Question about Samsung RSG257AABP (25 cu ft) Side by Side Refrigerator
On the screen where water comes out it shows OF OF. We had a power outage and when it cam back on thhat is what it had on it. What is it and how do I clear it?
    Sergeant:
    Champion:
  • 351 Answers
Un plug refer for a few min about 5min should reset
Posted on Sep 30, 2010
Power outage and fridge doesnt come back on when power is restored
First make sure there is power to the plug at the wall. If not check the breaker. If power at the plug, the power outage could have been associated with a power surge that killed your refrig.
Mar 21, 2014 | Whirlpool WRF560SMY 19.6 cu. ft. French...
Htc 8s water damaged?
It is a water demage - with using to quickly you made it bad, I guess with pressing the screen you moved the water.
I would say ... give it another dry (smile)
Open the rear, take the batterie out ... mean let the mobile breath ... then leave it on a warm, but not hot place ... it has to stay on the side. We want that the water in the case vabours troughthrough the side buttos within the time.
Feb 04, 2014 | Computers & Internet
Rheem Power Vent 50 gas water heater will not come out of vacation mode! Have tried turning on and off, resetting and following directions on the side of the tank. Will not come out of Vacation Mode. Had a...
Water inside tank-type water heater can remain hot for some time.
That's one advantage of well-insulated tank-type water heaters.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Power outage can be related to failure of gas control.
Unplug stuff when power goes out. And then plug back in after power is restored.
Water heaters with electronics are not protected from surge.
Electronics can blow out during and after power outage. For example nearby lightning strike will cause current to run along household wires. With ordinary power outage, once power is restored, the surge can affect all kinds of electronic circuitry such as timers, water heaters, water softener, treadmill etc.
Sounds like you have intellivent gas control valve:
Open following link to identify gas control, and download typical manual, and download intellivent service manual with troubleshooting, error codes, etc.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 26, 2011 | RHEEM 50 Gallon FVR NATGAS Water Heater...
1 have a xerox copier model XD120F Had apower outage when copier cam back on screen is showing a H4 and not powering up thanks Joe
Hello
Since the problem occured after a power outage,you should try resetting the H code.
Press CLEAR, EXPOSURE MODE, CLEAR, EXPOSURE MODE. The display should go blank. Then enter 14 with the copy count keys and press START. If the machine does not turn off and back on by itself - then turn it Off and back on. See if the H code should vanish and your copier should work well.
Apr 17, 2011 | Office Equipment & Supplies
My dell d600 doesnt start after a power outage. It was plugged into a power surge protector. This has happened before (power outages) and never a problem. After this outage, I was able to get online for...
A little googling gave me this http://www.laptop-junction.com/toast/content/dell-caps-lock-light-flashing-blinking
Looks like it could be a memory problem. You could check if one or both of your memory is damaged by removing one at a time. The manual should have the procedure for adding / replacing memory.
Feb 21, 2011 | Dell Latitude D600 Notebook
Lightening storm, brief power outage. When power returned, my JVC
You have been affected by the lightning.
It is possible that your television may come back...
Un-plug the television and let is sit for an hour or more. Plug the television back in and allow it to re-boot. If it does not come back then, turn it on and off a few times to see if it gets any better.
Unfortunately, your TV may need repair or replacement. To avoid this in the future, use a good quality surge protector like Panamax .
Jun 14, 2010 | JVC LT-40X776 40 in. LCD HDTV
Calling for a older friend> ac power outage happened within 30 secs of each other. Now computer comes on and begins startup showing screen but shuts down and starts up all over again and again
Unplug everything, wait a few seconds and retry startup. But it almost sounds like a virus or malware was uploaded into the computer. Also try startup in "Safe-Mode". Hold down key marked "F8" after pressing the power on button.
May 20, 2010 | Computers & Internet
Televison does not work
first try unplugging the tv for a couple of minutes this will reset it, then plug it back in and see if it comes on, if not there is a fuse inside the cover on the power board look to see if the power surge has blown the fuse. the power board is easy to locate your plugin goes directly to it.
Dec 12, 2007 | Westinghouse LTV-19W3 19 in. LCD...
Samsung RSG257AABP (25 cu ft) Side by Side Refrigerator Logo
91 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
