluffs and heats cloths. At some point during dry cycle water is injected on clothes and they end up sopping wet; much wetter than after wash. Filter is clear. Outlet pipe clear and functions well. Possible problem with dryer timer? Or washer timing kicking back on?
It's not your heating element. Your venting system is clogged. Like mine was. You'll need to take care of this ASAP and from then on at least once a year. It is a fire hazard. Not only that if left this way It can kill your heating element.
"Steam drying will get how but the air that comes later to actually dry is cold so the clothes never dry"
I am assuming "how" means hot in this sentence, if so, I think I can help! There is no "steam drying" phase for your dryer so what is probably happening is; the wet clothes are being heated properly [as a result causing steam] however if this steam does not escape frum the dryer it will simply condense back onto the clothing [leaving them moist/wet].
Check your flexible tube from the dryer and the vent on the outside of your home to make sure they are unobstructed. Hope this helps!
