Question about Samsung Televison & Video
My Samsung-LE40A656A1FXXU just turned itself off after about 10 minutes. I've checked the fuses, plugged in it diferent sockets it won't even go on standby
3 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Posted on Aug 28, 2009
  • 8457 Answers
SOURCE: My Samsung HLS4666WX TV has started shutting
The lamp in the tv been in use about 1 1/2 or 2 years,the tv on about 4 or 5 hours a day?The lamp life span is over.Replaced the lamp.
Posted on May 31, 2010
My Samsung LE40A656A1FXXU is not coming on just making a sleep mode noise very 10 seconds
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Sep 05, 2016 | Samsung Televison & Video
Why does my treadmill run for about 10 minutes then switch of,after restart runs for a few minutes more then goes of.
Check your user manual and read the programming section and fault finding,
like they say...if all else fails read the manual!!
good luck!
Jun 03, 2016 | Cars & Trucks
My laptop won't turn on, and the charger doesn't seem to be doing anything. even when plugged in, it won't start. ideas?
You've to replace the ac adapter, if it's brick doesn't get warm or LED does not glow on Power Jack on the laptop. offcourse, check with the wall different sockets
power jack can also be loose. so jiggle the cable to find out.
if notebook is getting power, you can remove the battery, ac adapter, hold and keeep pressing poer button for a minute, then, turn it on.
finally, you can take out hdd and ram, put them back again and turn on the laptop. hope it will help
Sep 17, 2011 | Compaq Presario CQ60-220US PC Laptop
I have a samsung LN-S3238D lcd tv. the unit is approx 3 - 4 yrs old. last night when watching tv the tv shut off by itself and will not turn back on. normally when the tv is shut off, the red led light is...
Hi replace the fuse in the wire connecting the mains plug. It's generally located within the 3 pin plug.
If you are lucky it maybe just a fuse blown out.
Thanks
Jul 06, 2017 | Samsung LN-S3238D 32 in. LCD HDTV
Daughter unplugged tv without turning it off first. Now, it won't turn back on from the remote or the monitor panel on the front of the tv. It's a Samsung 1080 LCD. Only 6 months old. I've...
hi if you have at least a basic knowledge in repairing in any electronics as my recommendations, since the problem is won't power on.first you need to open the back cover with the use of philip screw driver then start to check the power supply look for the blown fuse replaced with the same amper rated at the part. then check for any burnt or bulged capacitors. also considered the inverter ballast board if their is no burnt connectors or parts. good luck hope it will help you.
Jul 14, 2011 | Televison & Video
My tv won't power on after lightning struck and made the power flicker. i've tried unplugging it and leaving it unplugged for several minutes with no luck. is there a fuse?
Check the fuses on the power board. there is one fuse on primary side and one on secondary side.
Take of back panel and follow plug into the tv.where it ends is the power board.always use caution.the capacitors in there hold high voltage even after unplugged for a couple of days.Discharge capacitors before servicing the board.
Jun 28, 2011 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
My nissian maxima 2000's power outlet won't work. i've researched on the web and they say something is wrong with the fuse. so the fuse box left from the steering wheel, how can i check if the...
You should be able to see if the fuse is bad by pulling it out and looking through from the side. There should be a piece of metal that connects the two sides, if it is bad the piece of metal will be broken. To compare, try pulling out another fuse and comparing the two. Take the fuse with you to advance auto and they can sell you a replacement.
Jun 17, 2011 | 2000 Nissan Maxima
I have a built-in AEG Microwave code MC166(0E?) My son unfortunately used the microwave as a timer so it was on for 30mins without anything in it. It now won't turn "on"; no light/clock...
What fuse did you change? The fuse on the wiring that leads to the microwave needs to be intact, then the fuse in the Microwave itself needs to be checked. Usually there is a plug where the microwave is plugged in, in the cabinet above the microwave, you can take another small appliance or a power tester to make sure power is available in the outlet where the microwave is plugged in. If the power is on at the outlet then you'll know that it is the microwave itself that has turned itself off for some reason. You can get manuals for these ovens at this website
May 11, 2011 | Microwave Ovens
Indesit washing machine WIXE127 switches off main fuse
Have you added anything else that is drawing juice on the same breaker?
If so try turning those off.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Jan 31, 2009 | Indesit WA 125 Front Load Washer
Televison & Video Logo
105 people viewed this question
Henry  Thomas
Henry Thomas
