Question about GE WSXH208A Front Load Washer
Water is not draining from the tub. the hose is not kinked and i've tried advancing the timer. My roomate took his clothes out and handwrung them. Since then I've added some sheets to the water that was left in the tub and started the cycle over. The tub is spinning, but no new water is coming in and the old is not draining out, Do you have any ideas?
    Sergeant:
    Champion:
  • 351 Answers
The drain pump is not working i don think this washer has a pump strainer if it dose it behind the lower front panel
Posted on Sep 30, 2010
  • nsforster Dec 31, 2010
    how do you remove the front panel? I cannot seem to find any screws and it does not pull off.
  • MSgt-OBX Jan 16, 2011
    I have a GE Adore Front loader and had the same "not draining" problem. I looked around on the web and saw that the lower front panel is removable and that there is a filter there. I drained all of the water from the machine through the filter and found the following items in there. $2.34 in small coins, enough denim lint and fuzz to make 3 more pair and a wrench (yes, a wrench)-after clearing this out, low and behold, it drains like brand new!
  • 4 Answers
These are Frigidaire built machines and NOT very reliable at that... : ) Anyway, I would guess a bad pump to start with... very likely though it could also be the control board itself... I WOULD NOT spend a ton of money getting this fixed unless you have a sentimental attachment to it... (ha ha)... Good Luck and hope this helps!!
Unit acts like it has received water then continues to cycle as if it hasn't, no water is pumped???
Symptom Check
Click on underlined items for further information Washer does not work and makes no noise Washer does not work but it does make noise No water is entering the wash tub
- or no hot water
- or no cold water The water fills the wash tub too slowly The tub does not fill with enough water
  • Test the water level switch
  • Check that the drain hose is positioned roughly as high as the top of the inner tub
The water overflows the wash tub Water drains out during the wash or rinse cycle
  • Check the drain control lever
  • Test the drain control coils
  • Check the cam bar
  • Test the timer control
Wrong temperature of water is used
  • Water supply hoses may be reversed
  • Hot or cold water supply valve may be turned off
  • Water supply hose may be kinked
  • Check water inlet valve
Water drains out while it is filling
  • Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  • The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  • Check the cam bar
Water drips into the wash tub when the washer is off Water does not drain out of the wash tub Water is leaking onto the ground
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
Agitator does not move Agitator movement is weak or moves in only one direction
  • Inspect the agitator
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the pump coupling
Drum does not spin
  • Test the lid switch
  • Test the centrifugal switch
  • Test the motor
Clothes are too wet after spin cycle This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
Spin:
  • Test the motor
Cycle does not advance
  • If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  • If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  • If the timer does not advance during the rinse cycle, check whether water has filled the tub, if not, it is likely cold water related. Check the cold water supply valve, check the supply hose for kinks, check the filter screen and check the water inlet valve
Burning or electrical smell
  • Unplug the washer
  • Locate the source of the odor then read the instructions in the related section
Foul or stale odor coming from washer or clothes
  • Check that the drain line is clear
  • Check the drain hose for kinks or blockages
  • Check pump for blockages
  • Check for build up of soap in the outer tub
  • Check for article of clothing stuck in the outer tub
Noisy or vibrates too much
  • General tips
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Goes out of balance too often Clothing is damaged
  • Inspect agitator for cracks or rough spots
  • Inspect for rust spots
Jul 11, 2015 | Washing Machines
Flashing LD on panel and beeping cabrio top loader washing machine
Ld Long drain Clogged/slow drain/pump
"LD" stands for "long drain," meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I've even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the "LD" error code springs forth from such anomalies.
Hope helps.
May 18, 2011 | Washing Machines
GE dishwasher won't spin
Hi...
You need to check this parts.
Inspect the drain hose for kinks
Test the lid switch(some models)
Inspect the driver belt(belt drive only)
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Hope it will help you.
Regards
ICmanServer
Aug 12, 2009 | GE 24 in. Profile PDW7800 Built-in...
GE WPGT9350 won't drain
Hi...
Regards
ICmanServer
Aug 09, 2009 | GE Profile WPRE6100G Top Load Washer
Don't spin
Hi...
Regards
ICmanServer
Aug 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
FTW445ges2 Washer won't drain, buzzes during drain cycle
Hi...
Regards
ICmanServer
Aug 01, 2009 | Frigidaire GLTF2940ES Front Load Washer
Maytag washer will not cycle.
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jul 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
GE Top Load Washer WLSR2000G3WW~smells like burning and wont drain
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Nov 06, 2008 | GE WBSR3140DW Top Load Washer
Front loead washer will not spin/rinse,
First, make sure that you do not overload the machine.
Sep 17, 2008 | Frigidaire ATF6000ES Front Load Washer
Maytag doesn't seem to rinse.
Try this. Run the machine set for full load, short wash. DO NOT put clothes or detergeants in the tub. Water only. Let the machine agitate for 1-2 minutes. Gently advance the timer manually untill it locks into spin. Let the machine continue to spin until it stops on its' own and begins to refill. At this point lift the lid and see if there is any access water in the tub.
Most of the time this condition is caused by a blackage in the drain line. Make sure the drain hose is not kinked in any way.
Also, there are times when I've had to removes socks and other objects from the tub to pump hose. It only take a 10% block to cause the machine to retain water.
Nov 20, 2007 | Maytag SAV515DE Top Load Washer
GE WSXH208A Front Load Washer Logo
858 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
