Question about Philips GoGear SA178 MP3 Player
Big problem with play lists
Hello Doctor
I have big problem with playlists on my PHILIPS MP3 SA3115 /02. I do everything normaly, add music to the library next I create 3 lists each with different type of music and different name of the list then I add music to the each list and after this I sync everything to my player. I see progress in my WMP 11, files synchronizing one by one, everything seems to bo alright but when I turn on my player I didn't see any lists in the menu in the playlists panel only playlist on-the-go. I've tryed to copy playlists manually to the playlist directory but I didn't work as well. Any ideas Doctor??
Is it possibly to create list by folders?? that would be perfect for me.
regards
  • 8,596 Answers
According to the manual for most GoGear's, you have to have automatic synchronization enabled in Windows Media Player for the playlists to transfer correctly.I still have not been able to verify if this is true, since I have been able to transfer playlists fine with and without auto-sync engaged.
I haven't tried a 3115 specifically, but with an SA4111 and an SA5125, I just created the playlist in Windows Media Player 11, right clicked on the playlist name after it was created, selected "Add to Sync List," and then "Start Sync" with GoGear connected. I used this method, because it seemed more likely to add the songs AS A PLAYLIST rather than just dragging and dropping the tracks WITHIN the playlist.
As I look more closely at the documentation for the SA3115, however, it does not have the same playlists options as other GoGear's - it seems to limit you to Playlist-on-the-Go. I know that the GoGear will not recognize folders that you create in Windows Explorer, so that option is out. You can connect the GoGear, and see if a Playlists folder appears in the left-hand pane underneath the icon of the GoGear in the Sync tab. My gut feeling, however, is that this player is just not as equipped as other GoGear models for playlist transfer. I'll go back to the lab on tuesday and see if I can find anything new.
-Tha Mp3 Doctor
Posted on May 26, 2008
How do i copy music to my mp3
You can sync your music and pictures to your player using Windows Media Player.
By default, Windows Media Player automatically loads all the music and picture files
stored in your My Music and My Pictures folders into the library. If you add new files to
these folders, they will also be automatically added to the library.
If Windows Media Player has selected to sync your device automatically, you can choose not to sync your entire media library. You can choose what you wish to sync from existing
playlists or create new playlists. These playlists you have selected will then sync to your player every time you connect it to your computer.
1 Click the down arrow beneath the Sync tab and select Philips GoGear SA60xx > Set Up Sync.
> The Device Setup dialog box appears.
2 In the Available playlists pane, select the existing playlists you want to sync and then
click Add.
28
4.3.4 Select files and playlists for Manual Sync
If you sync manually, you must create a list of files and playlists you want to sync. You can also shuffle which files from your playlists to sync to your player.
1 Start Windows Media Player.
2 Switch on your player and then connect it to your computer using the supplied USB cable.
3 Click the Sync tab.
4 Drag the files and playlists that you want to sync from the Contents pane to the Sync List pane. You can also right-click on the file or playlist and select Add to "Sync List".
3 To create a playlist, click New Auto Playlist and follow the steps on the screen to specify criteria for files in the auto playlist (for details on how to create an auto playlist,
4 To remove a playlist, click the playlist in the list of Playlists to sync, and then click Remove.
5 In the Playlists to sync pane, select a playlist and click the Priority arrows to arrange
them in the order that you want them to sync.
Feb 12, 2011 | Philips GOGEAR SA6045 MP3 Player
I can't make my archos
be sure that you have already saved a list of song on your playlist. and for the pdf also make sure that there was a file that save on that location...
let me know
Aug 29, 2008 | Archos Audio Players & Recorders
What does sychronizing do?
Synchronizing on most mp3 players is used for transferring one or more playlists from a computer to the player, having a connection through USB.
Creating playlists, putting mp3 data in a list with a certain name,
mp3 could be put in a specific order.
The player preserves some space of memory to remember these playlists and the playing order.
Some players support subfolders, but not having the manual for the
MP200 I'm not sure if that will work.
e.g.
MUSIC > music list 1
> music list 2
Dec 20, 2009 | SanDisk Sansa e250 MP3 Player
Need Creative Zen user manual. No longer on the website. I really just need to know how to create playlists if you can help me with that.
  • Creating playlists for Creative Zen MP3 player
  1. Step 1 Turn your Creative Zen MP3 Player on and add music to its hard drive if you haven't already. Without music on your player, you won’t be able to select tracks for a playlist.
