Question about Casio FX-9750GPlus Calculator
How do I do e^(0.2)? When I enter e^(0.2) I get Syn ERROR.
  • Casio Master
  • 7,993 Answers
  1. Press [2nd][LN] to activate the exponential function.
  2. Type in the exponent 0.2
  3. Press [EXE]
[2nd][LN]0.2[EXE] Result is 1.221452758
DO NOT PRESS [^] : this is the source of the syntax error.
You can put the exponent in parentheses.
If exponent is negative, press the change sign key (-) right after the e appears on screen.
[2nd][LN][(-)]0.2 [EXE] gives 0.8187307531
Posted on Sep 30, 2010
  • lsdoida
    lsdoida Mar 15, 2013
    Saved my life! Thanks a looot!
  • k24674 Mar 15, 2013
    Glad it was of some help to you.
Square roots doesn't work
Two ways the calculator may work:
Enter a positive number then press the square root key, or
Press the square root key then type in a positive number and press =.
Feb 09, 2016 | Texas Instruments TI-15 Calculator
Im trying to graph a parametric equation and whenever the equation has an exponent/power in it the calculator says Syn error so i know how to graph x=2 cos T, y=2 sin T and similar equations without a...
To enter powers of trigonometric functions you must enclose the functions in parentheses and then apply the exponent to the whole. For example X1t =(sin T)^3 , Y1t=(cos T)^3 will give you a shape similar to a rhombus with concave sides. The symbol ^syands for the operation of raising to a power. The key is the one with the caret symbol ^ , and it is wedged between the xsqure and EXIT keys (third row of keys).
As regards the cotangent, use the equivalent definition cot(X)=1/tan(X).
Jul 26, 2011 | Casio FX-9750GPlus Calculator
Have a Toshiba 500GB external hard drive, model: HDDR500E03X and I've been using it for some time on a few of my computers, but lately it hasnt been displaying. I dont know much about Ubuntu to begin...
Sounds like some kind of bad wire, you hope. It could be a power issue as you have stated, I would try it out on several diffrent computers, and you were not wrong in trying the y cable. But if that still doesnt work then not all is lost. I would recomend opening up the caseing and removing the hard drive. Even external drives simply use standard laptop SATA drives. If you have a desktop you can simply plug in the drive while your computer is off, if you do not have xtra spots to plug it up you could temp unpulg your dvd drive to test it. If you have a laptop than you can buy several devices to use a sata drive though usb. http://www.newegg.com/Product/Product.aspx?Item=N82E16817153071&cm_re=usb_sata_docking_station-_-17-153-071-_-Product
This is the one I use the most.
Good luck , if you have any questions let me know
Prodigz2
Mar 12, 2011 | Toshiba HDDR500E04XL 500 GB USB Hard Drive
Trying to draw graph, what does syn error mean? I
Here is a screen capture to help you pinpoint the location of the error.
Apr 26, 2010 | Casio FX-7400G Plus Calculator
Square Root
Don't forget to close the parentheses.
To compute the square root of 2, press SQRT 2 ) ENTER
Mar 09, 2010 | Texas Instruments TI-15 Explorer...
SYN packet for established connection
Check the "TCP end timeout" setting. You can find in Policy -> Global
Properties -> Stateful Inspestion. FW-1 will take a connection out of
its established connections table after two FIN packets (one from each
party) or a RST packet + the time defined in this setting.
Have a great day,
Bhautesh
Feb 18, 2010 | Nokia IP 440 Firewall
Im not sure how to put the formula 4 sin squared x 60 into my casio fx-83wa calculator it keeps saying syn error please help
You should know that you cannot enter something like sin^2(x) as you would by hand. So you must use parentheses: ( sin(x) )^2. If you do that there is no ambiguity. The calculator evaluates the sine because parentheses are evaluated first, then it takes the square.
So 4[x][(] [SIN][(] 60 [)] [)] [Xto the 2] [=] result is 3/
Since you do not say what model you use, what I entered may not be appropriate: the parentheses inside the sine function may not be needed. In the new Casio the first parenthesis inside the sine is supplied by calculator, but the closing one must be entered by the user.
Hope it helps
Sep 17, 2009 | Casio Office Equipment & Supplies
TI-15 square root Function
You should enter it as follows [SQRT]36 ) [ENTER/=].
If you define some function f of a variable x you write that f(x), where the parentheses enclose the so-called argument (objet on wich the function acts). It seems that on this calculator the opening parenthesis is implicit: the calculator supplies it when you press [SQRT] but does not display it (a design flaw?). However the closing parenthesis must be entered by you to signifie to the function [SQRT] that you have finished entering the argument. Weird but one can live with it.
Hope it helps.
Oct 19, 2008 | Texas Instruments TI-15 Explorer...
Unable to syn music
uninstall itunes the go to the apple website (u can google it) or the cd your music will automaticaly go onto your new itunes libary and it will sync
the same pro happened and my ipod nano and it worked for me
Mar 14, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Series - Syn Error
The clock on either your Jornada or the desktop PC is set wrong. Either one of them is in the wrong time zone, or more likely, one of them is not set to compensate for daylight savings time. Good luck,
Sep 12, 2005 | HP Jornada 565 Pocket PC
Casio FX-9750GPlus Calculator Logo
193 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
