Question about Dryers
How do I remove the front panel to a 80 series kenmore dryer
  • Dryers Master
  • 3,740 Answers
Download this Job Aid L68 and see page 20 of the pdf File for removal of the toe panel.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
For removal of the top panel see page 14 and for removal of the front panl see page 24.
Thanks for choosing FixYa.
Kelly
Posted on Sep 30, 2010
DRYER LIGHT IS OUT IN KENMORE 80 SERIES DRYER HOW DO I REPLACE IT
if your front cover can be removed by removing two screws on bottom then you can get access to light if not check and see of you can unscrew light ficture its self for access
Dec 11, 2014 | Kenmore Series 80 Creme Front Gas Dryer...
Kenmore 80 series electric dryer. metalic sound/burning smell
drum bearing on the rear has gone making the front of drum rub on the caseing re metalic sound
Aug 17, 2012 | Kenmore Dryers
My kenmore dryer 80 series will not start please tell me were to look for the duct fuse
if its the one like on the picture, take off front bottom panel and remove lint filter cover, the fuse sits on top of blower housing on left side!!!
Jun 24, 2011 | Kenmore 63942 Dryer
I have a Kenmore Electric Series 80 Dryer that the drum inside won't turn but it heats up and smells hot like something is burning. I can however turn it manually.
Remove the top and the front panel to remove the drum after you purchase a belt and teh idler pulley that Sears selles for your dryer. The pulley's bearing has froze up causing the belt to burn up and falling off
Jan 22, 2011 | Kenmore Dryers
How do I take the top off of a Kenmore 80 Series?
You remove the back panel that is how your get to everything. once the back panel is removed you will be able to put the belt and the idler pulley on. Please rate
May 24, 2010 | Kenmore 64852 Electric Dryer
Kenmore 80 series dryer. The drum will not turn.
You Take the front off.Screws under endcap trim ,flip console back. Remove screws along vack and top slides forward. take bottom panel off and then door and front panel.
eric
Jul 04, 2009 | Kenmore 63942 Dryer
How do I remove the front panel from my kenmore 80 series dryer to replace ignitor?
Either you have to pry the top up with a wide flat screw driver or two screws at the very bottom of the front panel. Whichever it needs to be done the other end will be hooked in place. make sure you remove door switch wires before taking front panel off all the way. Good Luck
Feb 28, 2009 | Kenmore 63942 Dryer
Dryer belt broke on my kenmore series 80
With the front cabinet panel off, place the drum against the back and on the rear rollers. The roller on the right will sometimes move toward the rear so reach from underneath and pull it forward. The rollers should sit in the groove. The drum will tilt forward but shouldn't fall off. Route the belt around drum, pulley and motor. Tilt the drum back and support it while placing the front panel back onto it's hooks. With the front panel on (don't screw it on yet), rotate the drum by hand to make sure the seal is not kinked and the belt won't slide off the pulley or motor. If all is well screw in the front panel and re-assemble the rest.
Feb 16, 2009 | Kenmore 62622 Electric Dryer
Kenmore Gas Dryer will not start
i would check the thermal fuse on the back of the dryer where the vent come out remove the back panell it is a small white with2 blue wirs most of the time and one screw holding it in un less you dryer does not have a removeable back then there is a removable front cover acrose the bottom remove it and the fuse is on the blwer housing the in the front should look the same and described above.
Jan 19, 2009 | Kenmore Dryers
Kenmore 80 Series Heavy Duty Dryer won't work
hi thanks for the question the belt has probably broken there should be a bottom panel use screw driver to pry the front on each side pry outwards remove panel now you should see a broken belt replace thanks the appliance dod
Sep 25, 2008 | Kenmore 63942 Dryer
Dryers Logo
191 people viewed this question
Top Dryers Experts
