Question about Samsung HL-P5063W 50" Rear Projection HDTV
Hlp 5063w on off front button flashing lamp then stanby..hear sound no picture.. shuts off then comes on.
  • Samsung Master
  • 5,188 Answers
If the lamp and standby lights are both flashing and the timer light is off, check that the lamp cover on the back of the TV is properly positioned in the groove and secured by the screw. Take it off and check that the screws that hold the lamp itself are secure. There is an safety feature that keeps the lamp from turning on when the lamp cover is off.
If the three lights (timer, lamp, and standby) are blinking, then the lamp needs to be replaced. If the timer and standby lights are blinking and the lamp light is off, then a cooling fan isn't working. When only the standby light is blinking and the other lights are off, the unit is overheating and a ventilation area may be blocked.
I hope this helps.
Posted on Sep 30, 2010
Samsung hlp-5063w no picture when its on
Do you have three flashing lights on the front? You most likely have a problem with your lamp or color wheel. Those two component combined are pretty much the guts of your TV. If you are handy, you can replace those parts yourself. I have a 50" Samsung DLP and I've already replaced those to items myself. Otherwise, you can contact Samsung at 1-800-SAMSUNG and they can assist.
I bought my parts using Amazon, had them shipped to me, and took an afternoon to take about the back of the TV; documenting everything and taking photos of the progress, until it was done. There may be video tutorials on Youtube. There was for my model (HLS5086). Here is a great link to help you along. Good luck.
http://blog.trebacz.com/2011/01/50-samsung-dlp-hl-p5063w-with-3.html
Nov 19, 2013 | Televison & Video
Model 5063W - loud noise
The picture is pink, that would point more toward the color wheel, and you can see the fan through the vents in the back and you can go from there. It sounds more like the color wheel since you have a picture malfunction.
Jun 24, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
No picture, no sound, power button blinks 47 times, then lamp flashes 134 times, then shuts off
It is symptom of weak Lamp in your TV, replace Lamp with following part number..
A1606034B LAMP BLOCK XL-2100U
It is available in Sony Accessories for $200
Always buy Sony Original Lamp for your Sony TV and avoid aftermarket/ cheap lamps.
Apr 22, 2009 | Televison & Video
Samsung hlp 5063w humming noise
Can you reseat the lamp?  Don't forget to unplug the TV of course, but sometimes the connection between the lamp and TV degrade due to heat contraction and cooling.  Some TV's provide an error code by having LED's flash a certain way, is this what you mean by lights flashing?
Mar 24, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Replacement of bulb for my HLP 5674 WX/XAA
sounds like your lamp is needing to be replaced. www.alltvlamps.com will have the lamp for your set just enter the model number of your Tv to locate it.
May 20, 2008 | Samsung HCN473W 47" Rear Projection...
Turning On Problem
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Feb 06, 2008 | Samsung HLN467W 46" Rear Projection HDTV
Samsung HLP 5063WX Sound but no picture
Carloes, You need to open the lamp housing door and take the lamp tray assembly out to visually inspect the lamp itself... If the lamp is blown it will be obvious and replacing it should restore normal operation. A shop can do this on a single home visit. The second part of your question has to do with the unit cycling (turning on/off a couple of times) This is because the lamp detection circuit is finding no load on the lamp circuit. Light is not lighting - - - Tv shuts down. This is merely a protection from causing other damage or more damage. The circuit doesn't know why there is no load volatge just that there is none. Good Luck Bill
May 31, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HL-P5063W 50" Rear Projection HDTV Logo
1,019 people viewed this question
Henry  Thomas
Henry Thomas
