Question about Maytag Refrigerators
When refrigerator stops, it doesn't turn on itself. I have to turn it off then turn on again to start.
  • lyudmila_ras Sep 30, 2010
    When it stops light works,
    but fan never start work again
    and in the freezer ice melting
    and becomes to water again.
    I turn it off by turning Cool-cooler
    knob in freezer off and then turning
    it on again. Fan start and in a while
    water becomes to ice.
    Then it stops again and ice melted.
    Thanks
    Here is info of my refrigerator:
    Model HBB2256GES
    MGF No PHBB2256G50
    s/n 10795106CL
    11 VAC/60 Hz
    AMPS 7.70
    President:
  • 2,777 Answers
Hello there, need some more info here.. What do you mean when it stops? When you hear the fans stop you mean? It may take a long time for the fans to come back on and that is normal... Are you certain it won't come back on? Or do you mean the lights go off and never come back on?
Let me know, thanks
Tim
Posted on Sep 30, 2010
  • Tim Grayson
    Tim Grayson Sep 30, 2010
    Interesting, it sounds like the internal thermostat / temperature gauge is failing in the fridge. Are you trying to do the repair yourself? I would definitely recommend you consult with a refrigerator repair person at this point as the repair is very difficult. If you want to try it yourself though I can find the part that you need, let me know.
    Thanks
    Tim
Refrigerator and freezer not cooling
Check the start capacitor on the compressor and the thermal cutoff switch. It is where the wires connect to the compressor.
Jan 05, 2014 | Whirlpool ED5VHGXM Side by Side...
My Rheem RRKA-AO3OJK08E unit froze up, yesterday (frost on tubing). I cleaned the filter, really good, and turned off unit to let thaw. I have not tried to re-start it, yet. Can you tell me the usual...
Either your filter was really stopped up or you could be low on refrigerant. If your filter was stopped up, be sure it is thawed out all the way with no more ice build up, and go ahead and turn it on. You may have already solved your problem. It it freezes up again, you will have to have your refrigerant checked.
The only other thing it could be would be a stopped up evaporator coil. This happens when the unit is ran for a long time without a filter or when the filter doesn't fit in the blower correctly.
Jun 23, 2011 | Heating & Cooling
My kenmore sid by side frige has lost all power the recepticle i use is fine.it's less than 2 yrs.old
Reset the circuit breaker or fuse and ensure the fuse has a 15 amp time-delay to provide enough power to the refrigerator.
Ensure the temperature control knob is turned past "0" and is set at a temperature cool enough to require motor function from the refrigerator.
Wait 20 minutes and check the power on the refrigerator again, as the unit may be in a defrost cycle, which may make it seem as if it was turned off.
if that doesn't work, and your sure you have power to the plug itself,, contact the searsdirect.com
they have an online chat repair
Jun 12, 2011 | Kenmore Side by Side Refrigerator
I have a small magic chef fridge that just stopped working. Can seem to get the motor going at all - if just defrosted by itself. Inside is a dial and a red button - we've clicked that a few times to try...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 03, 2011 | Magic Chef MCBR445S1 Stainless Steel...
The fan on my GE TFX25ARAA refridgerator stops running, but if I give it a push with a pencil, it starts running again. When it is not running, the outside of the refridgerator gets very hot as do the...
Possible that the fan is defective or the fan is receiving low voltage so as not to run by itself.
you will need to remove the fan and check with an external voltage to see if the fan starts without an external trigger.
If not check the voltage to the fan , trace for any loose connection or poor joints for loss of voltage.
Oct 28, 2010 | GE 25.2 cu. ft. Side-by-Side Refrigerator...
Our avant 323yb works. intermittently. It stops chilling unless we turn the temperature back off and on again. But eventually it will shut itself off again.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Sep 11, 2010 | Refrigerators
Side by side not making ice
valve is probably frozen preventing supply water into ice maker. turn ref off for about 12 hrs to allow the supply line to defrost. turn on and see if it solved the problem. if not, the valve itself may be defective.
Jan 27, 2009 | Frigidaire FRS3R5EMB Side by Side...
Kenmore side by side compressor keeps getting hot
Your fan is stalling which in turn is over heating the compressor causing it to shut itself down. Replace the fan and make sure the coils under the fridge are clean. That should take care of the problem. Good luck
Dec 29, 2008 | Kenmore 50522 / 50524 Side by Side...
Refrigerator stops cooling, but if I adjust the temp it restarts
temp control wire dodgy turn off take plug out of socket trace wire repair it switch back on i had one temp mate it was wire
Dec 17, 2008 | Frigidaire FRS23KF7AB Side by Side...
Refrigerators Logo
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
