Question about Grundfos MQ3-35 3/4 HP Pressure Booster Pump
I have a Grundfos MQ3 35B pump that transfers water from a rainwater tank to the wasking machine, garden taps and flush toilets on demand. This works fine most of the day but if left unused (ie overnight or when away for a day or so) it has shut itself down (red fault light on). When rebooted (switched back on) it mostly works straight away or hums away for 5 minutes or so then works. Any ideas on what sends it to sleep?. 2 storey house - having trouble pushing up hill? Thanks Bill
  • 1 more comment
  • billnagle54 Oct 05, 2010
    thanks tbreeze47. Your response has got me thinking. The tank water level is very low (not much rain and mains top up floats set very low - not much above the outlet/suction line on the tank). I have filled tank manually from mains and this improves situation but not always. So I will check the non-return valve (on the suction side? - none on discharge side). It may be faulty, incorrectly set or slightly ajar with rubbish or foreign matter. What do you think?
    I have a Grundfos MQ3 35B pump that transfers water from a rainwater tank to the washing machine, garden taps and flush toilets on demand. This works most of the day but if left unused (ie sometimes briefly but commonly overnight or when away for a day or so) it has shut itself down (red alarm light on). When rebooted (switched back on) it mostly works straight away or hums away for 5 minutes or so (as it primes?) then works. Any ideas on what sends it to sleep?. 2 storey house - having trouble pushing up hill? Low water levels in the tank or a problem with the non-return valve? Thanks Bill
  • billnagle54 Oct 06, 2010
    Thank you - I am coming to that conclusion as well. Partly low suction side pressure because the tank is so low and possibly a leaky non-return valve on the suction side.
  • 11,800 Answers
The only thing that would cause a problem like that is when the pump is no longer primed - the water has drained out of it and it runs on empty = overspeeds.
You need to replace the valves, they are leaking. Also make sure that the rain tank is clean, dirt and debris might block the valves.
Posted on Oct 05, 2010
  • 3,083 Answers
Most likely the water supply to the second story is not holding water for a few hours, and so the pump has to repump it up the supply line until it works. There could be a slightly leaky stop valve or whatever is being used to hold the water in the line when off, but it sounds like it might work at times and not at other times.
Have never messed with something like this, just sounds like what's happening. I read on a blog that this pump takes 5 minutes to self prime from a 26 ft well, so it sounds like sometimes it's having to re-prime.
Good luck, and hope this helps.
Hope this helps.
Posted on Sep 30, 2010
Should Ebrs watertech pressure pump come on and shut up with use of tap
No. It sounds like you have lost your air bubble or air bladder in your captive air tank. Without the elastic effect of an air bladder or air bubble in your captive air tank, the pump will come on right away, trying to keep up with demand for water. You will have to either add air to the bladder in your captive air tank (it looks like a car tire valve stem) so the pressure is likely in the 35-50 lbs range. You may have to flush a toilet or have other water usage going on when you will the tank with air or you will be fighting your water pump. Or, turn the pump off, flush a toilet, and then will it with air to the approximate pressure, then turn the pump on for normal operation. If the problem comes back, you will need to possibly replace the captive air tank and or bladder, which if ruptured is letting air dissolve into the water, leaving you again with not elastic bubble to act as an accumulator.
Jan 23, 2018 | Plumbing
Toilet stools whistle after flushing
This could be caused by the sound of water jetting into the water tank. Just open the tap to the water tank slightly more until the whistling stops. The flusher valve in the tank may be leaking, causing the water jet to open again and the whistling noise.
Apr 26, 2016 | Home
A friend has a grundfos comfort hot wter recirc system and is getting a chatter or water hammer noise at night after the toilet is flushed.he tells me it sounds like it's coming from under the counter...
1) Unplug grundfos and see if same problem occurs.
2) Noise can be cause by water not flowing freely.
Disassemble parts and clean with CLR (calcium lime rust).
http://waterheatertimer.org/Water-heater-recirculation-system.html
3) Any time there is a humming sound, it can be the motor.
I would also use CLR and clean out Grundfos pump.
4) Any pump or motor that slows down, is overheating, and burn out.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 06, 2011 | Grundfos Comfort System Recirculator ...
I have a Grundfos Comfort System. At the tap farthest from the hot water tank, I get a tremendous amount of grainy residue from the tap. No other taps have the residu. I've replaced teh water softener,...
Sounds like you have sediment built up in the pipes, and maybe the furthest faucet is the gathering place.
Take off each shut-off valve at furthest faucet and connect a water hose that flows into nearby toilet bowl.
You can buy garden-hose-to-1/2-pipe adapter at hardware.
Open water so it flushes the line into toilet bowl.
Then clean out valves and reassemble shut-offs and grundfos connection.
Remove faucet aerator and flush line up to faucet.
Install new aerator.
Dec 30, 2010 | Grundfos Comfort System Recirculator ...
Ok at the place I am employed they have a 1 Hp submersible pump it pumps about 300 ft into the top of a 120 gal storage tank then the water comes out of the bottom of the tank and goes into our grundfos...
The booster should have been placed after you restrooms with a check valve to prevent back-pressure. then you can adjust both the sub-pump pressure, and the booster pressure accordingly
let me know
Dec 18, 2010 | Grundfos MQ3-45 1 HP Pressure Booster...
I have a problem with the MQ-35 pump starting and running for about 10 minutes when there is constant demand (such as running a sprinkler) and it then alarms and shuts off for 30 minutes before it will run...
This sounds like a issue with air still being in the system and not being removed from the system to make things work properly. I did try to findthere number and was unable to locate it. The only other option for you is to return the product and find one with better support
May 04, 2010 | Grundfos MQ3-35 3/4 HP Pressure Booster...
No water comes out of the tap connected to the rainwater tank when turned on
hi chances are silt is sitting in the bottom of your rainwater tank best bet is to memove the tap and flush out hope this helps
Nov 18, 2009 | Home
Ghost flush on toilet bowl
Lift the cover on the toilet tank. If the water is too high, it is running into the overflow tube. You will have to adjust the float lower to stop the water at a lower level. If there is no water in the tank, the ball **** is faulty and needs to be fixed or replaced.
Jun 07, 2009 | Siemens SpeedStream 4200 (13A4200001)...
Grundfos MQ3-35  3/4 HP Pressure Booster Pump  Logo
839 people viewed this question
Top Grundfos Garden Experts
john h
jasbo
jasbo
Audrey Messer
Audrey Messer
Are you a Grundfos Garden Expert? Answer questions, earn points and help others
