Question about Hitachi 60VX500 60" Rear Projection HDTV
I recently moved and now my TV has a blue streak going through the left side and only about 60-70% of the screen is visibile
    Master:
  • 473 Answers
Issue with Board Connection Possibility IF board defect ...Check pin terminal for reading scale
Posted on Sep 30, 2010
Left side screen black out
Possible failure of the driver, open and check for visibile failures of a fusible link to the main voltage for the driver.
Check if there is any connecctors that are not contacting and cutting off the screen,
finally it is possible that the screen was damaged by any reason, was the set moved?
Sep 24, 2010 | Sony Bravia KDL-40S4100 40 in. LCD TV
The blue will not converge, how can I manually do it? The blue appears to be showing bottom left corner below the screen, like it got moved.
I had the same problem but it wouldn't converge on the whole right side of the screen. I fixed my problem by taking off the speaker cover, removing the 3 allen 7/64" screws from the front of the bottom of the button pannel, then removing the 4 scew from the back of the pannel (2 on each side), and the button pannel should drop down. With the power on I cleaned the 3 projection lenses with many qtips dipped in alcohol. I left the TV on so I could see if there was any streaking on the lenses (streaking means it is still dirty). Once they were all clean and I put the button pannel back on, I went to the menu and ran the autoconvergence function. Now my picture is so clean. Good Luck.
Mar 03, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Blue streak now double vision on outside.
coversion amp ic have died you need to call al tech to replace them parts are cheap but labor is going to get ya
Sep 20, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Blue streaks, looks like a spill from the top
light engine is defective.try cleaning lens first.
Jul 28, 2009 | Panasonic PT-47WX49 47" Rear Projection...
HITACHI ULTRASCAN HD TV w/Model # 43FDX01B (Digital ProjectionTV)
i am not sure these is going to work but give it a try. after useing the tv for a long time you can get a problem with the lineing of the three picture colors may drift away from each other causeing the problem you have, they move because of moveing the tv or the viberation of the tv.  you can to one of two things if you have a remote for the tv go to the menu and look for the convergence adj. setting then you are going to get close to you tv and press the small but the says the same thing now on the screen you are going to see a grid the you can fix youself with the remote just by pressing the up, down,left, rigth buttons and the menu button to change the color, to aline the red line and blue line with the middle line till you get only a white line going up and down  if the doesn't work just unplugg th power cord and what for about 4 hours and then plug it in and turn it on again. if after you do all these if you still have the problem then you either have two choices call to see how much it will cost to repair it or toss it out and get a new one
Mar 19, 2009 | Hitachi 43FDX01B TV
Projection tv - Hitachi
sounds like you need to do convergence.
Feb 21, 2008 | Televison & Video
Blue Streak
I had the same problem w/ the same TV about 6 months ago. You need a new optical engine. Hopefully you are still under warranty. Once that was replaced, the tv looks great.
Dec 26, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi rear proj TV, light blue vertical streak center screen, moves slowly
Sounds like a source problem. What happens when you play
a DVD or some other source??
Need more info? Always give Model # and age----T.
Nov 03, 2007 | Televison & Video
42" philips plasma flat panel television
same problem anyone know what his is please send me an email. real unhappy!!! this tv cost me $900!!!!! rami7344@bellsouth.net
Oct 22, 2007 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
PT-47WX, Blue streaks across the screen?
It is not a bulb. It is a picture tube. If there are thin blue lines across the entire screen, not just the edges, and the picture itself looks too blue, it means that the blue picture tube is being driven too hard. This could be because the blue screen voltage is too high, the boost voltage on the blue picture tube is too low, or the video output is leaky or shorted. If the picture has what looks like blue arcs and double images on one or more sides of the picture, it means that one of your convergence IC's has burned out and needs to be replaced. These are things that should be tested and serviced by a qualified tech, so allow an experienced tech to handle it for you.
Sep 07, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Hitachi 60VX500 60" Rear Projection HDTV Logo
106 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
