Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Wear do you put the water - Bissell 1699 ProHeat Clear View Upright Steam Vacuum
  • 694 Answers
Inside the main tank is another container for clean water.
To fill it, lay machine all the way down. Lift handle and remove container. Take to sink, turn handle, and remove lid. Fill with hot, clean water. Replace and lock the lid. Place container back into tank and put handle down.
Posted on Sep 30, 2010
Water leaking from somewhere on my bissel quicksteamer model #1970
This is not an easy one for us to offer advice on because we cannot see it. There are a lot of places that can leak water and there are a lot of parts that can wear out. You need to check the hoses and connections on all the tanks and spray bars. At least you can get parts for it now: http://www.vacsite.com/en/bissell-parts-1/bissell-parts/1970-quicksteamer.html
Apr 22, 2016 | Vacuums
Wred do I go to get one I got one from the postoffice
PUMA Online Store - Help > Frequently Asked Questions
us.puma.com/en_US/faq/FAQ.html
Due to our fast shipping process, it is not possible to change or cancel an order once it has been placed. You will need to return the original package to obtain a ...Missing: hades
Join The Club ' Five Four Club ' Clothes Delivered To Your ...
https://www.fivefourclub.com/
GET STARTED ... Each month you'll receive a different package of clothing according to your style profile and preferences. ... Shipping for exchanges is on us too!* ... most of the clothes I've been sent in the past six months go well with the items I alreadyhave in my closet." ... Five Four Club, Online Retailer, Los Angeles, CA.Missing: hades
My Team Shop ' BSN SPORTS
Dec 16, 2015 | Vacuums
HOW DO YOU PUT THE BAGS IN THE EUREKA POWERMITE
My guess is to wear thick work gloves unhook metal cord from neck, unzip zipper and install or replace bag and put everything back.
Jul 14, 2014 | Oreck XL Ultra Bagged Upright Vacuum
We have the water hooked up at the back of machine. there is a spout for the water to come in and fill the ice tray.but is does not. If we turn the water on it fills up the space under the ice basket. I...
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
With the fill tube blocked with ice the water can drip down the back wall or drip into the ice bin or just stop up. You can use a hairdryer to thaw the tube out.
Feb 18, 2011 | Vacuums
Pipes will not pull apart
depending on the joint but holding it over the steam of a boiling kettle or wrapping a tea towel around the joint and pour boiling water on it, allow to sit 2 minutes then separate. Be careful and wear thick gloves
Jan 11, 2011 | Vacuums
No water
check the pump belt that runs from the brushroll to the pump. frequently the plastic gear on the pump wears out. the pumps also frequently fail. check all solution supply lines for cloggs, and most importantly check the spray nozzles inside the unit by the brushes for cloggs. let me know if you need any further instructions. thanks,
chuck
Jan 07, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
It will not **** up the water.
the squeegee strips on the bottom often wear out causing the machine not to **** up water. the part # is 59177047. the old one can be removed by two screws inside squeegee and one on the outside in the center. let me know if you have any more problems
Jan 06, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
Dirty water is not going into the tank, it's leaking out the bott
Check the little door at the back of the unit where the hose attachment plugs in. It has to be shut really tightly and it takes a quick fist smack on it to get mine to "click" and be shut. If that isn't sealed it could leak both clean and dirty water to the floor.
Also, take the dump tank off, check the filter (near the top where the dump tank connects on the machine side) is clear. Also make sure the rubber seal around the filter isn't loose or cracked. Then put the dump tank back on making sure the bottom is seated well first and then CLICK the top into place when you push it to the upright/in place position.
If you are using the hose attachment, make sure it is clicked into place tightly. I have to put one hand on the front of the machine to push toward the back while pushing the other hand on the hose to get it to click tightly in place. If it's not really snapped in there, it will leak.
Apr 19, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
I have a Bissell Proheat upright 2x and the water and soap is not coming out. Help!! Wear is the heating element located on the vacuum?
Does the water come out of the tank by pushing in the valve at the bottom? If it does, then you could have a clog somewhere and taking it all apart is the only way to find it, but you could first try running a mix of vinegar and water to see if that will clear out the lines. The other is a bad pump and soleniod.
Apr 24, 2008 | Vacuums
Bissell Quicksteamer
the problem is that after used you have to run clear water through it. the reason is that once you put it away there is still soap inside the tubes. after some time the soap gets hard and clogs it. in the case of the machines that have the heat the heater is also full of hard soap.
good luck
Nov 26, 2007 | Bissell 1770 Quicksteamer II Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
49 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
