Question about Whirlpool Duet 7.0 Cu. Ft. Capacity Plus Electric Dryer
What about the drying time takes forever. I already replace the thermistor, its resistance test failed, I checked the vent lines, cleared all the vent from dryer up to the attic and finally I replaced the machine control electronics but it still takes forever to dry the clothes, even at manual drying, set at HI and set for 45 minutes. I could see the ignition and flame, but the flame only goes for 5 to 8 secs and stops, and 2 minutes later the flame goes up again for 5 to 8 secs. the whole time I check the ignitors and flame, it works good but for few seconds, is this normal? what is still there to replace? the high limit thermostat tested good as per the manual and so as the thermal fuse.
  • Whirlpool Master
  • 2,287 Answers
You still have a block somewhere.remove the duct that the lint filter slides into,make sure the outside vent is clear and blow out the vent line with a leaf blower,i told this to someone else and they blew a birds nest out of the line and they said the line was clear,also remove the t-stats on the blower wheel housing and check the back of them,sometimes lint and dust gets stuck on the back of them and they don't read right.if that looks fine change out the gas coils but i'd say you have a clog somewhere
Posted on Sep 30, 2010
  • 4 Answers
As crazy as it sounds this COULD be a problem with the gas valve. It MAY think that there is a pressure issue and then shuts itself down... Could also be the thermostat on the blower housing... that would be the first part I would replace EVEN if it ohm;s out ok... Hope this helps!! : )
I have a GE Profile DPVH880EJMG Dryer. It drys but shuts off before clothes are dry. It doesnt matter what sensory cycle it is on or time dry.
i SAY CHECK MOISTER SENSOR, CYCYLING THERMOSTATS? AND HI LIMIT THERMNOSTAT AS WELL AS THERMISTORS IF UR MODEL HAS THEM? UR REPAIR MAN SOUNDS LIKE A SHAM.
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or
overheating.
The heating elements are located inside the heater ducts. If you think a heating element is faulty, test it with avolt-ohm-multimeter (VOM)set to the RX1 scale. Disconnect the leads from the power terminals and clip one probe of the VOM to each terminal. The meter should read about 12 ohms. If the reading is higher ohms, the heater is faulty and should be replaced. Replace a faulty heater with a new one of the same type and electrical rating. A heater connected to a 115-volt line usually has an 8.4-ohm resistance; a heater connected to a 220-volt line usually has 11 ohms resistance.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
OR you may have a broken centrifugal switch in the motor because this switch activates the motor and the heater as well. supposed to be if the motor does not run , the heater should not heat in order not to create fire but if the motor is not running, and the heater is still heating, then there could be a problem with the motor centrifugal switch that is connected to this interlock switch that should trigger the heater.
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum 9 this is why in some cases the dryer will operate at lower cycles like gentle or low heat but not at higher settings?)
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :
http://www.ehow.com/info_12203962_check-dryer-thermistor.
GOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
How to Check Dryer Thermistor eHow
Dec 08, 2016 | GE Dryers
I have aaytag bravos dryer model med6400. The sensing light stays on noatter what and the clothes take forever to dry. Is this a thermostat or a blower problem or what
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Mar 16, 2015 | Dryers
How do I set timing to dry clothes for 1 hour?
overheating.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!!
Mar 03, 2015 | Dryers
Why is it taking two hours to dry a load of clothes in my new dryer tdv6w
overheating.
Oct 04, 2014 | Dryers
My danby dryer keeps shutting off and turning on and the clothes take forever to dry
GOD IS STILL GOOD !!!!
Sep 09, 2014 | Danby DCD5505W Electric Dryer
How do I repair an Amana dryer not heating?
overheating.
GOD IS still GOOD !!!!
Sep 05, 2014 | Amana Dryers
Dryer takes 2 cycles to dry
overheating.
Sep 04, 2014 | Dryers
Drier takes several run times to dry clothes
Hello.
When your dryer heats yet gives very poor drying results its usually always poor air flow that's causing it to take forever to dry the clothing.
To check to see why it has poor airflow the first thing to check is for a blocked or restricted vent tube from the back of the dryer all the way to where it exits the house. Also in some case lint is built up in the blower wheel/lint filter housing and that housing would need to taken apart and clean all the lint from it.
GENE
Oct 13, 2011 | Kenmore Elite HE4 Electric Dryer
The dryer is heating up but takes forever to dry clothes
first things first, check the vent. if the unit isnt vented properly or vent hose isn't clear, it will take forever to dry. if the vent is clear, check the vent thermostat.
Mar 21, 2011 | Dryers
T5 error code comes in my amana dryer ned 7200tw
That is actually a Ts error.
Thermistor Short Sensed
The Thermistor resistance is very low.
Check for:
- Clogged lint screen.
- Restricted vent system.
- Check Thermistor resistance.
Thermistor is Item #27 HERE
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 06, 2010 | Amana NED7200TW Electric Dryer
Whirlpool Duet 7.0 Cu. Ft. Capacity Plus Electric Dryer Logo
222 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
