Question about Famous Trails Ariel FT300 Monocular
Push botton on top does not work,and battery is good,sat in my love chest for 3 yrs.,what is the problem with it.
Lock botton unlocks the door and unlock botton locks it. When I put the code in it unlocks it and when I push the lock botton it unlocks it
I have installed your Powerbolt, but when I push the Lock Button, it unlocks? What should I do? First remove the cover on the inside of the Powerbolt unit. On the right hand side under the batteries, you will notice that is says "Door Direction Jumper". If the cap is mounted on Prongs 1 & 2, carefully remove it and move it over so that it mounts Prongs 2 & 3. A is right handed, B is left handed.
Good luck--and please provide feedback if this helps!
Oct 09, 2011 | Weiser Lock Powerbolt 1000 Lock
Won't run!
have the fault codes read to determine the problem sensors
Jun 04, 2017 | Fisher Price Power Wheels Cadillac...
Frigidaire, chest freezer only 2 or 3 yrs old, was...
See if you have 120 volts at the compressor if you do do you hear any clicking sound at compressor if not replace compressor Start Relay/Overload if you hear clicking sound the compressor may be bad or Start Relay/Overload the only way to know is to replace the compressor Start Relay/Overload. If you do not have 120 volts at the compressor jump out the thermostat you should have 120 volts at the compressor now if not you may have a defrost timer Prob. if this is shelf defrost unit check timer turn knob to see if it starts.
May 19, 2010 | Frigidaire 12.8 cu. ft. Chest Freezer...
How do I enable my EFX 544 to give my heart rate while wearing my polar heart rate chest strap?
If the EFX 544 has polar Heart Rate attach to the upper electronics your chest strap should be transmitting and the unit should be receiving. If your chest strap is more than 3 yrs old usually the battery will die and needs to be replaced or you have a defective receiver and will have to be replaced
May 17, 2010 | Precor C956i Treadmills with HR /...
MY BIKE HAVED GOOD CHARGE , IM PUSH START BOTTON,
check you starter is working, to activate starter touch a wire from the battery to terminal on starter ,starter should turn..
Dec 21, 2009 | 1986 kawasaki ZL 900 A2 Eliminator
K my 86 ford ranger has sat for 3 yrs and im tryin to fix it but when i try to jump it my cylinoid and all my rekay switches click is something grounding out or is it my cylinoid
Clean the battery connections for good contact and that the battery is well charged (should read 12.6 volts without the engine running).
Sep 07, 2009 | 1986 Ford Ranger 2WD
1985 ford ranger
fuel cutoff swicht you probably hit a pothole look on the passager side kick panel scare switch botton on top push it you gonna ear a click noise that it it should start or you can have corroded wire thanks for using fixya pierre
Mar 07, 2008 | Car Audio & Video
Triax CV10
Nike Triax CV10 - Successful HRM reset 7 November 2008
I had real problems too. Even after repeatedly following the known reset steps everyone else is posting up. Here’s how I got mine going, please forgive the mind bogglingly tedious detail…
First make sure you’re using new good quality batteries. I used Maxell’s, bought in 10’s from Hong Kong on ebay – no problem.
Second, and this is the ESSENTIAL bit…move right away from the computer and any other electromagnetic sources before carrying out the known reset…
Third, follow the known reset steps below, adjusted to what worked for me…
If you press all four buttons of your Nike HRM it will reset. Next time you go to "RUN" mode, it will show "HRM LINK" error. You will now need to "hard reset" the unit.
Nike made a late change to add a "hard reset" to the chest strap. To re-link (re-initialise) the watch you'll need to open the battery door on the chest strap, and use a paper clip (or the equivalent) to push the small gold button in the battery area. There should be a small sticker in the battery compartment that points to the reset button.
The re-initialisation steps for the Nike C10 and CV10 digital HRM's is:
(1) reset the watch
(2) open the battery door on the chest strap
(3) move the watch to RUN mode
(4) press the reset button in the chest strap battery area without removing the battery
Tip - I agree with the suggestion to use a pin or needle and definitely do it with the battery in the hrm.
Tip – Thumb holds battery to stop it from pinging out, other hand performs jiggle with pin until the link is made (it links straightaway if you jiggle it just right!)
(5) replace chest strap battery cover…and smile!
Nov 30, 2006 | Nike Triax CV10 Wrist Watch
Can Link watch with Heart Monitor
If you can't link the hrm do as detailed in the following link If you press all four buttons of your Nike HRM it will reset. Next time you go to "RUN" mode, it will show "HRM LINK" error. You will now need to "hard reset" the unit. Nike made a late change to add a "hard reset" to the chest strap. To re-link (re-initialise) the watch you'll need to open the battery door on the chest strap, and use a paper clip (or the equivalent) to push the small gold button in the battery area. There should be a small sticker in the battery compartment that points to the reset button. The re-initialisation steps for the Nike C10 and CV10 digital HRM's is: (1) reset the watch (2) open the battery door on the chest strap (3) move the watch to RUN mode (4) press the reset button in the chest strap battery area (5) put the battery back in the chest strap (if it's not already in - it's possible to push the button without removing the battery) (6) hold both of the electrode to create a signal (probably not necessary - it usually links immediately). My suggestion is to use a very thin needle and do it with the battery in the hrm. Eventually, Nike will either eliminate the hard reset or update the manual to include this info.
Sep 16, 2006 | Nike Triax CV10 Wrist Watch
Famous Trails Ariel FT300 Monocular Logo
73 people viewed this question
Top Famous Trails Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Famous Trails Optic Expert? Answer questions, earn points and help others
