Question about Coleman Powermate 11 Gallon Air Compressor
I have the Coleman Powermate 11 gallon air compresser, and it just stopped working. I checked all the connections inside, it doesnt need oil, thats one of the new technologies they gave it I guess. Doesn't even turn when I flip it on. I'm not using any extension chords. Do these have fuses? If they do where are they located at, I was thinking maybe that was the problem...
I have the same problem and discovered that a green fuse in the field coil circuit was blown. I am looking for a replacement fuse.
Len
Posted on Jul 22, 2013
    Master:
  • 473 Answers
Check carefuly for Reset button on the unit or check for fuse ...Sometime its the safety valve stuck inside the panel..but carefull dont bypass it ...it will make your reservor explose it make sure you dont overload the tank ..
Posted on Sep 30, 2010
    Brigadier General:
  • 4,088 Answers
A lot of motors have circuit breakers built into them--look for a push button on the end of the motor shell opposite the shaft end and push it in. If it clicks, then retry to start. If the button doesn't exist, or has no effect, try to turn the compressor by hand (power shut off). It should turn fairly easily. Most compressor motors use a capacitor to allow more power at start--if bad the motor will not run, but will hum loudly until the circuit breaker trips. Be sure to check the circuit breaker for the circuit that the machine is connected to. It's possible that the air pressure switch has failed causing no start. Hope some of this helps!
Compresser runs but won't build up pressure
check gauge it could be bad. but if it is working the compressor is bad they sell parts to fix if you are handy
Jan 28, 2013 | Coleman Powermate 11 Gallon Air Compressor
Wont run while under load
ok buddy i know the problem before the pipe connects to the tank it goes to a valve unscrew this and check the rubber inside turning it around if necessery get back to me51a35be.jpg
Sep 19, 2009 | Coleman Powermate 11 Gallon Air Compressor
Coleman powermate 27gal 5hp air supply line and regulater gets very hot and blowes off hose
Is a shroud of any sort been took of ? is there oil in pump assembly ? Is there a fan on this model? At what pressure does the compressor stop pumping (should be less than 135psi aroud120psi) are you using it over it's duty capacity ei:sandblasting....?
Jun 04, 2009 | Coleman Powermate 27 Gallon Air Compressor
Coleman powermate compressor doesnt hold air
CHECK YOUR TANK PRESSURE ADJUSTMENT KNOB ON TOP A LOT OF TIMES THERE NOT SET AT THE FACTORY.HOPE THIS HELP'S
May 22, 2009 | Coleman Powermate 11 Gallon Air Compressor
Coleman 11 gallon air compressor wont start
Sometimes the initial start up with the tank at 0 psi electric power is adequate. However when the tank is full or the garage is cold it is a bigger load for start up. Check your overload (reset button) and breaker. If 220 volts one side of the breaker could be tripped without showing.
Feb 14, 2009 | Coleman Powermate 11 Gallon Air Compressor
Coleman Powermate 11 Gallon Air Compressor Logo
315 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
