My gotech dvd player seems to be playing only the visual part of a dvd and no audio.
SOURCE: No Audio when playing back certain DVD's???? HELP!!!!
Install AC3Filter ,This has solved many problems relating to sound http://prdownloads.sourceforge.net/ac3filter/ac3filter_0_70b.exe?download - binary http://prdownloads.sourceforge.net/ac3filter/ac3filter_0_70b_src.zip?download -
Posted on Sep 05, 2007
  • 85 Answers
SOURCE: TreTech TT320 dvd player will NOT turn on
The fuse is usually blown when this happens. If you know how to find the fuse and replace it this should give you power on again. If this doesn't help then you may have had power surge and just blew the mother board. If this is the case then you may just need to get a new one for they are really priced low now.
Posted on Jan 08, 2009
likha
  • 790 Answers
SOURCE: Pictue but no audio on VHS playback..VHS record to DVD visual/no
Hi
please check the format settings, maybe the audio is not in good settiongs!~
Thanks!
Posted on Feb 01, 2009
SOURCE: repair dvd player dual audio
DVD / CD plastic housing breaks wear spring holds metal top pad to align CD /DVD on drive engine pad, most common problem.
Posted on Mar 11, 2009
  • 3 Answers
SOURCE: Have just connected a set
wat inda set sir
Posted on Dec 28, 2009
Picture or sound will not come on while disc is playing
Think has other dvd players worked before on that tv. If so then has anything about the current dvd player changed such as the yellow red white cord? If so changing the old one back will help. The dvd player r/y/w jacks could be loose and the tv jacks could be loose as well which can cause a poor visual or no visual at all. If other dvd's work then its simply the dvd itself, make sure your not trying to play a blueray dvd in a regular dvd player they wont work in a normal player.
Feb 17, 2012 | RCA DRC247N DVD Player
For some reason, I get audio for the visually impaired when i play a DVD. The original sound of the DVD plays but an additional narrative (describing each scene) plays as well. The DVD is a recent...
Generally, remote controls for DVD systems have a button labeled "Audio". This button changes which audio track you will hear during the movie. Common tracks include English, French, Spanish, Commentaries, and occasionally Audio for the Hearing Impaired.
It seems odd for the latter audio track to be default, but clicking the Audio button until you have the plain English track should work. I would consult the manual if you have it on hand to see if your system is capable of remembering which track to start on.
Hope this helps.
Jun 13, 2011 | Protron PDS-2315 Theater System
I have an old DVD player from 2002 & I'm trying to hook it up to my TV (old TV too). Do you have a graphic of the hook up? The TV has a spot to hook up my cable for my basic cable channels. The DVD...
You connect up a DVD to a TV via the Audio Visual leads, they go into the Red White, the Audio, & Yellow, the composite Video. In & Out. They wire color to color. Then you select AV on the TV. & press Play on DVD.
Feb 07, 2010 | Toshiba SD-2800 DVD Player
Why the drive dvd rw can't play dvd movie
You need special codecs to play dvd movie disc...or you need the right player that already has them installed in the main program. Below is a free dvd player but it is also a universal player of all types of audio-visual formats. It will play any movie disc just like from blockbuster or netflix or the ones you buy at a retailer. Below is the link to the download. Click on the link below and when it comes up look for the small bue text that says "server 1", click on this and it will start the download.
http://www.download3000.com/download-avs-dvd-player-count-reg-17748.html
Jan 13, 2010 | Compaq Computers & Internet
Installed memorex mvd2042 dvd player, receive message "root"
Aha. I just found a solution. Press DVD menu on the lower left.
Dec 29, 2008 | Memorex MVD2042 DVD Player
Need instruction to hook up dvd player
You will need a TV or monitor with audio/visual inputs. The better ones have what is known as an S/VHS input, which separates the TV picture signal for better color reproduction. You will need to be able to switch your TV, usually by the channel selector, to the proper input for audio visual signals. Sometimes this is known as Video 1, Video 2, A/V etc. These are usually below Channel 2. Maybe your remote has that option. You will need an a/v cable. This is a three-connector cable with RCA plugs on each end. Connect the DVD player to the TV as follows: 1. Yellow cable, from video OUT on the DVD player, to video IN on the TV. Video is ALWAYS yellow. 2. Red and white cables from audio OUT on the DVD player to audio IN on the TV. 3. If you have S/VHS capability, buy an S/VHS patch cable which will have the three plugs mentioned, plus a round 4-pin plug. Select S/VHS OUT on the DVD player, and S/VHS IN on the TV. When using S/VHS, ignore the yellow connector. It is for composite video and not needed. Here's a hint: Your YV audio/visual inputs will usually be on the back of the set. Some better units have a/v inputs in front. What if my TV doesn't have a/v inputs? If your DVD player as an RF output, connect an RF "f" cable from that output to the antenna in cable on your TV. Otherwise buy an RF converter (about $20 or so at Radio Shack). Connect your a/v cable (yellow, red and white) from the DVD player to toe converter, then connect an RF cable (like the kind your cable box is connected with) to the antenna input on your TV. This signal usually comes in on Channel 3. Let me know if your problem is more complicated, It seems like a lot of wires and connections, but it is really straightforward, Remember, yellow is ALWAYS video. The two audio cables can be connected without worrying about color.
Dec 13, 2008 | Televison & Video
My dvd recorder will only play audio and not visual when I try to play dvds
check the spindle motor,set your tester to x1 if normal the reading is 200ohms if not change your spindle motor,if not fix the problem replace the MPEG board of you dvd.
Oct 29, 2008 | Sony Televison & Video
No audio
Mine does that too. I've noticed that the audio works fine if I play an audio CD. It seems to "reset" something. But then after I turn off the DVD player, it's **** shoot whether or not I'll get any audio the next time I turn it on.
Jul 09, 2008 | Cyberhome CH-DVD 300 DVD Player
Playing dvd files
Different video files need different software. What is the operating sytem?. What DVD software are you trying to play? What are you using to play it at the moment?
Let me know and I can help you.
Apr 27, 2008 | Televison & Video
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
