Question about Onkyo TX-DS575 Receiver
My receiver shuts off & the standby button blinks when I switch sources such as DVD to Video to FM.
    President:
  • Onkyo Master
  • 1,114 Answers
The most common problem found on FixYa for Audio Video Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
If you still have an issue, post a comment and I can help you further.
Posted on Sep 30, 2010
Onkyo ht-rc180 standby light blinks will not start.i tryed factory reset, still blinks
The amp protection circuit has been activated. Remove the power cord from the wall outlet immediately. Disconnect all speaker cables and input sources, and leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and reconnect an input and a pair of speaker wires onto the unit. If the receiver still does not turn on than you will have to bring it in for service. Turn up the volume and if the receiver doesn't shut down, power off the receiver and add another pair of speakers. Power up the unit again and turn up the volume. If it doesn't shut down, power off the unit again. Now connect all your input sources and turn on your receiver. If the unit shuts down again, your unit will need to be further serviced at an authorized Onkyo service center.
Sep 24, 2014 | Onkyo Ht-Rc180 7.2-Channel A/V Surround...
TV is not working
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Mar 10, 2014 | Sylvania LD-320SS8 32 in. LCD TV/DVD Combo
I have SR 307 onkyo A/V receiver home theatre system. the remote control has stopped working. i checked with a local dealer and that the remote is okay and something has wrong in the receiver,
Did you check the remote with another Onkyo system at the dealer ??. If its OK try resetting the system. Remember you will loose all your stored presets ( FM and customized settings ) and the Amp will go back to factory settings.
While in standby mode hold down the DVD button and press the Standby/On button., the display will show Clear and the Receiver will go into standby mode. Turn it on and try the remote once again.
Jun 01, 2011 | Onkyo TX-SR307 A/V Receiver
Need to know how to set the clock on this model
PRS SOURCE BUTTON AND SELECT STANDBY. PUSH CONTROL KNOB TWDS FM OR AM SELECT CLK ADJ. PRESS CONTROL KNOW FOR AT LEAST 1 SECOND OR UNTIL CLOCK DISPLAY BLINKS. PUSH CONTROL KNOB TWDS FM OR AM TO ADJUST HOUR. PUSH CONTROL KNOB TWDS FF(ARROWS) OR REV (ARROWS) TO ADJUST MINUTES. PRESS MENU WHEN DONE TO EXIT.
Aug 18, 2010 | Kenwood KDC-MP202
Unable to stay power-on
Have already posted this fix twice, but to be sure hunglam_1999 receives notification, doing so again 27Oct2009:
Most common failure is the audio amp IC, reference # Q5001, which is an STK402-950 (Onkyo Pt. # 222123). Typically fails as a result of excessive volume levels or as a result of problems with the speakers or their wires. If you're technically inclined, the part can be had from various vendors & is fairly straightforward to replace once the complex disassembly required to access the PCB this IC resides on is accomplished, using standard soldering skills. A repair of this type by a reputable servicer may be more effective for non-technical folks, as typically can be accomplished for $200 or less, much less than replacement cost...
Oct 05, 2009 | Onkyo LS-V955 System
Amp err
Same problem here VSX-916 AMP ERR
Jan 28, 2009 | Pioneer VSX-D912 Receiver
Blinking standby button
Hi...1st off ...make sure all the speakers are connected at both ends.
2nd..buy a new cat..one that doesnt drool.
If it's still stays in Stdby after checking speakers, It might have blown an internal fuse cause thats where those darn stereo people put them now.
Jan 09, 2009 | Onkyo TX-SR605 Receiver
Marantz SR6001 AV Surround Receiver - Blinking Standy Light
For resetting sr6001: When power lights blinking, press "clear" + "pure direct" + "7.1 ch input" simultaneously for 3 seconds.
iskender
Nov 10, 2008 | Marantz SR-7200 Receiver
Onkyo TX-DX838
I went back and found a loose cable/coax. Re-attached and now the receiver works as good as ever.
Sep 02, 2008 | Onkyo TX-DS838 Receiver
Blinking Standby
regarding the Pioneer VSX-912 blinking standby light. This is how you reset it; press the "advanced surround" and the " enter" at the same time for about 3 seconds. Make sure you press the ENTER on the reciever (its the one on top next to the small dial) If you press the "ON" instead of "ENTER" it will not work. If an error message comes on and shuts the unit down, just reset it again. This should save you some $$$$. To bad Pioneer did't put this info in the manual.
May 22, 2007 | Pioneer VSX-D912 Receiver
Onkyo TX-DS575 Receiver Logo
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
