Question about Jensen Q2049J 20" TV
My jensen tv all of sudden has a blu screen with a lock symbol on the corner, it does not want to change channels or anything
  • 2,200 Answers
To remove the lock on the Jensen simpy press and hold the Display Button on the remote for at least 3 seconds whilst pointing it at the TV.
The lock will be removed and the TV will resume normal operation..
Please do leave a vote for the solution. Thanks for using FixYa
Posted on Jan 23, 2011
My screen is all blue, no image and voice. a lock on the upper left corner
It sounds that your TV is locked by someway. Just unlock it. Proceed the following.
Many Jensen TVs have a parental lock that can be set to stop children from watching certain television shows or channels. In order to activate or deactivate the controls, you have to know the four-digit code or parental lock passcode. If you forget the passcode or if the lock gets set accidentally, you can still unlock the TV.
• Turn on the TV using the remote control. In most cases, you will need the original Jensen remote to unlock the TV if you aren't sure of the unlock code. You can purchase an original replacement online if necessary.
• Look at the screen. If you see a red key on the bottom of the screen, press "Function" and "Mute" on the remote at the same time. This will unlock the channel. Do this if you want to bypass the lock to watch a certain show or channel while leaving the TV locked. All other channels will remain locked and the TV will lock again when it is turned off.
• Unlock all of the channels on the TV by entering 0711 or 3308. These are the Jensen factory reset codes that will reset the TV to the original factory settings. By doing this, you will loose any information that you have stored in the TV, such as channel labels and schedules. You will have to program the TV again by going through the entire initial set up.
•Call the technical support service number in your owner's manual if neither of those codes work. A technician can help you troubleshoot the television as the problem may not be the parental lock feature. Have the model number and serial number of the TV available when you call.
• Take your television to a TV repair shop if neither of the codes work and the TV locked by itself while it was turned on. In this case, the TV may need to be rewired.
Sep 27, 2012 | Jensen Q2749J 27" TV
Parental control code had been changed, don't know what it is now
Hello
Try the following to unlock your Jensen TV.
1. Turn on the TV using the remote control. In most cases, you will need the original Jensen remote to unlock the TV if you aren't sure of the unlock code. You can purchase an original replacement online if necessary.
2. Look at the screen. If you see a red key on the bottom of the screen, press "Function" and "Mute" on the remote at the same time. This will unlock the channel. Do this if you want to bypass the lock to watch a certain show or channel while leaving the TV locked. All other channels will remain locked and the TV will lock again when it is turned off.
3. Unlock all of the channels on the TV by entering 0711 or 3308. These are the Jensen factory reset codes that will reset the TV to the original factory settings. By doing this, you will loose any information that you have stored in the TV, such as channel labels and schedules. You will have to program the TV again by going through the entire initial set up.
4. Call the technical support service number in your owner's manual if neither of those codes work. A technician can help you troubleshoot the television as the problem may not be the parental lock feature. Have the model number and serial number of the TV available when you call.
5. Take your television to a TV repair shop if neither of the codes work and the TV locked by itself while it was turned on. In this case, the TV may need to be rewired.
OK.
Mar 14, 2011 | Jensen 143307 Remote Control
I have a 3423 graetz tv my daughter did something that locked the tv i can't turn the voulme up or anything from the tv except turn it on and off. i dont have the orignal remote so i'm using a...
Do the buttons on the actual TV do anything? Try for example just turning up or down the volume, or changing the channel using the TV's built in buttons. If nothing functions with those then you have some larger issue with the TV.
Let me know what you find, just reply here,
Thanks
Tim
Oct 27, 2010 | Televison & Video
All of the sudden my Jenson has a red lock icon in the upper left corner.The TV was given to me so I do not have any sort of lock code set up.
Unlock all of the channels on the TV by entering 0711 or 3308. These are the Jensen factory reset codes that will reset the TV to the original factory settings. By doing this, you will lose any information that you have stored in the TV, such as channel labels and schedules. You will have to program the TV again by going through the entire initial set up.
Good Luck,
--Matt
Jun 17, 2010 | Jensen TS2050J 20" TV
Kids locked up the TV, need code to unlock it.
Try this: press "Function" and "Mute" on the remote at the same time. This will unlock the channel. Do this if you want to bypass the lock to watch a certain show or channel while leaving the TV locked. All other channels will remain locked and the TV will lock again when it is turned off.
Apr 21, 2009 | Jensen JER-323 Remote Control
User Manual for Jensen JER-321 codes my jensen tv has a lock symbol on the upper right hand corner and i can't get it off. i have the remote but i lost the manual, what do i do?
i found the answer to my problem on one of fixya's message board.
THANK YOU. i turn on the tv using the remote then i pressed on the display key and a miracle happened, my tv was working.
May 27, 2008 | Jensen 143307 Remote Control
Hello tv channels problem
I to am running into the same problem- suddenly my tv is blue with a little lock in the corner and I can not get it unlocked.
Dec 27, 2007 | Jensen TS2750J TV
Can't undo the parental lock
try holding "display" on your remote control for 3 seconds.
Sep 01, 2006 | Jensen TS2050J 20" TV
Jensen Q2049J 20" TV Logo
51 people viewed this question
Top Jensen Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
