Question about Frigidaire ATF6000ES Front Load Washer
My CRTF1240AS0 FRONT LOAD FRIGIDAIRE WASHER WILL NOT START. WHAT DO WE NEED TO CHECK. THERE IS POWER AND THE BREAKER IS NOT TRIPPED.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 113 Answers
There is a small magnet on the bottom of the dispensor drawer that always seems to get dislodged. Pull out dispensor and check for it. It's number 8 on the drawing. Hope this helps,
Posted on Sep 29, 2010
Frigidaire Affinity ATF7000E Front Load Washer locks the door then it doesn't start. What's wrong?
Good Afternoon Friend,
I understand the door locks on your Frigidaire Affinity washer, model# ATF7000E, and the load does not start. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire Affinity ATF7000E Front Load...
Start button doesn't work on King Size Washer
Are there any lights on at the washer? If not check the washer circuit breaker in your house main circuit breaker/service panel. If it is tripped reset it and try start button again. If it trips again you need a service call. If there are lights on try turning the washer main knob to off and unplug the washer from the wall outlet...wait 10 seconds then plug in and try start button again.
Mar 16, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
Frigidaire affnity no power washer does nothing
see this causes and fix it. God bless you
see the diagram attached and troubleshooting.
1. No power to the washer
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
2. Lid switch
The washing machine may not function if the lid switch is defective. The switch is usually located near the door. Replace if found defective.
Sep 30, 2012 | Frigidaire Affinity ATF7000E Front Load...
Washer will not restart
There is a main control board on top which may need to be replaced,
if you remove the back top panel there is a tech sheet with a lot of information tucked in there, Suggest you plug something else into outlet to make sure outlet has power, and breaker is still ok,
good luck
May 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer tripped breaker on elec. panel, reset, washer won't turn o
This sounds like something has shorted causing the breaker to trip. You definitely need a qualified LG repairman to check it out.
Jan 11, 2010 | LG WM1814CW Front Load Washer
My Kenmore Elite front loader has no power.
the power is on but the start button does not start the machine
Jun 29, 2009 | Kenmore Elite 45986 Front Load Washer
LG Tromm WM2277H washer won't start after tripping breaker
no fuses only control boards.with power off pull the top off and check wires at your power supply board(not the one with buttons). Look for burn or damaged wires. no luck with that, will probably need power board(usually the board that goes out). Call LG and speak to cust service....sometimes will cover the board.
Jun 11, 2009 | LG WM2277H Front Load Washer
Dryer
I WOULD CHECK DOOR SWITCH FIRST
Jan 31, 2008 | Frigidaire GLGT1142CS Top Load Stacked...
Front loading frigidare washing machine
Check breaker only one breaker are function recock it the two breaker try to start it .
Jan 07, 2008 | Frigidaire GLTF1670A Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
99 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
