Question about Asko Washing Machines
My Asko washing machine suddenly lost power. Could it be fuse problems? How do I replace the fuse.
    Sergeant:
    Champion:
  • 351 Answers
The fuse are on the back of washer you will see them top right
Posted on Sep 29, 2010
I have Asko washing machine W600/Quattro 1000 and it is not closing the door all of a sudden - so not able to do washing.
Try lifting up on the outer bottom corner when shutting the door, if it shuts that way then there is probably a loose screw on the hinges that needs tightening.
Jan 25, 2017 | Asko Washing Machines
We have been given an Asko W600 to replace a washer lost in the brisbane floods. But we can't get it to start. We have a user manual but can't locate an installation guide. Can you help us please Jenni
I did some research on this Asko machine-
Apparently there are a couple fuses to check--
Do you have access to the internet?--
Here is a link that might be real helpful:
http://www.fixya.com/support/t6444675-asko_20004_washer
Let me know if this helped-- or what more we can do to help you.
Mack B
Jan 25, 2011 | Asko Washing Machines
My Asko 20004 washer has been running perfectly since November 1, 1996. On Friday, while washing a load, the washer suddenly stopped. No power, on-off switch did nothing and I checked the house fuses and...
Hello Rick,
Welcome to FixYa.
There are 2 internal fuses for the Asko washer, on the 20004 model they are located at the back next to the power cord...
i.e.
To remove and check the fuses you`ll need a flat/slotted screwdriver and place it in the slot of the fuse holder and turn them left 1/4 turn and pull out.
**The above is an image for removing the dryer fuse, but the same procedure applies**
Once removed this is what you should see...
I would also suggest removing the top of the washer to visually inspect the condition of the wires as a poor connection can cause the fuses to blow.
i.e.
The replacement part is a 240v 15 amp slow blow fuse. part number will be as listed below and it is a complete kit available at "repairclinic.com"
# 1460992
Hope that answers your question or better yet solves the problem altogether.
Thanks for choosing FixYa and good luck. Please take a moment to rate the info provided and a short testimony if you will its warranted.
Regards,
Macmarkus :)
Oct 17, 2010 | Asko Washing Machines
Lost manual
yes directly from asko online
May 16, 2010 | Asko W6221 Front Load Washer
Power light is not turning on. I have replaced the 2 15 amp fuses in the washer (not ASKO fuses) and I have confirmed that the beaker panel is working fine and the dryer which is linked to the washer is...
There is need to check if there is power getting at the fuses and power getting to timer control board.That is done reading volts with a multimeter.
For safety reasons I need to remind that all test with live power must be done by a trained repairman.
If there is no power at all and you already replaced the two fuses, then problem can be power cord, internal wiring harness, control assembly .
Sep 08, 2009 | Asko Washing Machines
Asko washing machine has no power
check your ground fault interupters (outlets with butons) under the sink and around the kichen
then check the breakers in your breaker box
finaly call a sertified tecnition
Jan 22, 2009 | Asko W6441 Front Load Washer
Asko W6761 Front Loader
check the fuse on the back panel if thats ok check to see where theres power it may be a display board fault.
Aug 27, 2008 | Asko W6761 Front Load Washer
Loss of power on LG WF-T652A
I have the same problem as you. Machine was stopping intermittently in wash cycles - usually near spin/drain and sometimes just wouldn't turn on. Now it won't turn on at all...
Jun 22, 2008 | Washing Machines
Asko 20005 Washing Machine Stopped Running
If all your power did shut down of the machine it might well be a fuse problem.
If you have a mult meter you can check the resistance of the fuses. they must be near 0 . infinit resistance means blown.
otherway to test it lol for the DIY under us take a 9 volts batterie and conect one pole to the fuse . now connect tongue to fus and other pole. Little shock? no blown fuse.
nothing than the fuse is blown. ( by the way not the most pleasurable feeling)
Let me know if they were blown or not.
May 13, 2008 | Washing Machines
Washing Machines Logo
415 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
marley mcelhinney
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
