Question about RCA TH1101 MP3 Player
RCA MP3 TH1100A Charge Problem
The unit is plugged into my USB port, but when I disconnect it to use, the screen continually reads Low Battery Shut Down and cannot be used. My player is model TH1100A.
  • 8,596 Answers
Get the firmware upgrade first. If that fails, Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If that fails, the Mp3 player has a hardware issue and needs to be replaced - call RCA.
-Tha Mp3 Doctor
Posted on May 26, 2008
SanDisk Sansa Express 2 GB MP3 Player (Black), battery status states 14% critically low....what does it mean and what actions should I suppose to do?
You need to charge the battery so you can continue playing your MP3player.
Connect the supplied USB cable into the player and then plug it into the USB port of your computer. The computer will charge up the MP3 player and you can also copy mp3 music and photos etc to the MP3 player.
Aug 25, 2011 | SanDisk Audio Players & Recorders
I shut down the computer while charging my mp3
Try plugging in the USB connection again. If that doesn't work, unplug it and then press and hold the on button for ten seconds.
May 06, 2010 | SanDisk Sansa e250 MP3 Player
I have been trying to recharge the unit as I typically do by connecting it to my compu but the battery is still low. I read in the manual that this unit might need a new battery, if so, where can I buy...
You could try say Ebay... or the like.
You cannot usually charge a totally flat, or even a half flat battery from the USB port. These are on;y used to "Top UP" the battery... You need to replace it with a fully charged one,and then us the USB to keep it fully charged.
Jan 29, 2010 | RCA OPAL M4001 MP3 Player
I have a 30g Zune which has not been holding a charge for a couple of weeks. This morning the Zune powers up and then shuts off (even while plugged in). I tried the 'hold down the back button and up at the...
I am not sure if this is gonna work but, since you've tried all other steps why dont we give this a try too...LOL :-)
To troubleshoot this issue, try one or more of the following methods in the order in which they are listed:
  1. Let your Zune device charge for 30 minutes, then disconnect and reconnect the cable to turn on the player. It can take up to 3 hours to fully charge.
  2. Connect the Zune device to a different USB port on the computer. Use a USB port on the back of the computer. Do not use a USB hub.
  3. Use another supported high power source, such as an Xbox 360 console, a Zune AC Adapter, a Zune Car Charger, or a Zune FM Transmitter/Charger.
    Note These devices are sold separately.
  4. If you are connecting your Zune device to a mobile computer, make sure that the mobile computer is plugged in and is not running on battery power. Many mobile computers are configured to conserve power when they are running on battery power to extend battery life. This behavior may affect Zune device charging.
  5. If the Zune device is charging slowly, be aware that, for optimal charging, the Zune device requires at least 500 milliamps (mA) of power. Frequently, USB ports that are located on the front of a computer and on some USB hubs are low-power, 100-mA ports. Typically, the high-power, 500-mA USB ports are on the back of the computer. Additionally, when you suspend the computer or put the computer to sleep, high-power USB ports may be switched to low-power, 100 mA mode.
  6. If the device boots to the home screen but is still not charging correctly, continue with the "Home screen is displayed" steps in the following section.
    If the device continues to display the full-screen charging icon, continue with "Full-screen charging icon is displayed."
  7. If the battery in the device still does not charge correctly, visit the following Web site to sign in and register your device: http://service.zune.net (http://service.zune.net)
    At this Web site, you can submit a request for service if your device qualifies for service.
Dec 24, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
RCA M4304 mp3 player wont charge even when plugged in
As long as your computer can see the player, it is likely the firmware has gotten corruped.
First, connect your player and back up any important media items that are on it.
Next, download and run the firmware installer from the RCA website:
http://voxrightnow.custhelp.com/app/answers/detail/a_id/5635
Nov 08, 2009 | RCA M4304 Digital Media Player
Charging difficulty
go get a new one that one is busted
Jan 14, 2009 | RCA OPAL M4001 MP3 Player
My rca opal mp3 m4204 4gb is not recognized by my computer
Try plugging it on an another computer. Maybe the USB port is in problem if it cannot powers up the player.
Jan 11, 2009 | RCA M4204 MP3 Player
RCA M4002 mp3 does not turn on.
Download the latest firmware upgrade from www.rcaopal.com to restore the player. The firmware upgrade file will be on the "Download Upgrades" section of the website.
-Tha Mp3 Doctor
Dec 27, 2008 | RCA OPAL M4001 MP3 Player
I dont have driver 4 RCA TH1100A
Hello likeapimp,
Both the TH1100 and TH1101 require Windows 2000 (Service Pack 3), Windows XP
(Service Pack 1 or higher) or Windows Vista. All of these OS's will recognize the players without you installing any drivers.
Jan 04, 2008 | RCA TH1101 MP3 Player
RCA stands for Really Crappy Appliance!!
yeah you have to slide the power button and hold it for awhile.
Sep 09, 2007 | RCA TH1101 MP3 Player
RCA TH1101 MP3 Player Logo
69 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
