Question about Paragon 8145-20 Defrost Timer
Can i use the timer for a water headter to trun on and off
Paragon 8145-20 is a 240V defrost timer
It is probably not best choice for water heater timer
Timer initiates defrost cycles each 4 hours.
A water heater timer should have more scheduling options.
-For example estimates show average run-time for water heater is 3 hours per day, depending on incoming water temperature, thermostat setting, and number of gallons used.
-To save money using water heater timer, you have to schedule times carefully so water heater runs less than 3 hours per day.
-Now your average electric water heater heats about 20 gallons per hour.
-Average shower uses 4-9 gallons hot water, so water heater needs to run 15-30 minutes (15 summer, 30 winter)
-Average bath uses 12-15 gallons hot water so water heater runs 45-60 minutes
-But lets say you run water heater for 1 hour and make 20 gallons of hot water. Then you take a shower, expecting hot water to remain in tank.
-Here's the problem ... cold water entered the tank to replace the shower water ... and the new cold water is cooling the rest of the tank.
-So a timer means scheduling hot water to match shower and bath events. For example taking shower and bath in immediate succession.
-Or set the timer for each individual hot water event ... for example set timer for 1/2 hour for shower, and later timer turns on 1 hour for bath, or 1-1/2 hr for 2 baths, etc
-> The flexible programming described above is not a characteristic of defrost timers.
I suggest Intermatic WH-31 240V or Intermatic T-104 240V or GE 15207. These are mechanical repeat-24 hour timers with manual override where each day has same schedule.
Digital programmable timers like Intermatic EH40 offer 7-day, 40 event programming. Weekends and weekdays can be different.
To see several box-type timers:
http://waterheatertimer.org/Boxtype.html
Posted on Sep 30, 2010
My timer works up to the end and stops but the dryer keeps going &going i have to trun it off my self
My guess is the contacts inside the timer are fried together. If you are careful you can take it apart and check. What I do is remove the shank ring around the shaft so that I can carefully remove and inspect the contacts without disturbing anything.
Jun 19, 2012 | Whirlpool Dryers
Fridge/freez ,motor fan stopped power going in,lound buzzlike a transformer
manually trun the defort timer clockwise until the unit goes into deforst mode. IT MAY BE THAT THE EVAPORATOR COIL IS FULL WITH ICE.
Jan 31, 2012 | Refrigerators
What happen when trun on a tv but it go off by itself (viore tv)
First check to see if you have a sleep timer set in the menu. Some flat panel units also shut off if the do not detect a signal.
Aug 16, 2010 | Televison & Video
How do you set an out door time? i truned the time to day and night position, it hads on / off but it only truns off
Ther trippers are different. There is one for on. and it should be marked on. and one for off should be marked off. The hit in different areas to turn it on and off.
Jul 01, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
WASHER GOES INTO ERROR IT SAYS E 10 CAN'T FIND MANUAL
I have a problem with the washer when trun on the it take the water and then E11 pop up and then trun off can you tell me why it doing that
Jan 03, 2010 | Frigidaire ATF6000ES Front Load Washer
Truns off by self
Check sleep timers make sure you have non set in the menu or setup if not the timer inside is gone south on you and will need repair.
Apr 23, 2009 | Dell W2606C 26 in. HD-Ready LCD Television
Matag top load washer wont spin or empty
Set the timer for manually for the spin cycle and trun it on.
If it does not spin replace the lid switch.
Mar 14, 2009 | Maytag Washing Machines
Zanussi electric oven ZBM 762X How do I trun the oven to manual?
If it is an anologue timer then rotate the knob until you see a hand symbol in the window, this brings it off auto.
If it is a digital timer then you need to press two or more buttons at the same time to get it off auto and back onto manual.
Dec 08, 2008 | Ovens
I can't get it to work i can trun it on but thats it. i can get work
hi
could be several things,
are the dishes wet at all?
is there a puddle of water in the bottom ?
do you have children?
If the dishes are wet , then its not draining, up on top of the sink theres an aerator , pull the chrome cap straight up and under that is a white knob, unscrew that counterclockwise and look for debris, reinstall
theres a round white float inside the machine below the bottom rack near the front that can get stuck in the up position and prevent draining, grasp the float to see if you can get it to move up and down slightly, look under float for dishes/debris
look under the sink for kinked hoses with a flashlight, make sure all faucet knobs are turned on under the sink.
lastly, toddlers and small children can crank the control knob in the wrong direction, bending contact points in the timer, if thats the case , youll need a new timer..
good luck
J
Jul 11, 2008 | Dishwashers
NO HEAT
CK IF YOU HAVE 220V COMMING IN OR THE HEATING ELEMENT IS GOOD. OR CK THE THM FUSE.IS NO GOOD. BUT IF DRYER RAN OVER NIGHT AND DIDNOT TRUN OFF YOU HAVE TIMER PROBLUM. THE DRYER SHULD TRUN OFF EVEN YOU HAVE HEAT IN THE DRYER OR NOT.
May 03, 2008 | Roper REX4634KQ Electric Dryer
Paragon 8145-20 Defrost Timer Logo
329 people viewed this question
Top Paragon Hardware & Accessories Experts
Gene Haynes
Steve
jdthefixer
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
