Question about Whirlpool Duet 7.0 Cu. Ft. Capacity Plus Electric Dryer
The drying time goes for normal mode start at 34 minutes to 30 minutes left then drops to 20 minutes then goes down to 17 minutes left then suddenly it stops and says complete. so the normal mode doesn't do the whole 34 minutes for normal mode instead it only operates for 7 - 8 minutes and the cycle is complete but the clothes are still damp or wet.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 113 Answers
Yes, I believe the "normal" setting is part of the sensor dry. So, if the sensors, bars located on the inside of basket, do not detect moisture, the time will decrease and eventually stop. Locate the sensor bars, get some scotchbrite pad, and lightly clean the two metallic "bars" on the inside of drum. I find alot of buildup from dryer sheets inhibiting the conductivity of the sensors. I would start from there. If that doesn't fix it then you may need to call for service. hope this helps.
Posted on Sep 29, 2010
Does this model support printing on 34" paper?
The printer will support the following media sizes:
Roll paper (width) -
ISO: A3, A2, A1, A0,
JIS: B2, B1,
ARCH: 24", 36"
Others: 10", 14", 16", 17"
Cut sheet -
ISO: A4, A3, A3+, A2, A1, A0, B4, B3, B2, B1,
DIN: C4, C3, C2, C1, C0, JIS: B4, B3, B2, B1,
ANSI: 8.5 x 11", 8.5 x 14", 11 x 17", 13 x 19", 17 x 22", 22 x 34", 28 x 40", 34 x 44",
ARCH: 9 x 12", 12 x 18", 18 x 24", 24 x 36", 26 x 38", 27 x 39", 30 x 42", 36 x 48",
Photo: 20 x 24", 18 x 22", 14 x 17", 12 x 16", 10 x 12", 10 x 15", 8 x 10", 16 x 20" (US Photo size), Poster: 20 x 30", 30 x 40"
Dec 16, 2010 | Canon imagePROGRAF IPF720 Printer
Hello, When i on my lappy,it didnt start directly as usual and it will be suddenly off. And i need to on again and again by using Last Known Good Configuration or start your laptop in normal...
Press windows Key third key on bottom left and press R key at the same time. Type last known good configuration in box and hit run. This should clear it or you can set it back to a known last configuration as by date and time you knew it was working properly.
Jun 08, 2017 | Computers & Internet
It seems that the temp more often goes up to 20-30's and that food is not as frozen when I check it. When temp goes up I check it for next couple of minutes and usually within 10 min the temp is back down...
This is normal. All commercfial freezers must defrost 3 to 5 times a day, or they will freeze over at the coil and then stop freezing. A timer in your freezer turns off the compressor and turns a heating element on for 10 to 15 minutes. During that time the coil heats and melts frost from the coil. Usually within 30 minutes the temperature will briefly rise to 20 t0 25 degrees F and then quickly drop down to 0 degrees F. The food rarely defrosts in this short period of time..
Sep 01, 2010 | Turbo Air 23 cu. ft. / 651 liter...
Model MDE5500AYW. Seems like dryer occasionally overheats when in sensor dry mode. Lint screen and vent are clean and plenty of air flow. One time the sensor works fine (minute timer drops and unit shuts...
there isn't a timer on this machine,you have a control board,if the time isn't counting down correctly sounds like you have a bad control board that's inside the console
Feb 10, 2010 | Maytag Neptune MDE5500AY Electric Dryer
STR-DE445 Works, but goes into protect when you turn up/down volume
This is a piece of **** unit. Mine only works on the left side, sometimes. When those times are I have NO idea. It doesn't seem to play 5.1 correctly and it goes into speaker protect mode for NO reason. It is TRUE lemon !!! ..let me know if you have any other problems with this JUNK .....schafe1001@aol.com
Aug 28, 2008 | Sony STR-DE445 Receiver
If its new call Sony and get service????????????
Washer time-down problem
Check to see if your machine is connected to cold water, it should be. The problem could be the electronic thinks the machine is always connected to cold water at about 20 degree c. if connected to hot, the time drop if the it would take to heat the water to the incomming temperture Good luck
Aug 14, 2007 | Miele Touchtronic W1213 Front Load Washer
Whirlpool Duet 7.0 Cu. Ft. Capacity Plus Electric Dryer Logo
155 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
