Question about Fisher and Paykel DGGX1 Electric Dryer
My dryr drum does not turns it hums - Fisher and Paykel DGGX1 Electric Dryer
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 113 Answers
Try to rotate the dryer drum by hand to see if it's locked up. If it is than you probably have an obstruction in the blower ( any missing socks?). If it's not that than your motor may be bad.
Posted on Sep 30, 2010
Why is my LG TROMM frontloader dryer making a loud noise when running?
If the washer is making a loud noise the rear drum with bearing might need to be replaced. On this washer the bearing might not be sold separately, the entire rear drum might have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Sep 02, 2014 | LG 4925ER1015B 4924ER1010 Used Frontload...
Dryer motor just hums, drum doesn't turn
check belt drum drive? check drum turns at all, it may be stuck.most drums turn with a belt. if it broke it is laying on the bottom of the dryer.didnt u see it??look again.
Apr 21, 2013 | Kenmore 98702 Stacked Washer/Dryer
Model # 72852 Burning smell Drum does not turn but a humming noise When door is closed it hums without the start button being pushed.
f you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Jan 18, 2011 | Kenmore Dryers
Dryer makes loud humming noise but drum doesn't turn when I push start.
Check to see if the drum will turn by hand. If so, leave the door open but push the light switch button down and start the unit. Once you hear the humming sound, manually turn the drum with your hand to start. If the drum turns normally, you have a bad motor and needs to be replaced. If the drum does not turn, something is jamming the motor and needs to be disassembled and inspected.
Good luck
Oct 03, 2010 | LG DLE2514 Electric Dryer
Drum not turning, hear humming noise
the humming noise is from the motor,see if you can spin the drum by hand,if it moves you have a bad motor,if it's hard to turn you could have something stuck in the blower wheel or the belt is jammed somewhere,the blower wheel is behind the duct that the lint filter slides into
Mar 20, 2010 | Whirlpool LER4634J Electric Dryer
Press the start button on dryer, it hums but wont turn. With 2 people pressed the start button again, held the door switch, reached in turned the drum, it hummed stopped humming then no more nothing....
Sounds like a weak motor. You'll have to get a new motor installed. They are fairly inexpensive and easy to install yourself on that type of machine if you are handy. Motor is located in the bottom right of the machine, attached to the drum belt through a small pulley underneath the drum next to the motor.
Dec 27, 2009 | Dryers
Dryer drum will not spin. motor hums when button
either the belt is broken that turns the motor or thr idler tension pulley is bad, if it were a motor problem the breaker most likely will trip
Nov 01, 2009 | Dryers
Model#GLEQ642AS2
If the drum is not turning and the hum is a nice quiet hum, then the belt on the drum has broken. The hum you hear is the motor turning without the belt.
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Aug 17, 2009 | Frigidaire GLER341A Electric Dryer
Very loud vibration coming from dryr
There's bearings for the drum,most likely a bad one.
Jul 14, 2009 | Dryers
Sounds like the belt has been stretched and is not letting the motor turn the drum. If the motor is not turning at all then your motor is burnt out and needs ot be replaced
May 22, 2009 | Dryers
Fisher and Paykel DGGX1 Electric Dryer Logo
76 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
