Question about Samsung LNT4066F 40 in. LCD Television
Turn on TV, blue light powers up but screen does not power on. turn off and back on a few times and screen eventually powers on. also get occasional light purple dots scattered about screen. disappears if turn off and then back on. what gives?
  • 11,361 Answers
I t may have dying power supply module due to bad caps with bulging/leaking top/seal. That will be the first place to look.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Sep 30, 2010
When turning on the tv by either remote or switch on side screen will flash blue then turn off. Have unplugged tv still won't turn on.
Search Results
    Samsung TV Keeps Shutting Down - Forums - CNET
    www.cnet.com > Forums > Samsung
    CNETWhen I turn the TV on for the first time each day it shuts itself off within 30 ... There is ablue kill switch there, but you don't want to fool with that. .... The tv will not turn offwith the remote or the side buttons on the tv. .... I replaced the lamp but the tv screen will have a momentary flash of light on the screen then it will turn on and ...
    Philips/Magnavox Tv Problems ? - Home Forums
    ths.gardenweb.com > Home Forums > Electronics
    Mar 26, 2005 - I turned the tv on then off a few tims then eventually the piture would come on. .... time, the LED will flash continuously along with the volume going up to max. ...... You can use the remote to turn the tv off and on but nothing else. ... If you press the power button over and over it stays on a blue screen but as ...
    Top 208 Complaints and Reviews about Akai ' Page 3
    www.consumeraffairs.com > Electronics > Televisions
    Rating: 1.9 - ‎37 votes
    The screen will not turn on with the remote, side switch or rocker arm. .... It will flash for a second and the blue Akai screen will display very briefly, but then .... Akai LCT3201AD TV does not turn on using either remote or power button. ... I turned itoff one night and the next time I turned it on, the green light came on, but it did ...
    Get help with audio, video, or power on Apple TV - Apple ...
    https://support.apple.com/en-us/HT200197
    Apple
Jan 28, 2016 | Televison & Video
My Dynex 32" LCD tv seems to turn on and off
The blue light merely indicates that power is getting to your TV. It has internal power supply problems.
Nov 30, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
When i turn tv on, visio 37" 64hz 1080p HDTV, it
The Vizio 1080P HDTV offers a variety of features and input jacks that make it a true multimedia centerpiece. Occasionally, however, there are a few scenarios in which the screen blacks out.
  1. Basic
    • Verify that all input cables and your power cord are firmly inserted. If you are viewing a program that utilizes RGB (red, green, blue) or HDMI cables, be certain your TV is not in sleep mode. It will time out and appear blacked out in this case. Verify your sleep timer hasn't been turned on. Try resetting the TV by turning it off for 30 minutes.
    Advanced
    • If you experience limited or no lights, the power supply is likely failing. If you feel comfortable doing so, open the back of the TV and look at the power supply area (shock hazard). Follow the power cord area to find it. Check for bad capacitors, which look like small batteries with connectors soldered to the board. They will be blown or bulged out. Replace them or the complete power supply.
    Other Considerations
    • Verify your surge suppressor is not bad. These often have a connected equipment guarantee that covers your repair if a power surge caused failure. You can reset all settings to original modes by pressing "Reset All Settings " in the Setup menu.
Oct 05, 2011 | Vizio VX37L Television
Red dots across the screen
Please check the power supply board, if there is any Pup-Up electrolytic capacitors, please replace them.
May 25, 2017 | Samsung LN-T4665F 46 in. LCD Television
Tv turns off, volume adjusts incrementally then shuts off, screen is tinted blue
there is a defecton the small signal panel. most of the time caused by power surge..john
Aug 30, 2007 | Insignia IS-LCDTV32 32 in. Television
Tv screen goes black for a few seconds
do you get sound while screen does black? what do you mean by "until eventually it has turned black and will not come back"? is it black from the minute you turn the tv on untill you turn it off? if sound is good but picture is black, it may be the resault of a fried monitor tube, in this case replacement will cost alot. if sound is dead also, them it is probobly power supply related issue. get out your DMM and measure the voltages in the power supply. When the screen goes black, is there still regulated B+ going to the circuitry? Do you still have HV? Is the filament of the CRT lit? Does the set still have a raster (you may have temporarily increase the screen setting to see it)? Do you measure any of the flyback derived B+ voltages that go to the video processing, tuner, Vertical Deflection, and other circuitry?
Mar 19, 2006 | Samsung TXD1972 19" TV
Samsung LNT4066F 40 in. LCD Television Logo
187 people viewed this question
Henry  Thomas
Henry Thomas
