Question about Toshiba e-Studio150 Copier
Maintenance counter is on display. How do i clear?
    Problem Solver:
  • 17 Answers
How can I solve maintenance call m2 bizhub 185
As it says you need to call a service agent out.
Feb 21, 2017 | Office Equipment & Supplies
How to solution services call m1 for Konica Minolta 164
11.5.4 MAINTENANCE COUNT.
A. Use
• To display the count of the maintenance counter.
• When the counter reaches "0", maintenance call M1 or the service call will appear, according to the setting on MAINTENANCE COUNT. of SERVICE'S CHOISE.
See P.85 below
e
• To enter an appropriate counter value (0 to 999999) as the tentative maintenance time.
• Specify the setting on maintenance counter to "1" or "2": If the maintenance life is
reached, the maintenance call (M1) or service call [Call Service (M1)] will appear.
"0" : Not counted
1 : Counted (The maintenance call display is given when the counter reaches 0.)
2 : Counted (The service call display is given and the initiation of any new copy cycle
is inhibited when the counter reaches 0.)
NOTE
• The counter value is decremented until it reaches -999999 even after it has
counted 0.
B. Procedure
• The default setting is 0.
• When "1" or "2" is selected, a screen will then appear to allow the counter value to be
entered.
• To clear the count, use [CLEAR DATA] of the SERVICE MODE.
Procedure below to enter::
11.2.1 Starting procedure
1. Press the Menu/Select key.
2. Press the following keys in this order.
Quick Settings Quick Settings left arrow twice the right arrow then left arrow
11.2.2 Exiting procedure
• Press the Back/Stop/Reset key as many times as it is required to display the initial
screen.
11.2.3 Changing the setting value in SERVICE MODE functions
1. Select the desired item using [??/??/??/??] key.
2. Select the setting value using [??/??/??/??] key.
3. Validate the selection by pressing the Menu/Select key.
4. To go back to previous screen, press the Back/Stop/Reset key.
Sep 29, 2016 | Konica Minolta Office Equipment & Supplies
T630 clear counter
The following will reset the maintenance count after you install the maintenance kit, you can not reset the printer total page count. Press and hold down the [Select] and [Return] keys while powering on the printer, hold these buttons until the display reads "Performing Self Test." If the display readds "80 Schedules Maintenance", press the [Go] to continue past this message and access the Configuration Menu. Press the menu button until the display reads "Reset Maint Cnt" on the second line of the display and press the [Select] button. The top line of the display should now read "Reset Maint Cnt" and the second line will read "Reset" and press the [Select] button. This will reset the counter. To exit out of the "Configuration Mode" cycle the power.
Apr 15, 2013 | Lexmark T630 Laser Printer
Printer unable to clean
This most likely means that the over flow tank is full. You can order a replacement tank but you have to disassemble the printer pretty far to get to it. You would also need to reset the counter so ..... if you want you can just reset the counter. Doing this without replacing the Ink Absorber will mean that once it is truly full it will leak into the printer itself. Do so at your own risk, but then again these are cheap printers....
Brother Maintenance Mode Commands:
- Quickly press Menu/Set * 2 8 6 4 to enter maintenance mode.
- Display should read maintenance.
- Press one or more of the maintenance mode commands below. After each command display should read re-init for a few moments then redisplay maintenance.
- Press 99 to exit the maintenance mode.
Maintenance mode commands:
01 Full RAM clear (see 91 below for retaining user programming)
02 scanner initialize (feed a white sheet, then a black sheet)
05 white level
09 print test
10 modify soft switches
11 print configuration list
16 panel test
19 CML test
20 signal test
21 tonal test
23 filter RX
54 scan edge
55 scanner area
66 test print memo
75 display drum life (if enabled on laser models)
76 reset drum life counter (laser models)
91 parameter initialize (user programming remains intact)
95 protection
99 Exit maintenance mode"
I would use the 01 and reset everything. Otherwise you can go through the 91 parameter list till you find the counter.
Jim
May 11, 2011 | Brother MFC 420CN All-In-One InkJet...
I REPAIR THE MACHINES IN AFRICA SO I NI THE ERROR RESET CODES
Perform the following procedure to enter the simulation mode.
"#" key Interrupt key "C" key Interrupt key
Main code Start key Sub code Start key
Usual "reset" codes:
14 - Trouble cancel (except for U2)
16 - U2 trouble cancel
20 - 01 Maintenance counter clear
24 -01 Jam total counter clear
02 Trouble memory clear
04 SPF counter clear
06 Paper feed counter clear
07 Drum counter clear
08 Copy counter clear
09 Printer counter clear
13 Scanner counter clear
14 SPF jam total counter clear
42 01 Developing counter clear
There are codes and subcodes.
example if yiu want to clear the maintenance counter , you have to enter simulation mode and then enter 20 / Copy key /01 /copy key.
