Question about Panasonic Microwave Ovens
Micro has no display or time - Panasonic Microwave Ovens
    Master:
  • 473 Answers
Check for Fuse at the back off the unit ....Possibility damage on Magnetron...or Capacitor fail ...But Carefull Very hi voltage inside if you deside to open it make shure you unplug the Capacitor first because the voltage remain several minute before it complitely empty of voltage.. ..So be Aware ....
Posted on Sep 30, 2010
Sharp R-9H84B-display black, cleared display shows "Conv Mix, 88:88 Auto". Short time all dark again. Hit clear happen 2 times then, all dark, no power, can't clear won't start, nothing works.
R-9H84B - May 29, 2017
I would suggest pulling the control board out and looking on the foil side (opposite the component side) for "ring cracks," most likely on the low voltage transformer's connections.
The board may have the screen-printed reference designator "T1" near the low voltage transformer.
Also be sure the fuse is not easy to turn with your fingertips when it is in the holder. If it is, the fuse holder is too loose and must be replaced (not just squeezed with pliers).
You can order a fuse holder, part number WB06X10034 for $6.49 (subject to change) from the Pros here.
If you have any keypad issues, please note that the membrane keypads for this model have long been discontinued.
FixYa does not directly notify us experts of responses, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 28, 2017 | Sharp Microwave Ovens
Micro does not turn on without external pressure
Likely the door latch microswitch. My micro/convection oven has 4 of these, and they do go bad. I've had to replace two of the switches in 4 years.
May 16, 2015 | Microwave Ovens
How to make clock light brighter oneletrolux micro
youll find over time the fluorescent type displays darken
this is caused by the capacitors on the controller board becoming dried out
you need to replace all the values 1uf - 330uf at least
Aug 12, 2014 | Electrolux Microwave Ovens
My MMV5165BAW displays *** with micro, AM/PM, help..etc under each x. Display flashes this msg. Touch pad will not work, but when it displays to set the clock, touch pad will work. After setting clock
There may be grease or moisture on the the control circuit board, especially in the are where the keypad strip plugs into the board.
Or there may be a pad stuck on th keypad.
See the owner's manual here in case that might help you.
Otherwise, the controller assembly may need repair, which is usually economical.
Jan 30, 2013 | Maytag MMV5165 Microwave Oven
Where are the fuses in my microwave oven,?
Inside behind the display panel on a small circuit board.
Jan 01, 2013 | Magic Chef MCO160UB Microwave Oven
Panasonic inverter nn-cf778s
Demonstration Mode
This is to enable you to experiment setting various
programs. (The letter D will always appear in the display
window. This is to confirm that there is no microwave
power produced and it is safe to use the oven without
any food). To set Demonstration Mode: press micro
power once, then press Stop/Cancel 4 times. To cancel
Demonstration Mode press Micro power once, then
Feb 03, 2012 | Panasonic Microwave Ovens
Boiling waer under micro wave lots of steam into micro wave, turn on micro wave ,pop noise like glass miro wave comes on louder hum than normal no heat
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Mar 03, 2009 | Amana Radarange Microwave Oven
On the face of the microwave that displays the time, we just noticed ////////////along the bottom of the display under the time, we unplugged the microwave and tried to reset it, but no change
ok if memmory serves me correct
press the pause clear button with start button at same time
holding them for 5 seconds the micro should beep then press1 3 5 7 for the reset micro screen its been a while since i serviced a micro but i believe this is correct display reset config for micro
Jun 02, 2008 | GE Microwave Ovens
Display shows nothing, microwave cuts off
You need a couple of cheap microswithes that the door latches hit when you close the door and a new control for your display problem which sharp has had a problem with
Oct 30, 2007 | Sharp R-1405 / R-140 Microwave Oven
Microwave Ovens Logo
24 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