  2. Step 2 Select "Music Library" from the Main Menu. The Main Menu should appear as the first menu when you turn your device on.
  3. Step 3 Select "Now Playing" from the options available, then press the Options button.
  4. Step 4 Select "Save as Playlist" from the list of options. This will save the tracks you have listed currently as a playlist that can be reloaded later.
  5. Step 5 To play a playlist back, go to the Main Menu, select the playlist and click
Jun 16, 2009 | Audio Players & Recorders
Deleting playlist
Nextar MA933A – Deleting Playlists
There are a couple of different ways to approach this problem.
You could 1. connect the Nextar to your computer
2. Double-click My Computer
3. Double-click the icon that corresponds to the Nextar – this is going to be different for every computer – some will have an actual Nextar icon, some will display it as USB Mass Storage Device, and others will list it as a Removable Drive – if it is listed as a Removable Drive, you can find the right one by double-clicking each removable drive until it gives you a new window with folders labeled Music, etc.
4. Enter the Music folder and Delete the folder that corresponds to the playlist that you want to delete
If that set of methods fails, or your mp3 player does not allow you to view the contents of the drive:
1. Go to the MSC menu
2. Press MENU button
3. When you see a song displayed in the LCD, press the Play key to pause the song
4. Once song is paused, press the MENU button
5. Select “Delete File,” and select the songs you want to delete
6. Use the Menu left/right keys to toggle between “Yes” delete and “No” don’t delete
-Tha Mp3 Doctor
Feb 05, 2009 | Nextar MA933A MP3 Player
Playlist dont Show
That player is set up for playlist transfer through Windows Media Player 10 only - you can either: 1) rollback your Windows Media Player to ver. 10; 2) attempt the firmware upgrade by running the Update tab in Philips Device Manager (may not work); 3) reinstall the installation CD - select Repair as your choice - it will add a plug-in that it may have skipped during initial installation. Good luck!
-Tha Mp3 Doctor
Dec 29, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips GoGear SA3245 - Playlists Not Showing Up on Player
Have solved this problem on GoGear syncing with WMP 11 by going to options on the device itself, then go to the "settings" option, scroll down to "PC Connection Preferences", from here you will select the check box saying "MTP" then back out of options and connect your device and go back to your WMP 11 and drag your playlists to the syncing area and resync your device. You should then be able to see your playlists under the playlist option in music along with the "playlist on the go" playlist.
Hope this will help!
- Jared
Determan Technology LLC
Aug 31, 2008 | Philips GoGear SA3245/37 Digital Media...
Pearl Mp3 Player
Once a playlist is created, you must remove the entire playlist from the mp3 player to re-add a playlist with additional songs on it.
-Tha Mp3 Doctor
Aug 20, 2007 | RCA TH1101 MP3 Player
How do you add a playlist to the player!!!
There is another way but that is called Favorites. First go to settings on the player and enable advance then go to one of your songs and press the select button then it will give you an option that says add to favorites? choose the check mark to add that songs to your playlist. Also there is a way to add playlist using windows media player. The steps given would be for windows media player 10. First click on the Library Tab thecn click on the arrow for the Now Playing List choose New List then Playlist, now add songs to your newly created playlist by dragging them to the drag items here window after you have choosen all the songs you like click on Now Playing List and choose Save Playlist As.. After saving the playlist change the settings of the player to Autodetect and connect the player to the computer. Now wait for it to be detected by the computer and click on SYNC tab on the windows media player software. There are two windows the left is where you will choose the playlist the right your mp3 player. Choose the playlist that you have created and click on START SYNC now it will be transferring the playlist to your mp3 player just go to Music then Playlist. Hope this helps :D
Jun 30, 2007 | SanDisk Sansa m230 MP3 Player
Mp3 player
Load the Philips software onto your computer. You have to load the songs onto the player using WMP (Windows Media Player) 8 or 9. Connect the player using the USB cable. Run the Philips Go Gear Digital Audio Player software. Upgrade the firmware. This will format the player and erase everything you have done so far. Start WMP. Click on the Synch tab.It will have 2 window panes. In the right side, at the top, there is a drop list. Select the player from the list. Now create a synch list by clicking on edit playlist. Once you have added the songs, click Start Synch. That's all there is to it. Ian
Feb 02, 2007 | Philips GoGear SA261 MP3 Player
Philips GoGear SA178 MP3 Player Logo
257 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
