Question about Sega Genesis Console
Reset switch stuck - Sega Genesis Console
    President:
  • 894 Answers
Well you are going to have to take the console apart to see if it can be fixed or have it be unstucked
however if it cant be fixed you will have to buy a new one then.
Posted on Aug 29, 2011
Honeywell reset botton stuck
Buy some WD40 or CRC spray and using the thin tube that comes on each can, spray around each button to get penetration into the spring inside. Pump the switch until it loostens. If this doesn\'t work you need a new switch!
Dec 31, 2012 | Honeywell Heating & Cooling
Stuck in wide mode
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 03, 2012 | Televison & Video
How to reset lights on a subaru loyale?
There isn't any "reset" switch. Whatever light system you are referring to most likely has a stuck closed switch and can not open the circuit.
Feb 20, 2012 | 1992 Subaru Loyale
The unit won't turn on or off. I've changed the battery but still no response. also the reset button is stuck and won't work
A stuck reset switch keeps the timer in a rest mode so that nothing else will function. Try to operate the switch so as to free it. Then reprogram the timer if you are successful.
Dec 30, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Insinkerator stopped working. Cutting plate rotates freely. tHE RESET BUTTON IS STUCK IN THE "ON" POSITION.
If the reset button is stuck in the on position and can not be reset, the motor has an internal overload and will need to be replaced. Turn the power off to the motor via switch or circuit breaker, let it cool for awhile, the hit the reset button again to see if it resets. If it does, turn off the power at the breaker and leave it off. At this time, you need to dislodge a jam on the rotary vane that shreds the waste, there is something most likely stuck on the vane, causing the motor to overheat. There should be an allen wrench socket area in the middle of the underside of the motor housing, use an allen wrench and turn the motor manually back and forth, to release the jam. Again, be sure the power is OFF!!!
Dec 04, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
GoGear Aria reset stuck in, will not turn on.
Have you reset the player? Reset the player by holding the off-switch and the volume-+ (plus) switch.
If this doesn't help try this: Connect your player to the pc that has the Philips device manager running, then reset the player by holding the off-switch and the volume-+ (plus) switch. As soon as the player shuts off, press and hold the volume- - (minus) switch. The Philips device manager will recognize the player now, and recommend a repair, let it do so.
Aug 18, 2009 | Philips GoGear HDD1830 MP3 Player
Is there a reset button on the Badger 5
Yes, on bottom a little recessed button should be pushed to reset the device. If the blade is stuck, the reset might not work but just keep tripping the breaker so you have to free up the blades with a broom stick or other item stuck into the disposal (with the power off of course) to turn the blades manually. Then try the reset button again. and hit the switch. Otherwise, check your kitchen's electrical breaker to see if it has tripped as well.
Aug 02, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
How do i reset my service light on my v70 1997 please
  • Press and hold odometer reset button
  • Turn ignition switch to Run
  • After SRL flashes, release odometer reset button
  • Confirm by turning your Volvo off, then on again
  • Jul 12, 2009 | 1998 Volvo V70
    Iphone stuck with white screen
    flip your sound lock switch on side, Then hold down the square button and the top wake up button till it resets.
    Jan 26, 2009 | Apple iPhone Smartphone
    Sega Genesis Console Logo
    125 people viewed this question
    Top Sega Video Game Consoles & Games Experts
    DROPNDEAL
    DROPNDEAL
    Reggie brown
    Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
