Question about Husqvarna 649cc 2Cycle Gas Backpack Blower
My Husqvarna back pack blower which has always worked great has developed a problem. While under full power, which it ususally is, it looses power and then regains it. What's up? Thanks
Wish I could help ya. I have a 170 BF 65cc engine that does the same thing. I did replace the spark plug but that only seemed to help for about an hour then it did the same thing.
Posted on Dec 09, 2011
My Husqvarna 150BT leafblower was running great then started to loose power like when I run out of gas, I shut it off check fuel level which was fine, cleaned the air filter, added more fuel and pulled the...
Pull the muffler and look for scoring on the piston. I think you cooked it my friend. You may have a bad coil or fuel cap, but it's more likely you ran the mix too lean.
Nov 04, 2013 | Husqvarna 150Bt Leaf Blowers
Husqvarna 150bt - runs great (WOT) from a cold start for about 15 minutes, then almost just dies. If I immediately release the throtle when I sense it is about to lose power it may return to idle, but...
Yes, the exhaust screen check is a must any time performance is low.
Your problem sounds like fuel starvation, ie. the fuel hose in the tank is broken or cracked. The weighted filter is on the end of the hose and has deteriated. You may have to replace the hose. Make sure to use the OEM hose as it is a special ethonal resistant material.
Additionally, if you can turn L and the H screw on the carb out (counterclockwise) about 1/8 you may find performance to be improved. Initially, most manufactures have leaned the mixtures of the screws to meet EPA specs., but performance suffers.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Mar 28, 2017 | Husqvarna 155bt Gas Backpack Leaf Blower
HUSQVARNA 130BT GAS BLOWER STARTS FINE, BUT LOSES POWER WHEN I TRY TO USE????
Sounds like a fuel starvation problem, Strip and clean carb. Avoid using airlines to clean carbs. remove low and high adjustment screws, reset to factory settings. Walbro carbs are generally scew both of them back in all the way and then turn out 2 full turns each anticlockwise.
Mar 02, 2013 | Husqvarna 130bt 130 Bt Gas Powered...
Trigger stuck on full
This machine has a metal throttle rod from the trigger to the carb, you need to look at the side of the carb where the rod connects to the carb, with your finger ( with the engine stopped ) work the carb throttle spindle manually to see if it is moving freely and it springs back to the small throttle idle screw easily, if it does unscrew the idle screw with a cross head screw driver until the machine idles ok, if not you need to take the l/h side cover off to investigate what has happened .
Feb 02, 2013 | Husqvarna Hand Held Blower 125 B Grass...
Where is the resistor pack located that is in the heater circuit, for a 1998 mercury Mistique?
Might be the Resistor pack located close to the blower. Could be under the dash or under the hood, but always close to the blower itself. Usually has a flat connector with 4 or 5 wires, and two small screws holding in the duct. It may be a crispy critter. It happens... The blower moves air across it to keep it cool. The blower motor may be bad as well, or possibly the fan speed switch. May very well be the fuse for the blower as well. The blower connector may be loose. Let me know what you find.
Dec 02, 2012 | 1998 Mercury Mystique
Handle assembly
Request a handle assembly diagram from Husqvarna.
Dec 08, 2017 | Husqvarna 130bt 130 Bt Gas Powered...
Redmax ebz5100 blower stumbles/misfires periodically until engine is hot?
What happens if you play with the choke ? does it clear up or change, If it does then it's a fuel problem example : fuel filter, fuel line cracked,dirt in carb. If the choke does'nt make a difference then , try a new spark plug Good Luck, Let me know how you come out 2StrokeJim
Nov 27, 2011 | Redmax Ebz5100 Back Pack Power Blower...
I have a Husqvarna 130 BT will not start; spark plug gap is proper; gas mixture is proper; filter is clean and the engine is getting gas and spark; help
pull your muffler and see if it starts,if not you are looking to more serious problems like crank seals or loose flywheel causing timing to be off
May 16, 2011 | Husqvarna 295cc Back Pack Blower HVH 130BT
My Husqvarna 125BT leaf blower will not make full power anymore. The past few weeks I noticed a strange sound best described as as a rattle similar to a loose baffle. Starts and runs fine but only makes...
Try pulling the muffler off and checking for blockage in the exhaust port, expecially the small hole above the main exhaust port. This is the same thing that my 125bt was doing this season and after cleaning out the carb with no improvement, I found some carbon build up in the exhaust port. The small hole above the port was completely blocked. After cleaning up all of the carbon buildup, it ran back to full power again.
Oct 30, 2010 | Husqvarna Backpack Blower 25cc, 140 Mph,...
Husqvarna 649cc 2Cycle Gas Backpack Blower Logo
226 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
