Question about Patton PUH9907B-U 1 Touch Utility Heater
I have a new PUH 9907B that has a very slow running motor. When in the low heat mode, the motor stops and the high heat sensor shuts the unit off. Is this a motor fault or control problem? What is the solution?? Thanks in advance, Glen T SHelby
    Master:
  • 473 Answers
Issue with Voltage Regulator Motor Maybe Damage also check thermoresitor potentiometer The ceramic plate get to hot and brake ...
Posted on Sep 30, 2010
Flashing light the at says e6
Usually Indoor Unit Anti-freezing protection (Cooling
Mode) or Over-heating Protection (Heating Mode)
for Evaporator
A) Indoor room
temperature too low
under cooling mode,
Too high under
heating mode
B) Indoor unit filter or
evaporator too dirty
C) Indoor unit fan motor
blocked
D) Insufficient refrigerant
under cooling mode
E) Indoor unit evaporator
sensor wrong
connection or failure
Jul 28, 2014 | Samsung AQV12VBE Vivace Wall Heat Pump Air...
This is a Unico AIR HANDLER in a residential application with heat / cool unit in the attic. With system off (not calling for cool) and fan in auto mode, the blower fan is on high speed only constantly....
Sounds like a sticking relay. You can check the stat simply by remove the faceplate. If fan still runs with tstat cover off its not the stat. Not sure is your blower has a separate relay or if relay is mounted on control board. This can be bypassed with a new relay if you are willing. Good luck!!
Mar 26, 2017 | Heating & Cooling
Heatpump r-22 rudd system,unit runs starts out heating then compressor stops in middle of heating ,this unit has a out side air temp. sensor just wondering if possible bad board or not
If compressor stops in middle, check the following.
1.Thermostat setting must be minimum +3 degree than your room temp
2. Check it's in heat "mode"
3. Check indoor and outdoor coils are clean.
4. Check fan motor is working alright.
5. Outside sensor and room air sensor is placed correctly.
6. Gas pressure is o.k
7.Check compressor is overheated, even all the above is o.k.
Jan 12, 2011 | Ruud UAPA024 Air Conditioner
1994 Carrier 58 PAV
sounds like the relay for the unit may be bad, usually if a blower motor goes it stops or has a very loud humm and only goes slow
Aug 03, 2009 | Heating & Cooling
P8 eroor code
P8 error is abnormal pipe temperature indoor. If you are running it on heating P8 error will appear because the disc pressure is too high. It could be overcharged.
May 31, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Duo Therm Quick Cool A/C fan motor cycles from low to high
sounds like the motor is either wired incoirrectly and getting 1/2 power all the time or it is going to ground. check out the woiring real good and duse your ohhm meter to check for gounds.
Dec 20, 2008 | Dometic Rooftop RV Air Conditioner
High Pressure cutoff
YOUR OUTDOOR FAN MOTOR SHOULD NEVER SHUT OFF IN THE AC MODE. IT IS SUPPOSED TO SHUT OFF IN THE HEAT MODE WHEN ITS IN DEFROST. IF THE UNIT IS RUNNING IN COOL AND THE OUTSIDE MOTOR QUITS ,THE COMPRESSOR WILL QUIT SOON AFTER. EITHER THE RUN CAPACITOR FOR THE FAN IS BAD OR THE FAN MOTOR ITSELF IS BAD, IF CAP IS GOOD THEN THE MOTOR IS At FAULT. THE OUTDOOR PRESSURE SWITCH CAN ALSO OPEN IF THE INDOOR FAN MOTOR FAILS IN HEAT OR THE FILTER IS PLUM NASTY in heat OR THE INDOOR COIL IS PLUGGED UP in heat.. THE PRESSURE SWITCH USUALLY TRIPS AT 400 TO 425 SO ITS WORKING CORRECTLY. YOU MAY BE CONFUSING THE ISSUE SAYING THAT THE AIR IS HOT AND COLD INSIDE. IT IS COLD WHEN AC IS RUNNING HOT WHEN HEAT PUMP IS RUNNING IN HEAT BUT ESSENTIALLY not cold or hot if compressor isn't running, but a lot of folks describe the lack of cold air as hot when the compressor isnt running. but it basically is warm or house air temp.you test the capacitor with a capacitor tester or take it to motor shop and let them test it. odds are its a 5 , 7.5 or a 10. it should test within 10 % of rated value . ask for a RESCUE brand replacement motor. they are great ,reversable etc.carefully oil and sand the motor shaft and note exactly where the blade was located in relation to the grill so you get it back just the same. usually they wire up black to a leg of 220 power. white to the other leg of 220 power. brown and brown with white stripe to the capacitor.you can also pull whole fan shroud assembly on some units and take whole thing to motor shop and let them test motor cap, replace and all you do is return to unit and connect two power leads,
Oct 26, 2008 | Heating & Cooling
Coleman tsr mach 3 RV Air Conditioner
the fan motor bearings need lub....the shaft has a tiny access hole to put some oil into. because the fan shaft is slowing down, it is putting more strain on the voltage current, and eventually the internal breaker shuts down the ac........plus your condenser is not getting enough air accross it, compressor heats up, and it too will shut the unit down......older units have to be oiled every year, and eventually it too will fail, and a new blower motor assembly is needed or replace the ac unit.....blower motor units are around $130....now you install it or pay to have it done at around another $150 labor,,,,,try yourself, if it fails then call the tech........let me know ..ray..yyzazz@ao.com
May 20, 2008 | Coleman Mach 15 Air Conditioner
Carrier furnace weathermaker 8000
. Several times of recyling power normally brings the furnance up. Though the failure code has always been 31, there are several different behaviour when the blower starts after reset :
a. blower simply creases.
b. there is an attempt to start the heating unit (I hear the high pitch noises), then everything stops.
c. there is an attempt to start the heating unit (I hear the high pitch noises), once I see the orange glow from the coil, normally the gas is lit up and the unit starts working.
Nov 23, 2007 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
Top Patton Heating & Cooling Experts
Mack Baxter
Jay Finke
Jay Finke
jeff5may32
Are you a Patton Heating and Cooling Expert? Answer questions, earn points and help others
