HD LCD TV E MOTION Hello, my tv will power up but sometimes i have a blank screen but have audio? Other times it works fine? I used to be able to get it work by banging the top of it. At the minute the screen is on but very dark? i would be really greatful if you could help this problem.
SOURCE: Sharp aquos lcd screen goes blank
i was having these same problems with the screen going black, and i found that when i hit the back of my tv it would work sometimes. so, i improvised on some of the advice on this page and so far no problems. here is what i did (its very easy):
1. lay the tv on the floor and take off the back panel. (i think 12 screws)
2. on the right side of the tv (as you are looking at the back) you will notice a large metal covering that is held in place by 6 screws. unscrew these and remove the metal cover.
3. you will notice that the three screw holes on the left side of the board have some sort of metal or solder around them, in sort of a star pattern. when i looked closely i noticed that most of the metal (solder) was tarnished, or kind of blackened. (this must mean that the ground screws werent getting a good connection and this would explain why it would work sometimes when i hit it because it would vibrate the screws enough to get a good connection! )
so, take a pencil eraser and erase all the black or tarnish off the metal surrounding the screw holes. thats it! (to be safe i took some sandpaper and cleaned up the screw holes on the back of the metal covering, but i dont know if that was necessary)
at this point i followed another gentleman's advice to do a hard reset. this involved unplugging the 8 connections although i dont know if this was really necessary because i believe my problem was a ground issue. i did it just to be safe. his advice is on this site if you want to do this step.
4. i put everything back together and it worked! i performed a soft reset at this point which puts your tv back to factory settings. just go to menu>setup>reset>return to factory settings? yes
this will turn your tv off and back on. that's it. so far so good for me.
Posted on Dec 18, 2008
SOURCE: westinghouse 32 inch screen goes blank
I had the exact same problem and I fixed my Westinghouse 32 inch by replacing the power supply. You can purchase it at
http://www.partstore.com/Part/Westinghouse+Digital+Electroni/Westinghouse+Digital/4900211680/New.aspx?ModelMfgName=Westinghouse+Digital+Electroni&ModelBrandName=Westinghouse+Digital&ModelNumber=LTV32W1
I takes about 15 minutest to replace. Just take the back lower panel off and replace the power supply. Mine works like new now.
Posted on Jan 25, 2009
falter
  • 245 Answers
SOURCE: Hitachi 32'' lcd tv picture runs slow sometime and goes dark
go in touch wit HITACHI costumer help and service and tell them ur problem u have.....how old is ur TV?
hope u get a answer from hitachi....and good luck
Posted on Mar 12, 2009
stonephoenix
  • 563 Answers
SOURCE: SCREEN BLANK....
I have over 10 years experience in electronic tech support. Currently I work for Viore customer service. Our customer service phone number is 216-454-0868.
I know this isn't what you want to hear, but the problem you've described can't be fixed with troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. The repair will cost a minimum $250 to $300 with parts and labor. If you're interested in going forward with repair, take the TV to a repair shop in your area to have the problem diagnosed. The tech will give you a copy of the work order showing the part(s) needed to complete the repair. Then you'll call the above number and ask to speak with Raphael at ext. 3115. The work order will be forwarded to the corporate office and they will contact you with the price of the replacement parts. You will be charged for the parts directly to avoid any markup by the repair shop. The part will be shipped directly to whatever repair shop you choose.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. I hope I've earned a positive rating from you today.
Please let me know if I can be of further assistance.
Posted on Jun 18, 2009
  • 24 Answers
SOURCE: TLX-03210B blanks out, audio works, with some smoke as well
Open the cover and look for the burned componet.Usually it must be a condenser. Rarely a resistor.If it is a condenser just replace it with the similar one. Note the polarity while replacing. If it is resistor need to check the associated circuit for over load. If you not sound in electronics reffer to an expert.
Posted on Sep 11, 2009
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Screen goes blank on Samsung LCD TV. Comes back on if tilt or move screen.
I'm gonna go out on a limb and say you may have a LCD tab(s) that are failing.
Jan 26, 2013 | Samsung LE32R73BD 32 in. HD-Ready LCD...
My samsung LE40R74BD set works fine for about 10 mins then screen goes blank (black) . It would appear there is no back lighting. I have visually checked the psu for blown capacitors but all seem to be...
This does not seem to be a power supply issue but rather an issue with the backlight inverter board. When the screen goes black, take a flash light and focus it on the screen from a close distance and several angles. See if you notice a very faint image. Try changing the channels to make it more noticeable. Try it and let me know
May 09, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
We are having HDMI handshake problems between our Onkyo TX-SR607 and our Sony KDF-55WF655 LCD Projection TV. The problem is intermittant. Sometimes it comes up just fine, and other times the screen is...
Hello, I am sorry for your issue. Haw long is the HDMI cable from the receiver to the TV? Have you tried a different cable/ Thank you, Onkyo USA
Jul 03, 2017 | Onkyo TX-SR607 Receiver
New Proscan 40 goes to green screen when using HDMI cables
I have the same problem with a 40" Toshiba LCD, Component cables work fine with FIOS but not HMDI, goes in and out then blank. HDMI with DVD player works fine. Best buy reported this same problem from users with this toshiba lcd but no solution.
Dec 26, 2009 | Proscan PS50700 50" Rear Projection...
White/Grey screen with non-HD channels
I removed the HDMI cable and connected with component video and rca audio. No more white screen.
Picture quality looks good. I don't know if it's as good as HDMI, but then I don't need to reboot the TV three times to get to teh on-demand menu... Grrrrr....
I am trying to contact Toshiba on this as well. I have seen several reports of this problem on the web.
Dec 04, 2009 | Toshiba 19AV500U 19 in. LCD HDTV
Samsung LCD tv - Turns on and off by itself.
Since you have another TV with the same problem you can try using an antenna(indoor model ok) to see if the cable is causing the problem. If not return TV before the warranty expires.
Mar 03, 2009 | Samsung LN46A850 LCD TV
Picture goes blank but audio on
If you are using component cables to connect your HD box to TV. Make sure your connections are tight. You should make the colors match up. Green, Red, Blue. Check on both TV and HD box. Make sure HD pox is powered on. Make sure to select TV input to Component 1 or whichever you are using. If this doesn't work you may need to call and have COX refresh the HD box. This can be done over the phone. This will make sure you are receiving and sending the proper signal level. Good luck
Oct 05, 2008 | Vizio L30WGU 30 in. HD-Ready LCD...
Samsung tv prob
My daughter's LCD which is barely used started showing horizontal coloured lines.I read that the LCD's are vunerable to static/charge build up and also power surges.
I unplugged my daughter's TV and it is now working properly however we now unplug the TV when it's not in use.
I was considering purchasing a larger model for the faily room but Not going to waste my money until they improve this rechnology.
Good luck to all.
Cheers!
Mar 22, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Samsung LTP326w
After few years of service with different TV providers I have problem with my TV. Last night my Samsung LTP326W just did the same think on HDMI connector and no mater what you do it will not turn HDMI video... it's connected to Verizon/Motorola DVR I called Verizon and they promptly replace DVR and HDMI cable but it didn't help at all, also sometimes when you power on/off I get message: The HD Content Protection of your display has been compromised Please use the YPBPR outputs for your HD connection...
When I switch to component cable it works just fine.
Feb 09, 2008 | Samsung LTP326WX/XAA 32 in. HD-Ready LCD...
Televison & Video Logo
619 people viewed this question
Top Televison & Video Experts
