Question about Mitsubishi WS-55809 55" Rear Projection Television
I had the 2 2 error code and replaced the two IC's and the 5 amp pico fuses in 4 and 5. Set worked fine for several days and then came up with 2 4 error. My son watched tv last night with no problem and now it won't turn on again and has 2 2 error. Both pico fuses are blown again. Any ideas?
    Master:
  • 473 Answers
Issue with Capacitor Filter Chec Hi Voltage Panel for Fail Capacitor ...check for Heat sink Over Heat.. check white balance and voltage regulator
Posted on Sep 30, 2010
  • carlin_carpe Sep 30, 2010
    Can you give me more specific instructions on how to check these issues. Thanks, and thanks for the quick reply.
Replaced Convergence chips, same problem
This set has pico fuses on convergence board and also on G power board, there should be 2 5 amp pico fuses on power board.
If convergence is bad exactly as before double check the power board fuses and check to see if voltage (it is marked!) is there with power board disconnected from chassis..
Steve
Mar 01, 2012 | Sony KP-61HS30 TV
I replaced the STK chips and one pico fuse that was blown on the input power board (the fuses and resistors near the STK chips are fine). I turn the power on, no screen and I get sound for 1 second, then...
A blink of 4 times is an error code that there is no vertical deflection. There may still be a problem with the + or - 15 volt supplies. This error is generate when the vertical deflection pulse is missing. there might be a problem with ic 8003 wich is the vertical drive ic. this chip generates a signal witch is detected by transistor q 8001 check pin 3 to see if you have 4 volt stop signal
Mar 07, 2011 | Sony KP-51WS500 51" Rear Projection...
The green timer light flashes when i plug in the tv, after hitting power the timer light comes on for about 4 sec then goes out. Tv does not power up, the error code it blinks is 2 blinks a pause and 2...
MODEL NUMBER WT-46809:
2,2 is the error code for short protection.
The most common reason for this is one of the 2 pico fuses that protect the convergence circuit is blown. Changing the fuses will not help! They are green in color and soldered into the middle circuit board and are F9a04 and F9a05----look like resistors but are 5 amp fuses.
99% chance if one or both are blown---you have to have someone change the STK-392-570 convergence IC'S that this set uses----the IC'S can be purchased on Ebay for under 14 dollars and the same seller sells the pico fuses 5 @ 2.95.
The best thing to do here if you or someone you know is able is to unplug the set and look for the fuses---middle board towards the back---there are 5 of them and the two closest to the back of the row are for the convergence IC----If someone checks them (like testing any other fuse) you will know--if either or both is blown--the convergence IC got them.
I have start to finish, step by step instructions and photos of the fuses etc----If you or someone you know can solder and is handy--you may be able to do the repair yourself.
If not, shops usually charge 300-400 for this kind of repair in this set.
LET ME KNOW IF YOU NEED ANY ADVICE or help.
Regards, SD TECH
Oct 28, 2009 | Mitsubishi WT-46809 46" Rear Projection...
I have a Mitsubishi ws-55711 I push the power button and the light goes on for a second and goes out. I did the diagnostic check and it shows 2 blinks then 2 blinks. Do you know if this is the fuses and if...
99% chance if one or both are blown---you have to have someone change the STK-393-110 convergence IC that this set uses----the IC can be purchased on Ebay for under 14 dollars and the same seller sells the pico fuses 5 @ 2.95.
Regards, SD TECH
Oct 26, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsu WS-65909 COMES ON AND TURN OFF IMMEDIATLY, ERROR CODE 2-2
Two blink code on this set means Usually one of the two pico fuses that protect the STK-393-110 CONVERGENCE IC is blown--the fuses will need to be tested and the chip and them replaced--
If you have enough skill I have step by step start to finish instructions for this repair in this set---set detects one of the voltages to the Chip is not there and shuts down instantly. I have photos of the chip, fuses and protect resistors this set uses also.
If you want the instructions for free give me a email and I will send them to you for free--if you are able to do this repair yourself you will save a lot of money--you can buy the chip on Ebay for about 14 dollars plus shipping and the same seller sells the pico fuses..............
If you want to attempt this give me a vote here--If you are not able to do it yourself I have suggestions for you about getting the set fixed--I have done hundreds of these sets!
Just reply to this post here.
Let me know what you want to do, I am here to help people
SD TECH
Sep 19, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-65611 IC's replaced
this set has a self diagnostic feature; when you turn it on and the green light goes out--push menu and device(or input) together for 5 seconds. the led for power should blink an error code. The most common is 2, pause and 2---this means something is shorted. If the set functioned before you changed the stk--you may have a new IC that is shorted--this IC is protected by two pico fuses usually marked as fao4 and fao5----they are about 3 inches behind the IC and are marked 5 a(they are green in color and do not look like fuses) also check all the 3.9 ohm blue resistors in front of the Ic--if any are white in the middle they are gone and the new IC got them. you did not remove the board? you tilted the entire chassis up to get at the IC? take a good look to make sure you did not pull any plugs loose---check for the error code first and let me know what it is. Best way to do this repair is to remove the entire board from the plastic frame---takes a little longer but is safer way to get it done. If one of the pico fuses is blown you will check it just like a regular fuse--an open fuse will suggest short and the set will shut down with 2, pause. 2 errror code.
Aug 18, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsuibishi WS65809
The only items on your set that should need replacement would be both convergence IC IC801 and IC802 which are both STK392-570 and you will also need to change the two 5 Amp pico fuses which are F9A04 and F9A05 they are both % amp pico fuses. All parts are located on the center Board
Oct 23, 2008 | Televison & Video
Mitsubishi WD-62525 Red Status Light After Cap Replacement
A steady red light: there is a short on the DVI cable from FMT to DMD disconnected
Sep 09, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
75 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
