Keyboard has mind of own
I dont know what happened but my function key has reversed my keyboard when i hit the letter k i get the nbr 2 and so forth with the rest of the keys.
  • sulpitius Mar 15, 2009
    keyboard types
    4 instead of u
    5 instead of i
    6 instead of o
    etc. its typing all the "function" of the actual key by itself. the only way im typing correctly is by holding down the fn key.
For the user that has
4 instead of u
5 instead of i
6 instead of o...
There is a Num Lk key on top right of your keyboard to change modes.
Just press it!
Posted on May 20, 2009
If you have the wrong Keymap in your Settings files the Computer cannot see and will map letters and numbers where it is told to.
Try to find the correct map for your Keyboard and set that up on the control panel /System Preferences of your Computer... C
Posted on May 28, 2008
I have a ""m edge" keyboard but cannot find the manual online. I dont know what the function of some of the keys are. Very frustrating when I can't even capitalize words! Where can I get instructions?
You must be kidding. Use the shift key to capitalise whilst you hit the letter or just hit the caps lock key.
You are probably not going to get instructions more than these which took 5 seconds to locate...............
http://www.medgestore.com/images/about/keyboardmanual.pdf
Mar 01, 2016 | Computers & Internet
My email n password dont match, how can I fix it?
The procedure to troubleshoot email account login issues may vary depending upon your email service provider. So, to let us suggest you a specific solution, can you please share with us the name of your email service provider?
In the meanwhile, we recommend you to make sure that all the keys on your keyboard are functioning properly. If one or more keys are jammed or have stuck up, the keys that you hit may not display characters correctly on your login page. Also, make sure that the functional keys like Caps Lock and Nums Lock are On or Off only when required. To make sure that the keys on your keyboard are working fine, you can first try typing your email ID and password on a Notepad or Word Document and see if they come up correctly. If the keyboard is working fine, we suggest you to try typing your email ID and password slowly (if you have not done this already). Also, give special attention to characters like 2 or Z, 0 (zero) or O, 1 or I, 5 or S, 8 or B etc.
If one or more keys on the keyboard have become malfunctional, try logging in to your account through some other device (if you have not done this already) or consider using a different keyboard (if possible).
You can also try onscreen keyboard by press and hold the Windows key and hit the letter R. Type in OSK and hit enter. Try using the onscreen keyboard if the keyboard is not functioning correctly.
GuruAid.com
Jul 17, 2014 | Computers & Internet
Above my scroll/# lock the lightbar is lit,and some letters produce #... i = 5 etc
Sounds like yo have the scroll lock or num lock turned on. If the scroll key is a colored key (the scroll lk lettering is blue) then you will have to Press and Hold the FN function key at the lower left portion of the keyboard then hit the scroll key to turn it off. When it is turned on if you press the letter i you get the number 5. If you press the letter O you get the number 6.
Notice that the numbers on the keys that have letters are a different color than the letters (blue most times). That means you have to Press and Hold the blue FN function key at the lower left portion of the keyboard then hit the key with the same color if you want the colored representation to happen.
Some laptops will use a Square Box instead of the blue colors on the keys. In that case you have to press and hold the key a the lower left portion of the keyboard that has the square box, then hit the key you want.
Jun 03, 2012 | HP Compaq Presario C500t Notebook
When you are typing it will type the symbols instead of the letters, you have to keep hitting the function button for the letters to work, sometimes it will work hitting it one time other times you have to...
Hi
Try system restore. Go to START>ACCESSORIES>SYSTEM TOOLS>SYSTEM RESTORE>CHOOSE PREVIOUS RESTORE DATES. Use other restore dates if needed.
Or try this
If your laptop keyboard types wrong characters, it is rather a software issue than an hardware one. This can happen if you accidentally press certain keys on your keyboard, which enable a certain kind of function.
Try the following steps in case your laptop keyboard displays wrong characters:
1.Go to the control panel option
Click ? 'Regional and Language Services' ? 'Languages' ? 'Details' ? 'Key Settings'
2.Select the option 'Switch Between Input Languages' and click on 'Change Key Sequence'
3.Ensure that all the check boxes are unchecked in this window and do the same for 'Switch to...(Keyboard Type)'
4.Click ?
'Ok' ? 'Ok' ? 'Apply' ? 'Ok'.
This should solve your problem
Jun 24, 2011 | Acer Aspire One AOD150-1920 Netbook
My laptop is only typing the numbers that appear on the letter keys. For example when I hit the letter J, it types a number 1. When I hit the letter k key, it types a 2, etc. How do I get it to go back...
Usually you have to hold the "Fn" key to get to these. Look for a "NumLock" key to turn this off. You may need to use the "Fn" key to select numlock.
Mar 10, 2011 | Computers & Internet
When i hit the letter U, I, O, P, J and so forth on my mini keyboard, I get the numbers 4, 5, 6, * instead. In essence I'm getting what on the upper right corner of those keys
your numlock is turned on. look for a key labeled fn and something like a padlock.. hold the fn key like a shift key, then tap the padlock.. this typically happens when someone plugs in an external full sized keyboard.
Sep 25, 2010 | HP Mini 1000 Netbook
My keyboard will not let me type 2 letters in a row without pushing shift first. ex- if i type letter, it loks like this leter if i dont hit shift before hiting the t again. same with backspace, if i need...
try turning off filter keys. if you don't know how to do this, go under control panel, click on the search bar if you have vista, just type in "repeat" and click on the filter-keys link. then uncheck the "turn on filterkeys" box and click apply at the bottom. best of luck.
Oct 10, 2009 | Gateway 2520915 Keyboard
A key (which one?) changes the letters all keys type
You're hitting SHIFT and CTRL -- which changes the keyboard input method, i.e., for French keyboard, or for DVORAK keyboard, or for Scandinavian keyboard.
Access CONTROL PANEL, and use REGIONAL settings to "uninstall" all keyboard-layouts that you _never_ use.
Jul 01, 2009 | Microsoft Natural Ergonomic 4000
SHIFT LOCKED ON
There should be a function key that is a light blue on the lower left. Hold that down and hit the NUM lock key at the upper right.
What happened is that you turned the numlock on just like on a regular keyboard but on a laptop, its a secondary function key where the letters double as numbers when the function numlock is turned on.
give it a try and let me know.
Good luck
Feb 15, 2009 | HP Compaq Presario V6000T Notebook
Computers & Internet Logo
500 people viewed this question
David Payne
David Payne
