Hi, what you need to do is this. IF you have NEVER set a password, then the default password will be the active one, and that is admin for login and admin for password.
However IF you have set a password and forgotten, then you need to remove the router from the power and reset the router via the reset button, usually in small hole at rear. Then power up again and use the default login and password, as before admin admin.
Now once you are logged into the router, then it is a simple matter to change the password to whatever you need, and then save the settings.
You didn't indicate the make and model of your router, I advise you to find a manual online and have a look in that just to make sure you have it all OK.
simply go to Google search, and type in the exact make and model and the word manual... this then will produce links to download a manual.
EG: Linksys 1234A manual
