Question about Maytag Heating & Cooling
Fan does not run on high speed . - Maytag Heating & Cooling
  • 382 Answers
Dear sir
if you how know to read a electric tester then check you air con,s selector switch please find out the fan motor wire in selector switch and test one by one and turn to fan on high speed mode and check on selector switch there electric supply comes on selector switch if it,s come and motor doesn't work then it,s mean motor high speed is defective if supply not come on selector switch then it,s mean selector swith is faulty .
if you can check like this then do if not then contact to a technician,
thank you
hope answer the question
please vote1
Posted on Oct 01, 2010
Fan is not working on 2001 Chevy Silverado 2500 truck radiator fan motor?
The engine cooling fan system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the powertrain control module (PCM) to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood fuse block.
During low speed operation, the PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the low speed fan relay coil, closes the relay contacts, and supplies battery positive voltage from the low fan fuse through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan s/p relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. After a 3 second delay, the PCM supplies a ground path for the high speed fan relay and the cooling fan s/p relay through the high speed cooling fan relay control circuit. This energizes the cooling fan s/p relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the high speed fan relay coil is energized closing the relay contacts and provides battery positive voltage from the high fan fuse on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have there own ground path. The result is a parallel circuit with both fans running at high speed.
Your best bet would be to take your vehicle to a qualified repair shop !
Relay Driven Dual Cooling Fan Diagnostics
Aug 19, 2016 | 2001 Chevrolet Silverado 2500
3 speed fan barely changes speed
You are talking about your blower fan for the air conditioner and heater right? More information will be needed to solve the problem.
When you say it barely changes speeds, does that mean it doesnt speed up, or doesnt slow down? By that I mean, is it "stuck" on low, or high?
Most blower fans run at different speeds through the use of a multi-stage resistor built into the fan switch circuit. Low speed is a high value resistor, medium speed is a low value one, and high speed is the fan running without any resistance.
If your fan is running on high and doesnt seem to want to run on lower speeds, the resistor pack may be failing. If the fan is running on low speed only, it may be that the fan itself is beginning to fail, or that the lubricant in it has gotten gummy.
Dec 07, 2015 | Cars & Trucks
Cooling fan motor gets hot when running high speed why
Check the bearings. If the friction is high the fan will not run at rated speed. When it runs slower it uses more current and gets hotter...
Disassemble, clean and lubricate to make sure fan runs full blast and does not burn out.
Or if the fan has two windings, one for starting and one for running it is possible that the high speed run winding has some shorts in it resulting in more current and more heat.
Oct 13, 2015 | Cars & Trucks
My 1998 lexus e300 is running hot and I noticed the cooling fans are both running but at low speed. what controls the fan speed
The PCM(computer) controls the fan speed. Low speed comes on around 200 degrees, high speed kicks on at around 225 degrees. If they come on when you first start the engine, the coolant sensor is bad. PCM is in default mode and runs the fans all the time. Since it doesn't read the 225 mark, it won't kick on the high speed. Turning on the A/C will also kick on the high speed fans. That's if your A/C works.
Jun 21, 2015 | Lexus Cars & Trucks
My ac is not working I have a Chevy Tahoe 2005 the fans won't turn on either .
Hi Maria , The A/C system wouldn't keep the fans from running but none working cooling fans will keep the A/C from working ! This is a fairly complex system if your not familiar with this sort of thing ! I will add the description from the factory service manual.
Cooling Fan Control - Two Fan System
Do you have a check engine light lit ? The thing to do would have it check at the dealer or a ASE certified repair facility ! They could hook up a advanced scan tool an diagnose fairly quick ! Or you could find a wiring diagram an try testing with a volt meter yourself ! But watch yourself so you don't short out the PCM - engine computer !
May 01, 2015 | AC Cars & Trucks
Fan only runs on high speed
Wild guess the fan was replaced with a one speed motor. Or the selector switch is bad or not connected. Or the relay/s for other speeds are not getting thermostat signal for some reason.
Mar 12, 2015 | Heating & Cooling
Kenmore over the stove microwave,model # 721.62629200,only low speed fan works on the keypad,no high speed fan.
The fan has a setting for high speed, low, and off. Fan only running at low speed.This indicates problem towards. 1) the fan motor. 2) The loose fan wiring. 3) The fan switch. IN the unit there is a motor for fan.If the motor gets weak or short. The fan will run but only at low speed.Because at high speed the motor will require more power to run.In this case motor needs to be checked and replaced. The other possibility is the fan wiring.There are two wires going from fan to motor and two going from motor to power board.If any of this wire is got loose or getting short then this will stop the fan to run in high speed.In this case the wires needs to be checked and reconnected properly. In the unit there is a switch internally.When you select the fan to high speed mode the switch goes up. when you select the fan to low speed mode the switch turns down.But if the switch is faulty or got worn out.Then it will not move properly up/down.In this case switch needs to be replaced.IN some brand models the High speed and low speed are directly controlled from front control panel.There is no switch in that models.In that case the control panel needs to be checked and replaced. Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Jun 10, 2010 | Kitchen Ranges
Fan will not run on high. Compressor runs fine but the fan will not run on high. Works fine on low and med.
It's the mode switch contactors for the high setting just overview the wiring of the high cool or high fan contactors if it's not there check all leads for the high fan or high cool circuitry.
Aug 01, 2009 | Coleman Mach III Air Conditioner
High cool not working
Compressors on these units runs at only one speed. The change to high cool is only a change in blower speed moving air faster over the cooling coil. I would have the running capacitor for the fan motor checked. A bad capacitor can cause your type of problem. The other problem could be that the high speed winding in the fan motor is bad. Try it operation in the fan only position through the two speeds. If it works in the low and high speed for fan only your problem could be in the selector switch.
Jun 23, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