I hope it helps you.
regards,
Adi
Nov 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
Need to reset the drum counter on the AL 1740 sharp while changing to a used drum
Entering in the simulation mode:press Clear - Interrupt - 0 - Interrupt -Main code - Start -Subcode - Start.
When the clear all key is pressed the simulation mode is cancelled.When the interrupt key is pressed,the proces is interrupted and the screen returns to the subcode entering display.After cancelling the simulation mode be sure to turn OFF/ON the power and check the operation.
Main code 20 subcode 1 =Maintenance counter clear.
Main code 21 subcode 1 =Maintenance cycle settimg
subcode 2 =Mini maintenance cycle setting.
Maincode 22 subcode 1 = Maintenance counter display
subcode 2=Maintenance preset value display
subcode 3=Jam memory display
subcode4=Total jam counter display
subcode 5=Total counter display
subcode 6=Developing counter display
subcode 7=Developing preset counter value display
subcode 9=Paper feed counter display
subcode 12=Drum counter display
Maincode 24 subcode 1 =Jam counter clear
subcode 2=Trouble memory clear
subcode 7=Drum counter clear
subcode 8=Copy counter clear
Maincode 26 subcode 22=Language setting
Maincode 42 subcode 1=Developing counter clear
Maincode 43 subcode 1=Fusing temperature setting
Maincode 46 subcode 1=Copy density level adjustment
subcode 19 AE mode picture quality change
Nov 20, 2009 | Sharp AL-1641CS Laser Digital Copier
How do you enter simulation mode and the code when you replace developer on lanier 7313.
Press C00C or C interupt key 0 interupt key and 41 for developer counter display 42 for developer counter clear 46 for exposure level adjustment 72 for maintenance preset counter setting 25 for automatic developer adjustment. 40 for developer preset counter display.
Nov 10, 2009 | Lanier Office Equipment & Supplies
What is "Maintenance required. Code: AA"
Maintenance timing display The message of maintenance execution timing is displayed when each counter reaches the set value. The relationship between the messages and the counters is shown blow. Maintenance counter AA WhenThe maintenance counters (both of total and color) reaches 90% of the set value of SIM21-1 (When the setting of SIM26-38 is ?print stop?). When The maintenance counters (both of total and color) reaches the set value of SIM21-1 (When the setting of SIM26-38 is ?print allowing?). Enable ? After completion of the maintenance, execute SIM 24-4 (Maintenance counters (total, color) clear).
Aug 29, 2009 | Sharp MX-2700N Color Copier
Need to clear the error code "replace Fuser" Fuser is new and so is the paper tray cannot seem to get the darned thing to clear
Put the MFC into Maintenance Mode
Press the Menu and Start Keys at the same time then press the up arrow key 4 times the machine should display "Maintenance " in the LCD display
Press the 8 key twice, Display should show Part Replacement
Press up or down keys to select "Reset Fuser" press OK or Start Key to reset the counter of the fuser
To Exit Maintenance Mode press the 9 Key twice
I hope this helps.
Aug 20, 2009 | Brother MFC-8460N All-In-One Printer
Service mode
Hello:
All I have access to is the Toshiba Version of your machine but I think maintenance mode is the same.
This is the excerpt from the relative info in the service manual.
Example:
Basically you press # * c * ( to get into maint. mode
Press 20 Start 01 start (then the maintenance counter will clear)
I hope you can figure it out
The drum and dev counts are below
To enter the serviceman test command mode, press the keys as follows:
[#] key [*] key [C] key [*] key
To cancel the test command mode, press the [CA] key.
[10KEY]:(number pad) Entry of MAIN CODE/SUB CODE
Selection of an item
Setup of an adjustment value in case of test commands for adjustment
[/]: Selection of MAIN CODE/SUB CODE
[OK (ENTER)/START]: Settlement
<In case of test commands for print>
[OK (ENTER)]: Settlement (Without print)
[START]: Settlement/Print
[C]: (Interrupting operation check) Returns to the upper hierarchy.
In case of test command of operation check, terminates the operations.
[CA]: Exits from the test command mode.
For a test command of adjustment, the display returns to the initial display (00-00).
20 01 Maintenance counter clear (M-CNT CLR.)
24 06 Developer counter clear (DVLP CLR.)
24 07 Drum counter clear (DRUM CLR.)
Mar 12, 2008 | Sharp AR-168D Copier
37 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
