Question about i-mate JASJAR Smartphone
Xxxxxxx - i-mate JASJAR Smartphone
Chang ur windows it work good any time
Posted on Jun 02, 2008
I have a Mercedes engine # 130 016 2601. What can you tell me about it? What year did it come out?
Mercedes engine numbers are of the format xxxxx xx xxxxx. They are usually located on the engine block just below the head (drivers side). Please provide more information....where did you get the number you are using(on what part of the engine), any other info that will help
Oct 12, 2014 | Engines & Components for Mercedes-Benz...
Verifone vx510
At the sales screen hit F2 & F4 together password XX X Alpha Alpha 66831.
Then hit the button under the arrow on the left of the screen one time.
choose flash files the clear all files password XXXXX same as above.
Then clear Ram files clear all files and confirm
Jun 30, 2014 | VeriFone Computers & Internet
Why office2010 error 0x8007232B?
How to fix Windows Activation Error 0x8007232b:
Solution 1:
Change the product key to an MAK. To do this, follow these steps:
1. Search CMD and run as an administrator.
office2010-error-0x8007232b-vycoaah5hfbvqv45to4wibe0-2-0.png 2. At the command prompt, type the following command, and then press Enter:
slmgr -ipk xxxxx-xxxxx-xxxxx-xxxxx-xxxxx
NOTE: Placeholder xxxxx-xxxxx-xxxxx-xxxxx-xxxxx represents your MAK product key.
Once you are done with this, you should see this:
office2010-error-0x8007232b-vycoaah5hfbvqv45to4wibe0-2-2.png Just restart your computer and the problem should be resolved.
Check the other solutions here How to fix Windows Activation Error 0x8007232b Fixed
May 19, 2014 | Microsoft Windows 7 Ultimate 32 bit Full...
Power board unit overloaded l4 error
missing some number codes are c-xxxxx or p-xx
Mar 08, 2014 | Konica Minolta Bizhub C220 Color Copier
Error 49.38.07 printer unable to initialize
49.XXXXX ERROR To continue turn off
then on
A critical firmware error has occurred.
Generally this fault occurs when a corrupt file is in the print queue
to clear fault follow these steps precisley
1. disconnect the net cable / usb cable or any other data cable that the machine is connected to
2. cycle the power with no data connections.
3. your machine should now come to ready.
4. take a copy from the platen glass ( straight forward photocopy)
if this prints out then the fault is down to corrupt data.
if at this point the error 49.xx.xx is still present then order a new formatter.
5. before reconnecting the networks -make sure ALL PRINT QUEUEs are cleared before connection otherwise you'll be back at square one
( print queues are on the computers sending print jobs)
before printing your documents its wise to send a test page through to make sure the printer is still able to understand print commands.
hope this helps...if you still need assistance please call Belmonte office equipment on 01614805556
Jan 21, 2014 | HP LaserJet Enterprise 500 MFP M525dn
Window seven stater
7'Starter'Acer'RDJXR-3M32B-FJT32-QMPGB-GCFF6
7'Starter'Asus'6K6WB-X73TD-KG794-FJYHG-YCJVG
7'Starter'Casper ERA'6PB94-MC2C6-4F37H-KTJ32-PF2PT
7'Starter'Dell'36Q3Y-BBT84-MGJ3H-FT7VD-FG72J
7'Starter'ECS'BHP4B-MXP9G-RG7KQ-T8R84-CW3D3
7'Starter'Exper'4FRH4-WQDGJ-M9HRY-K73D8-RGT3C
7'Starter'Fujitsu'PMXH9-M23P9-QJJMB-2FWRC-7CDKP
7'Starter'Hannspree'BRFCY-XMXRV-28JHQ-F6D9B-BV73C
7'Starter'HP'RH98C-M9PW4-6DHR7-X99PJ-3FGDB
7'Starter'Lenovo'273P4-GQ8V6-97YYM-9YTHF-DC2VP
7'Starter'Medion'2K8WH-JVQDM-C9HVC-YR2XC-8M76G
7'Starter'MSI'2W4DJ-JFFJV-DMCPP-2C3X8-883DP
7'Starter'Nokia'2XGHP-9TQK2-8CF28-BM2P2-8FRX8
7'Starter'Olidata'344HQ-3YHDT-C7VCT-BDPBV-4KTR3
7'Starter'Sony'32J2V-TGQCY-9QJXP-Q3FVT-X8BQ7
7'Starter'Toshiba'TGBKB-9KBGJ-3Y3J6-K8M2F-J2HJQ
7'Starter'Viewsonic'6TQ9G-QB2WK-FM2TB-CKBDP-9D6HM
7'Starter'Viliv'7W842-2HCPJ-BC3MJ-B79K6-TD2HQ
7'StarterE'HP'C3HY9-34XKR-6Y9Y9-RB7TR-84KWG
#7'StarterN'Demo'XXXXX-XXXXX-XXXXX-XXXXX-XXXXX
#7'Enterprise'Demo'XXXXX-XXXXX-XXXXX-XXXXX-XXXXX
#7'EnterpriseE'Demo'XXXXX-XXXXX-XXXXX-XXXXX-XXXXX
#7'EnterpriseN'Demo'XXXXX-XXXXX-XXXXX-XXXXX-XXXXX
Feb 27, 2011 | Computers & Internet
RB-XXXXX-XXXXX-XXXXX-XXXXX-XXXXX-XXXXX
Very good, you have found the X button.
What is your issue?
Feb 22, 2011 | Computers & Internet
Product key for microsoft visio
I need 25 character number for Micrrosoft standard Office 2007
Exampel: xxxxx-xxxxx-xxxxx-xxxxx-xxxxx
Jun 06, 2009 | Microsoft Office Standard for PC
WHAT IS A SERIAL NUMBER TO REGISTER "SERVICE YOUR PC"
The Sticker on the side of your computer/bottom of laptop
example: XXXXX-XXXXX-XXXXX-XXXXX-XXXXX
Nov 21, 2008 | Computers & Internet
Ibm netvista 2257-32u
First off I would troubleshoot the NIC onboard, but if it is not working then you should have an available PCI slot to install a new NIC. However you will also have to disable the onboard NIC in the BIOS.
If you are using windows
Click --Start --run-- type in cmd and hit <enter> (this will bring up the dos box)
then type ipconfig /all
It should come back and show:
Connetion-specific DNS Suffix : xxxxx.xxxx.com
Description: Brand and type of NIC
Physical Address : xx-xx-xx-xx-xx-xx
DHCP Enabled: yes or no
AutoConfiguration Enabled: yes or no
IP Address: xxx.xxx.xxx.xxx
Subnet mask: xxx.xxx.xxx.xxx
Lease Obtained: date when it connected
Lease Expires: date when connection expires
Default Gateway: xxx.xxx.xxx.xxx
DHCP Servers: xxx.xxx.xxx.xxx
DNS Servers: xxx.xxx.xxx.xxx
If all this is showing correct then try typing ping 127.0.0.1 this will be the NIC itself and it should reply back. If not then do the following.
If it does not show up then check device manager and see if the NIC is disabled.
if it is disabled try reenabling it.
if it is not unistall the device and then reboot the PC it should find the NIC and install it.
if all this fails then replace the NIC
Oct 30, 2008 | IBM Computers & Internet
i-mate JASJAR Smartphone Logo
417 people viewed this question
Top i-mate Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
