I have an RCA HD flat-screen TV and just bought the rt2770 system. An orange coaxial cable was included, which I hooked up. There's also a white short (eight inches or so) cable, with a straight end and an end that's shaped, for lack of a better explanation, like a hand drill. I have no idea where that goes. My TV runs through a converter box. The options on the main entertainment system don't give me digital, only "anl." Also, there's no sound in two of my speakers, even though they're attached as per color coding, with the proper ends in the proper slots. Any ideas?
    Sergeant:
  • 336 Answers
The most likely explanation for your problem is that the coaxial cable that gave you does not have a thick enough core for your television. It might be RG-56 which has a smaller core than a larger RG-6. I will need to know more information before I can be of further assistance.
All The Best,
RCF
Posted on May 26, 2008
I hooked up my cable box up to my sceptre tv and it had sounds but the picture is black and white I even went and bought the blue and green cords but still only black and white
With the blue/green/red cords (Component) you need to get a very good bright light on the connectors so you get the plugged into the correct COMPONENT connectors on the TV. Note, there are white and red AUDIO plugs right near the COMPONENT input so you need to be VERY careful. If you get it wrong, the colors on screen are often off and even black&white.
How is your cable box connected to the TV? Screw on "COAXIAL", Yellow, Red, White "RCA", single flat connector "HDMI" or 5 colored plugs 2 X Red, 1 X White, 1 X Blue, 1 X Green "COMPONENT"
Jan 08, 2014 | Televison & Video
The coax input on my tv is broken off how can I connect the cable to it other than the red white and yellow cords which don't have a good connection either I have my dvd player hooked up to hdmi is there a...
the simple answer is no.
but if you have basic cable (coax) you could connect it to a vcr, tune the channels with the vcr-
connect the vcr to the TV with composite video (yellow, red/white)
Apr 13, 2011 | Samsung Televison & Video
I wanted to know if there is a way to hook up the sound from a Panasonic DMP-BD655P-K Blu-Ray player to my existing Yamaha DVX C310SW home theater system. I know I can hook the Blu Ray directly to the TV...
Yes this can be done. You have several options for audio hookup. Stereo 2-channel (white and red) RCA cables, digital audio (optical or coaxial) or HDMI. Your home theater must have the inputs available such as optical, coaxial etc. Typically the stereo 2-channel RCA is the simple way. Just connect from the Bluray audio outputs to the Home theater inputs (white and red) for stereo sound. Select the input on the home theater. For Dolby Digital 5.1 use optical digital audio cable (black port) or coaxial (orange RCA port) from Bluray to similar home theater input.
Mar 06, 2011 | Yamaha Audio Players & Recorders
How do I hook up my maxent tv to cable
use 1 of these 4 options
On the back of the cable box there should be outputs
Coaxial ( regular cable wire that screws on)
RCA plugs (yellow red & white )
Component plugs ( green, red, blue for video) (red, white for audio)
HDMI ( on HD cable box only)
After connecting make sure your tv is on the input you connected on the back of the TV
Dec 04, 2010 | Maxent Televison & Video
Dvd player not working with sound
Ok, first thing is to know how it's hooked up. If you used RCA cables, the yellow plug is video, the red and white are audio. Make sure all your connections are "out" on the dvd and "in" on the receiver. If all this is correct, there may e an issue on the audio settings for your unit.
Jul 08, 2009 | RCA RT2300 System
I have a RCA RT2870A that i need a manual or help hook it up to TV and DCD
This is the manual for the 2770 from RCA.com http://www.voxxsupport.com/images/manuals/RT2770/media/RT2770_UMEN.pdf
If it has the same inputs as yours, you need an "optical" cable that will go from the TV "output" to the RCA system "optical input" and a "Coaxial Digital" cable from your DVD player to the "Coaxial Digital input of the receiver. Not knowing what kind of TV you are hooking this up to... If it's and LCD,Plasma, or Digital TV, it will have an optical audio out. if it's not one of these, post the model number of your TV & I'll check it. If you are using Cable TV/Satellite or FIOS, Great! then you can run the optical cable from the back of the cable box to the receiver. If you need any more help, just post a comment and I can help you some more.
Jun 23, 2009 | RCA RT2300 System
My HD only works on my video setting, but I have no sound
Ok so the sound is fine on all of the other sources,
The component is running from the cable box to the amp, and you can see it.
just take the audio Red/Whit RCA out of the cable box, and input it to Cable/TV or whatever its labled, Red White, RCA.
If you want surround, then you will have to go Coaxial((single orange RCA) or TOS out of the cable box to the Digital input on the AMP. When you use this instead of Red White RCA, your amp will automatically switch between the different types of surround depending on what the source calls for or is encoded in.
You may have to get into the amps menu and change that amps input to Digital/Coax/TOS for the surround sound.
Any more specific questions, I need the model #s.
Jan 10, 2009 | Mitsubishi WD52527 52" Projection HDTV
Connecting a samsung dvd-vr to TV with cable & rf modulator
my coaxial cable hook up is broken from the plasma. Can i fix it?
Jun 15, 2008 | Samsung LN-R328W 32 in. HD-Ready LCD...
Connecting Dell speaker system to TV or console
If you have a coaxial out on your TV and a coaxial in on your Speaker system that is the way to go to experience digital surround sound. Radio Shack, etc. has coaxial cables in the appropriate size. If you go to Radio Shack, etc. bring along your speaker system's model number as well as your TV's model number.
Hope this gets you going.
Worldvet
May 18, 2008 | Audio Players & Recorders
Antenna problem
That model requires a HD cable box from your cable company. It does not have an atsc tuner in it. That's why they are lower in price.
Apr 17, 2008 | iLO 3200 32 in. LCD Television
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
