Question about New World 50GSO Gas Kitchen Range
Grill wil not work
I turn the dial to grill, press the ignite switch and everything goes hunky dory, then when I let go of the dial the flame goes out. There is no gas coming out when I let go of the dial. if I turn the dial the other way to ignite the oven that works fine, its just the grill that does not work. Any help would be greatly appreciated.
  • 1 more comment
  • mjlarter May 28, 2008
    thanks for the info
  • mjlarter Jun 02, 2008
    Thanks for this mate - you're a star
  • Anonymous Mar 12, 2009
    I dont no how to oprate the grill, but the oven is just fine
  • 27 Answers
The termocouple is broken, just had the same problem myself, looking for replacement part will let you know when I find the part.
Posted on May 27, 2008
  • 5 more comments
  • Mikey1963
    Mikey1963 Jun 01, 2008
    Found part online at http://www.espares.co.uk/
    enter bfs716047 into keyword search (top right)
    £11.79 + £4.99 delivery
  • qamarul5
    qamarul5 Dec 08, 2012
    Did you do the repair yourself and if so was it easy I have the same problem to
  • Mikey1963
    Mikey1963 Dec 09, 2012
    Yes, farly easy but you have to dismantle top of cooker, see here http://s238.beta.photobucket.com/user/Mi...
  • Mikey1963
    YES FAIRLY SIMPLE, LOOK HERE HTTP://http://s238.beta.photobucket.com/...
  • Mikey1963
    SORRY HEREhttp://s238.beta.photobucket.com/user/Mi...
  • Mikey1963
    The thermocouple for the grill drops down in front, if you are not careful when using oven you tend to knock it when putting things in, I think this is what broke ours. the thermocouple senses the heat of the flame, if it doesn't it switches off the gas, safety issue, so if the couple is broken it will never think there is a flame so as soon as you release the knob the gas goes off.
  • Mikey1963
    My cooker is still going strong 4 1/2 years on.......
How to light grill
switch the dial to the indicator which shows the top grill,usually this is a black line with a squiggle under it.
Sep 15, 2016 | Ovens
Out Door grill flame.
replace the gas regulator
check for blockages in the gas hose
Jun 15, 2016 | Grilling
Chef Regency Gas Wall Oven - oven fan working,light working , grill working as well but the main oven not responding when turning dial. The Piezo ignition is intermittent and no gas sound coming out.
The Piezo control board opens the gas valve while it makes a spark. Once the flame is lit the milivolt flame sensor holds it open from there on. Replace the piezo control board to fix.
Jan 16, 2016 | Kitchen Ranges
Poor flame after changing tank on gas grille
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 05, 2014 | Weber Genesis E-310 Gas Grill
Stoves newhome gg700 grill flame goes out if lid is closed
I had a stove in my camper that did this. The answer was to let the flame burn for a few minutes BEFORE closing the door. I think the original problem is that there is too much gas flowing to the burner and it literally blows itself out, until you get everything heated up and working. The question, I think, is there a way to turn down the gas pressure??
Nov 19, 2013 | Stoves Newhome ECH600MXa Electric Kitchen...
I cannot get a flame going on my grill - it has slowly stopped - I've taken everything out and cleaned to the nth degree - replaced the grill regulator; replaced the gas tank regulator, etc. The dial...
Here's the problem and the solution. The new regulator you just installed, locked up when you turned ON new tank. This oocurs quite frequently with the fairly new OPD equipped grill tanks.
Solution:
1. Turn the gas tank's valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY, SLOWLY (slow motion, slow),
4. Once the valve is fully open, light the burner farthest from the tank first and turn it to HIGH.
Did the burner light and does the flame height look correct? If so, light the remaining burners
the same way. Now, do all the flame heights look correct? If so, you solved the problem (with
a little help). Remember to ALWAYS open the tank valve very, very, slowly.
Happy Grilling!!
Jun 23, 2011 | Viking Grilling
Hi, I have just bought a Weber 100 BBQ. I have a
You have a couple of questions. In order: 1. Flame may not be visible because it burns very clean. 2. When they say 'turn gas off', they actually mean 'turn gas tank off'. 3. It's not necessary to remove the tank after every use. Just make sure the gas valve is off and the entire grill and tank are covered. I do remove the tank, and store it in an outdoor shed during the winter.
May 18, 2010 | Grilling
Flames only come out very low on both sides
disconnect tank, hook tank back up, then open valve slowly. When opened to fast it thinks valve is leaking and shuts down.
Jun 11, 2009 | Char-Broil CharBroil Master Flame Gas...
Low flame on 3 main burners. model GBC730W
Mike, I had this problem with my grill once or twice. Like most of us grilling men we turn the grill off at the tank trying to be safe. Sometimes, like in my case, I do not turn the nobs back to the off position. When returning to the grill the next day or week the first thing we do is turn the gas on leaving the nobs on, then lighting. Every time I do this my flame never gets full or does not reach full temp. To resolve this: turn everything off including the nobs, then turn the gas on, wait a minute or two. Turn the nobs to full and ignite. It should be at full flame then, adjust from there. I hope this is helpfull.
Sep 23, 2008 | Grilling
Ducane 3400042 lighting problems
Good answer... but remember (if you have the regular burners on... The Rotisserie will not light.) 1. Cut all knobs off... Then push and hold in Rotisserie button as you turn to high.
2. Press ignition button, until you hear rotisserie ignite. 3. Keep holding in the rotisserie button until the thermostat realizes the gas is on and burning. (IT must get hot enough to keep gas flowing.) Hope that helps, Dave
Apr 08, 2008 | Ducane 30400040 Stainless Steel Grill
New World 50GSO Gas Kitchen Range Logo
479 people viewed this question
Top New World Kitchen Ranges Experts
ashburton
Ismael Rodriguez...
Paul Carew
Are you a New World Kitchen Range Expert? Answer questions, earn points and help others
