Question about Radio Shack Audio Players & Recorders
Hi my name is samantha and i have a problem i have an amp of 250 watts and i was playing it yesterday and it was fine and then today i was playing it again i connected it to my lap top and it was fine. About an hour ago i wanted to play it agian and it turned on but there was no sound. we checked the speaker with a battery and it works but the amp itself doesn't want to work what do we do?? or what is wrong with it?
    Sergeant:
  • 270 Answers
Houses and outlets have protections called GFI. The room (or outlet) does not have to be in a wet area to be on the circuit of an GFI plug.
Get a lamp, and test the outlet. If the lamp does not light, then you know the outlet is turned off. Look for the circuit breaker box, or a tripped GFI outlet.
good luck and don't forget to vote!!!
Posted on Sep 30, 2010
Hi,I have two 250w speakers at 8ohms ,could someone tell me if I need to get a amp with higher watts than the speakers?k
Speakers are rated either at RMS (root mean square) average power or Peak Power. An RMS of about 125 watt is equivalent to 250 watt peak. To match the radio and speakers they both need to be consistent. Also do not be confused with total radio power out vs per channel.
So if the speakers are 250 watt peak power then a radio with 125 watt per channel or 250 watt peak per channel would be a good match.
If the speakers are RMS 250 watt then the radio would be 250 RMS/channel and usually with a four channel radio a total of 1000W RMS
With that much power the neighbors should hear you coming!
Dec 02, 2015 | Car Audio & Video
92 maxima starts but 250 rpms
idel control module is bad....try and clean it with brake cleaner or replace.
Jul 05, 2014 | 2003 Ford F350 Super Duty DRW SuperCab
Put new pa speakers in church 2 1000 watt tied 2gether and 2 300 watt. tied 2gether. the pa amp only has 250 watts with 6 mics connected and a cd player which plays fine. every time the mics are used if...
hi,
You have to check the ohms of the speakers all spekers should be 8 Ohms or above. if not it will overload the amplifier at high level. The minium ohms impedence of the amplifier is 4 ohms. If you connect two 8 ohms speakers together then the effective ohms will be 4 OHMS then the amp will handle the speakers. If you connect two 4 ohms spekers together then the effective ohms will be 2 Ohms, this will overload the amplifier. You will be able to connect two 8 ohms speaker to left channel or right channel of the amplifier. Check the speaker spesifiction to know its ohms. Make sure all the speakers have an impedence of 8 OHMS or above
OK
Aug 19, 2011 | Radio Shack 250 Watt PA Amplifier...
Which amplifier i should use with JBL CS-1205T
this sub woofer tube has a rms rating of 275 watts... try using a kicker or orion 600 watt mono amp to run this. the brand name is what tell you about how good an amp is for instance the names i just mentioned rate their amp by standard play frenquencies where as other lower brand names rate their amps by the max out put on certain subs at certain frequencies which may lower their impedance and create more power although you will never play your sub at those frequencies. as for the max power of your sub of 1100 watts that is more than like only at a certain frequency so always only double your rms rating of your sub to find max power handling.
Jan 29, 2011 | Sony Xplod Amplifier XM-SD51X - Class D...
Adddress book does not show past c
dear friend, some phone have default setting that if one caller has called you yesterday & again today the yesterday history will be updated to today & it will not be shown again & if still has a problem please let me know your mobile name & model no.
njoy...cheers
Dec 25, 2010 | Cell Phones
Hi i have two 10'' jenson xs sub and they are about 6 years old and i was wondering wut amp size i should buy to run them.
I believe these are 4ohms, if so buy a 2ohm stable monoblock amp, that puts out 250-300 watts RMS, and connect your subs to it in parallel, don't pay attention to peak watts, look at RMS watts, or continuous watts. If they're 2 ohms, buy a 2 ohm stable 2 channel amp that puts out 125-150 watts RMS per channel, and 250-300 watts total or bridged RMS output. And connect them normally, on sub per channel... hope this helps, as far as brand recommendations, MTX, pioneer, Alpine, Kenwood... Good luck
Sep 20, 2009 | Jensen XS-1010 Car Subwoofer
Low voltage only or can timer be used for 110 v
1 hp= 750 watts
125 vac = 125 volts alternating current, wall outlets
5 amp= 5amps
125vac x 5amps= 625 watts
a timer is a switch with a clock on it. just like a switch in a lamp cord.
Dec 12, 2008 | Hardware & Accessories
My new tomtom XL It should have spoken street names, but I can not get it?
Apparently only Samantha can speak street names. Mine didn't come with it, but when I updated my unit by connecting it to the computer at the tomtom site, Samantha was automatically downloaded. I chose her voice and it works.
Sep 03, 2008 | Tomtom One XL GPS Receiver
60 people viewed this question
Top Radio Shack Audio Players & Recorders Experts
 Grubhead
Grubhead
Falling star
Stuart Slabber
Level 1 Expert
Are you a Radio Shack Audio Player and Recorder Expert? Answer questions, earn points and help others
