Question about Hotpoint WD62 Front Load Washer / Dryer
Hotpoint WD62 leaks heavily during spin cycle
I have a Hotpoint WD62, which has started to leak heavily during the spin cycle.
Could this be a relatively cheap fix, or should I think about getting a new one?
Regards
Ron.
  • ron2464 May 26, 2008
    Hi gittos73,
    I have had a good look around the door seal, but cannot see any holes at all. If it is a problem with the door seal, would it not leak through the whole wash cycle, and not just the spin cycle?
    Regards
    Ron.
  • ron2464 May 28, 2008
    Hi gittos73,
    OK, got to the bottom of the problem. It turned out to be a sock that was causing a blockage ... could have been embarrassing :-)
    Anyway, thanks for all your help, you're a star!!
    Regards
    Ron.
    Novelist:
    Champion:
  • 244 Answers
Hiya m8 check the door seal first you'll need to pull the seal slightly out to see under the flappy part they usually go there this will be the most likest leak u don't have to undue anything to do any of this and when u find the hole it will only be around £15 to get a new door seal u might have to run your fingers around under the flap to find it aswell m8 let me know if it is and ill tell u how to replace it m8
Posted on May 26, 2008
  • peter gittos
    peter gittos May 28, 2008
    what happens is while it leaks it fills the bottom support around the washer after it fills up through time it then overflows and water starts to show so most of the time and doesnt look like it is leaking all the time what u can do is pull the washer out from were it is now undue the 2 screws at the back which hold the top on remove the top now with the washer being at least 10inch away from your worktop tilt it back so the top of the washer is on the worktop with about 6inch left of the top above the worktop thus will give u enough room to look underneath at the pump which will be on the left as u look under the washer if that is wet turn power off undue the pump with the 2 8ml bolts there will be water that will come out once the pipes are taken off the seal in between the 2 ends can be re-sealed by unduing them and placing a water-proof sealant between them then doing it all back up and leaving for at least 1hour for the sealant to go off put back together if the pump isnt wet then it also gives u space to look up at the door-seal but the hole could be at the top which u would be able too see when u take off the lid of the washer try all these then get back to me m8 peter
WATER IS COMING OUT FROM THE BOTTOM OF THE WASHING MACHINE ONCE THE WASHING HAS STOPPED, IT DOES NOT LEAK DURING CYCLE AND IT SPINS AND DRAINS FINE..
i would inspect both the hoses on the pump
no leak during cycle is explained because water is moving through them to fast to leak when the machine settles it starts to leak
Oct 15, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wd62
Try taking the top off, power off obviously!! and remove the draw unit, there is a pipe that runs from there to the drum.... I found a sock in mine that was the problem !!
Feb 03, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Aquarius wd62 front drawer leaks
I had this problem and solved it by just leaving the draw sticking out a little bit! Now there are no leaks!
Feb 01, 2009 | Hotpoint WD62 Front Load Washer / Dryer
Unbelievable...leaking again!!!
take panel off at bottom rear. you will see a large diameter pipe going from bottom of machine to pump. undo pipe at machine end - carefull lots of water will come out. sock was probably in this pipe which also holds the filter
Jun 17, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint wd62 leaking from the drawer
Hi, check the electrict valve winding busted hot and cold.
Jan 27, 2008 | Hotpoint WD62 Front Load Washer / Dryer
WD62 drawer leak
remove drawer clean it make sure flap is free on drawer compartment
Nov 24, 2007 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint Aquarius WMA56 wont drain properly water leaking onto floor
pump is working water is only a trickle coming out so wont final spin
Nov 07, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint WD62 Front Load Washer / Dryer Logo
116 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
