If i use 110 power all the time, will i ruin the battery.
    Scholar:
  • 137 Answers
I assume you are talking about a laptop. It's a good idea to use the battery until you get a low battery warning once a month. This will cycle the chemistry in the battery and help it to last longer.
Posted on Sep 30, 2010
How to Save my Laptop Battery?
Charge battery fully (with laptop off) then unplug AC power. Do not continuously have power plugged in. This will ruin your battery. Remove battery when not in use for long periods. To refresh battery charge fully then run laptop till it turns off. Turn on again and wait for it to turn off. When laptop wont turn on, charge battery fully again and repeat process about 3 times. This should extend an old battery's run time.
Oct 18, 2016 | Computers & Internet
When i turn on my dell 110 mini the light goes from white to orange and stays there the screen doeset boot or anything
Remove battery, open the access panel on the bottom carefully remove the ram sticks. Put them safely on a piece of paper so that a static charge doesn't ruin them, also touch something metal before you try and remove. If your computer doesn't beep at all when you power it back on your CPU, GPU, or MB are bad. If it beeps then there is still hope.
Jun 10, 2011 | HP Mini 110-1037NR Netbook
Its a water pump for our house and barn pumps probably close to 300 to 400 gallons a day over the course of the day was wondering if it is wired for 220 if using it with 110 will ruin it
Unless the pump motor has provision on it specifically for running on 110, then yes, running a 220 motor on 110 will ruin it. It will cause the motor to overheat, if you can get it to work at all. Some 220 motors are designed so that you can run them on 110. If yours is, it should have instructions and a wiring diagram for that. Even if it IS designed for 110 or 220, running it on 110 WILL cause it to run hotter, and will shorten its life.
Mar 04, 2011 | Plumbing
I purchased the Easy Share M580 Digital Camera with the battery charger for the KLIC-7006 battery-also included. I am taking a trip to Europe starting in Stockholm, Sweden - cruising the Baltic Sea to...
The charger should be 110 v ~ 220 v (it should be in the fine print on the charger itself). If it includes 220 v then you will not need a converter. If it only states 110 v, without stating 220v, then you will need a converter. In either case, you should have no issue finding the adapter or the converter in any ma and pa hardware store after arriving to the country you're visiting.
The battery life depends on the amount you're using the camera. It should last you a few days each full recharge.
Mar 01, 2011 | Kodak Easyshare M580 Digital Camera
Compaq Armada 110 works only, when AC adapter (PSU) is connected. I changed a new battery (refurbished) and now fully charged, but when unplug AC cable power will be lost. It was same behaviour with the...
OK, check the connection IN the laptop make sure they are actually making contact and are actually working. Now IF that is all in order, then I suspect, that your Battery Charger/Internal Power Supply, has faulted, the External and Internal supplies are separate, with exception for tap off to battery charger.
I have had this many times in my shop, you can most likely buy the Power supply sub board assembly and replace it.
Below is a service manual that will show you what to do and the part numbers. Most likely Ebay will be your best bet, or go straight to Compaq or Compaq dealer for the spare parts, or use the 'net.
http://www.eserviceinfo.com/index.php?what=search2&searchstring=Compaq+Armada+110
If you don't wish to DIY, then please get a "Quote" from a Compaq repair Centre
Oct 15, 2010 | Compaq Armada 110 Notebook
Our house circuit got hit with 230 volts and the dishwasher is dead. Is it ruined beyond repair? Thanks John
probably not. first check power going into unit with meter. 2 check wire black and white at the power box make sure your gettting 110. 3.if everything is correct check on and off switch,then checkpower to the module .that will do it .let me know how u made out.
Feb 25, 2010 | Dishwashers
Fixing camper heater
for the heater is not enough power from the 12v battery,becouse it needs 110 or more v becouse the heaters need alot of power for it to work
Aug 21, 2009 | 1986 Volkswagen Wagon Camper
Will my Logitech X-230 speakers work in a country with 220-240 V power outlets or would i need an adapter to use them there? If i connect them directly to the 240 V outlet, will they run properly or would...
Check the back of your sub to check your voltage range. You will see something like this: 110V-120V or 110V-220V. If you see the later, you are ready to go. If you see 110-120V only, you will need a power converter to power your speakers as well as any other 110-120V equipment. But no matter what, if it is 110-120V DO NOT PLUG DIRECT TO 220V!! It will blow your speakers. (I lived in Germany for 11 years.)
Aug 12, 2009 | Logitech Z-2300 Computer Speakers
It want switch on
My Compaq Armada 110 does the same thing from time to time. Most of the time, the best way to have it power back on:
Unplug it. Pull the battery out. Plug it back in without the battery. if you get a light flashing to the left of the top section above the keyboard, you're set. put the battery back in and power it on. if still no flashing light then next:
unplug the unit, pull the battery, flip the unit upsidedown and open the panel with the two screws to the right. reseat the memory modules in the sockets there. then reassemble, the plug the unit in without the battery. if you see the light, then put the battery back in and you're set. power it on.
if it still doesn't power on, i've got other suggestions but these are the main things I have to do to get mine working. :)
Nov 26, 2008 | Compaq Armada 110 Notebook
Computers & Internet Logo
David Payne
David Payne
