Question about Sony Dream System DAVDX155 Theater System
Unplug/protect i start to watch a movie and about 5 mins in every time the picture gose black and no sound.......and on system it flashes unplug, protect......i unplug from wall and for a 1 min afterward it still flashes the same message then gose away.....i can then plug back and start again please help jason
    Genius:
  • Sony Master
  • 1,550 Answers
The audio amplifiers ICs of your device are damaged.You gotta take it to service center.Good luck.
Posted on May 25, 2008
I have sound but no picture.
Netflix Customer Phone Number Shortest Wait Best Support
  • Phone Number
    888-638-3549
  • Talk to a Human Press 0 at each prompt.
Average Wait: 5 mins - 24 hours, 7 days
OR:
Netflix Calls You Instead
Mar 15, 2015 | Netflix
Sony KPR-53EXR15 pictures fades in and out
Sounds like possibly it could be connection related between any AV/Cable ports. Worst case would be the capacitors of the motherboard leaking. It's possible to fix anything. Just make sure you have the knowledge and the right equipment.
Mar 31, 2017 | Televison & Video
42 projection sony wega tv model kdf46e2000 turn on but red lite flash for 3-4 second then tv gose off
Your TV set has entered a protection mode, the system detects a failure. Try to unplug your set for 5 minutes to reset the system...
Sep 24, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Picture goes black mins after watching
Bad flyback transformer. It has a short in the winding making the Horizontal output transistor heat up so when its too hot the set goes into protection.
Aug 25, 2009 | RCA D52W23 52" HDTV CRT TV
Picture went out on my 36'' RCA television, still have sound.
do you have and big sound system if you do the move them away from youur tv. or you sould just bring it to a shop it must be the picture tube
Jan 26, 2009 | RCA 36V430T 36" TV
A repair question for the RCA M50WH74S
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Aug 18, 2008 | RCA HD52W56 52" Rear Projection HDTV
I have sound but no picture?
i setup a remote code on the remote so the tv goes on /off and the volume but no picture on screen how when i put the dvd player i can see the movie but noy regular tv please help
May 08, 2008 | RCA D52130 52" Rear Projection Television
Flashing light
this unit will have what is called ik protection wich means that the picture tubes are constantly monitor with this system all the way to the video procesor so the picture will desapear to a black screen even if the audio is ok,there may be a solution if contract a tech like me to adjust the bias so that compensates the drives to the pictures tubes since 1 or the 3 pt are week at this point.
Dec 25, 2007 | Sony KP61XBR200 TV
Sony Dream System DAVDX155 Theater System Logo
268 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
